Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-16-2017, 10:22 PM   #1
ibbowhunting
hydro blasting? pro and cons
is hydro blasting safe to use on the sheet metal of my 47 3100, is warp age an issue with hydro blasting?
ibbowhunting is offline   Reply With Quote
Old 08-18-2017, 12:36 PM   #2
bs46488
Re: hydro blasting? pro and cons
I had some body parts hydro blasted with no issues.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 08-19-2017, 10:29 AM   #3
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
Damage to sheet metal is NOT Ill repeat NOT related to heat. So if your potential hydro blaster is touting his services will prevent damage, run cause the guy is a fool or a liar.
Warpage is caused by the media acting like thousands upon thousands of little hammers penning the metal stretching it out as they hit the surface. You can take a themo heat gun and the measure the before and after blasting temps can you won't see a darn bit of difference in metal temp. How do you warp metal via heat if the metal never changes temp???
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 08-20-2017, 09:28 PM   #4
ibbowhunting
It wasn't heat I was worried about, really just looking for input if people have tried the process with success, I'm more or less talking about the small hydro blasting kit that can be used at home, if it work ok, I know its alot of work and will take a lot of time but I like the idea of dustless blasting, and there no one in my local area media blasting
Old 08-21-2017, 03:19 PM   #5
theastronaut
theastronaut's Avatar
Make sure to clean out EVERY last square inch while its still wet with a pressure washer. Wet media packs tightly and doesn't come out easily once it's dried. I'd rather use a traditional method as the water/media mix carries more momentum than dry media, so the warping could potentially be much worse.
theastronaut is offline   Reply With Quote
