08-12-2016, 08:29 PM | #76 |
Re: Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S475
Man that rolling chassis is sexy!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
08-14-2016, 12:28 PM | #77 |
Thank ya sir!
Ha it's almost a shame to even put a body on it and cover it. Almost lol
Todd https://www.instagram.com/shores6/ Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S480 - http://67-72chevytrucks.com/vboard/s...d.php?t=700419 |
08-14-2016, 01:12 PM | #78 |
A320 Pilot/USAF Retired
Nice build, love the patina!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
08-16-2016, 07:46 PM | #79 |
Thank ya sir. The patina was exactly what I was wanting!
08-16-2016, 08:05 PM | #80 |
Alright, back to the bed floor. When it came time to cut the bed floor out for the hinged section, Im not gonna lie I was scared **** less lol But it went according to plan.
For the hinged section, I just built another frame out of 1" square tubing that fit inside the 1.5" tubing. The hinges are around 7" long, 5/8" diameter barrel weld on hinges. When it came to mounting the hinged section, I got some tabs and welded them to the 1" square tubing and put nut serts in the crossmembers in the bed. The struts were definitely trial and error. I ended up with struts that are almost 21" long extended with 70 lbs of force each. Mounted some trick tabs in a couple different spots until I was happy with where the hatch shut. When the hatch was open, I wanted it to be the same angle as the hood when its open. So I put one of my Porterbuilt hinges together and put an angle finder on it and it was around 45*. Also got some chub tubz from Rob. These things are awesome. I ended up with the CT44s for a 12" wide wheel in case I decide to make a wheel change in the future. The chub tubz are just mounted with 4 bolts in each corner with nutserts in the bed floor. I looked at about a million latches for this thing. I want something that was going to latch but also be able to be used as a pull. Easy enough, right? Wrong. While finding a latch that meet that criteria is pretty simple, finding one that also met the dimensions I needed was a bit of a chore. The problem was the ribs in the bed floor only being an inch and half wide. Most latch pulls were 2.5" in diameter. Would look a little dumb in my opinion. I ended up with a compression lever latch from southco. While it wasn't my first choice, it was definitely my best choice. Then it was off to get some more powder coat
08-17-2016, 08:11 AM | #81 |
Still Learning
Excellent work on the bed modification. I like the latch too. Keep up the good work!
08-17-2016, 08:15 AM | #82 |
Awesome job on the bed floor. I'm going to steal some ideas when I get to this point
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
08-17-2016, 08:58 AM | #83 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-19-2016, 03:15 PM | #84 | |
08-19-2016, 03:23 PM | #85 |
The bed floor is all mocked up and finished for the most part. I struggled with what to do with the underside of the bed floor. I thought if I left it rusty it would look out of place when I had the hatch open. Then I just went with the mentality of old on the outside, new on the inside. Then it came down to painting it or having it bed lined. I ended up having it bed lined for fear of the painting chipping with rocks flying up from underneath. Also had the underside of the chub tubz bed lined.
08-19-2016, 10:53 PM | #86 |
Nice!
09-01-2016, 07:11 PM | #87 |
Alright guys for the first time since I started this build thread, I'm finally on real time with my updates. I've been building this pile since around December of 2014. This is the first truck I've ever built. Why not go all in on the first one lol I've learned a lot from the start to where I am now. A lot of that knowledge come from a ton of reading on this site and watching yall's build threads. So thank yall.
Anyways, back to your regular scheduled program. I got the bed frame back from the powdercoater. Went with the same millennium black as I did with the chassis. Also got the rear bumper brackets put on. Minor I know but at this point any progress is good progress. Got a start on the accessory drive as well. While I would love to have a front runner kit, I just cant bring myself to drop $2800 for one. So I went with Dirty Dingo brackets with new accessories. I'm still trying to find an AC bracket thats going to work. That part is a pain in the rear. Wouldn't be that big of a deal but the turbo is in the way of a regular mount and the porterbuilt stuff is in the way of a lower mount. So I might have to get creative with that.
09-01-2016, 07:22 PM | #88 |
That's !
09-04-2016, 07:51 PM | #89 |
09-04-2016, 08:00 PM | #90 |
The bed floor turned out super slick! Love the build 🤘🤘
09-05-2016, 11:29 PM | #91 |
Thanks, man!
09-06-2016, 08:58 AM | #92 |
im totally diggin that bed frame ya got going on. Its crazy how similar to mine it is only mine goes full length of the bed. Mine isnt fully built yet. Is yours pretty stable so far.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
09-06-2016, 02:41 PM | #93 |
Thanks! Yeah so far it's solid as can be. I wanted it to go full length but still wanted to be able to put an ice chest or something else back there when I had the hatch open. I'm pretty happy with how it turned out.
09-06-2016, 06:05 PM | #94 |
looking good! can't wait to see the engine built up and the cab back on.
09-06-2016, 07:53 PM | #95 |
You and me both! You'll probably hear me all the way from Georgia when I get the cab put back on lol
09-07-2016, 09:44 AM | #96 |
I love that patina.
1971 C20 Daily, Built 350/700R4 1971 K20 Project, LLY Duramax, 5 speed Allison, and 8 in lift on 37x13.50s K20 Build |
09-07-2016, 10:14 AM | #97 |
Very nice!!!
09-14-2016, 04:43 PM | #98 |
Thanks, fellas.
Stay tuned.
09-14-2016, 05:53 PM | #99 |
A guy with a truck
Progress looks killer! Got your PM, sent you a text.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 09-14-2016 at 06:02 PM. |
09-16-2016, 08:15 AM | #100 |
