11-19-2012, 09:32 AM | #126 |
Re: Work Trucks - Utility / Service / Company / Fire / County
how much weight can you lift with that boom?
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
11-19-2012, 11:25 AM | #127 |
5 k. i still need to finish the outriggers, before i lift to much, i have to date had around 1000 lbs on it.
1964 1 Ton flatbed service truck (sold) 1964 C-10 panel (project complete frame up build) 1957 210 post pearl orange |
11-19-2012, 01:13 PM | #128 |
WOW, this truck is soooo sweet.
Something like this C-30 will be my next project.
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
11-19-2012, 01:17 PM | #129 |
one of the nicer trucks i have seen that still looks like it is being used as a truck !
11-19-2012, 11:42 PM | #130 |
This is probably my favorite truck on this site. Everything about it looks so right. Just awesome.
11-20-2012, 12:34 AM | #131 |
But Found Her 25yrs Later!
Yep, it's a winner.
http://67-72chevytrucks.com/vboard/s...d.php?t=550130
12-29-2012, 12:48 AM | #132 |
This is my first post to the threads, but I'm not new to chevy trucks. In fact my Dad taught me how to drive in a 1964 C30 flatbed he converted into his plumbing truck. When we moved to the Oregon coast in 2001, we did so using our '62 c-30 flatbed. 292 straight 6 and four on the floor. Max spped was 65 (Well not safely. the motor was whining at 65) Let just call it 50 mph cruising. Let's face it, Granny doesn't get much use. I was luck enough to find this easy fixer 65 C-20 Stepside converted to a utility bed. She was born at the Freemont assembly plant in the San Francisco Bay area and grew up as a work truck for a man and then his son. I purchased her off Craig's list from the third owner which makes me owner # 4. The original 327 was replaced in 2006 with a used 350 from a 79 k2500. The three on the Tree, is taking a little getting used to, but I'm managing. The mosy luck part is that someone tried to paint her with standard spray paint and although it sucks, It save her from alot of rust. She still has a couple of small holes in the fender and door bottoms, but the sills an floor pan are almost rust free. they may have painted it wrong but at least they painted her.
As far as I have researched, ULITCO aka Utility body of Oakland no longer exists, or may have been bought up. The corporate liscense is inactive and no answer from the Googled phone number.Apparently, the boxes were attached to the existing bed after removal of the fenders. i don't know if the headache rack was added then or later. i just got her the other day and the rain has prevented me from pulling the plywood from the bed to see what's left of the original wood bed. |
12-29-2012, 02:18 AM | #133 |
60-66 Nut
Welcome to the forum
That does look to be in real good condition. Especially considering it was a work truck. I wonder if those boxes were installed when the truck was brand new?
12-29-2012, 10:36 AM | #134 |
nice looking work truck,
12-29-2012, 11:03 AM | #135 |
I will add a few of my old 63 K20 brush truck. I have better ones but can't find them right now.
12-29-2012, 02:02 PM | #136 |
I like how they added these to the existing box by just removing the fenders and bolting these on. I suppose there was some other support added as well.
12-29-2012, 04:15 PM | #137 |
A few I've saved over the last few years.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-29-2012, 05:50 PM | #138 |
Great pictures guys. Factory Photos and all.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan |
12-29-2012, 06:17 PM | #139 | |
12-30-2012, 11:17 AM | #140 |
Maybe this is the truck you drove Check out that big 22 or 23,000lb Eaton rear axle. Also note the bumper design used on extra heavy duty models. A GMC 6500 is in a completely different weight range than a Chevy C 60, it would be closer to a Chevy C 80. Most Chevy and GMC trucks built with this cab design were in the lighter GVW ranges, extra heavy duty versions of these trucks ( 33,000 GVW) had much lower production numbers.
12-30-2012, 12:15 PM | #141 |
Here's some pics of our 64 C30 in action. That's my son driving. Bought this truck in Nebraska from another member of this site. Truck has 40,000 plus miles on it. Was used on the farms for hauling grain I think. We use it primarily for hauling wood. Jon
12-30-2012, 02:12 PM | #142 | |
12-30-2012, 02:16 PM | #143 |
60-66, nice '64 C-30. I had one just like it, although mine didn't dump. One of the best trucks I ever had.
01-01-2013, 01:20 PM | #144 |
Thanks Bill, these are good work trucks. We have used this one in parades also. Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
01-01-2013, 01:20 PM | #145 |
01-01-2013, 01:26 PM | #146 |
Interesting truck, but the year is wrong. Probably a '62 that was bought and Titled in '61. Looks real clean and well kept.
01-11-2013, 09:35 AM | #147 |
Cool thread.
01-11-2013, 01:50 PM | #148 |
Back when VIN's where in thier infancy,engine block numbers were used as well to identify vehicles. My 65 came with a "Protecto Plate" with a number representing the 1965 model year and sales codes. But the Listed VIN on the title. uses the assembly plant serial number with a 1964 VIN code pattern with the same assembly line number.
01-12-2013, 10:14 AM | #149 |
Here is my Work Truck, this 1965 GMC Rescue Squad was in service in Manville NJ up to 2004 with its first owner, Manville First Aid & Rescue Squad.
The Truck is now with its 3rd owner and will be the Mascot for the 6066 GMC Guy website.
Jolly ~ The 6066 GMC Guy Try the 6066 GMC Guy Facebook Page Jolly's Truck & Car Show Page! |
01-12-2013, 12:07 PM | #150 |
Whomever designed that truck, sure had more than utility in mind. It must have looked "Space Age" at the time. Or maybe the cabin of a "Chris Craft"
