07-16-2012, 01:55 PM | #26 |
67cheby
Re: Project: Rufus Restoration
Great progress !!
07-16-2012, 02:03 PM | #27 |
At least one pic for finally making it to the 2nd page...
07-16-2012, 02:07 PM | #28 |
Thanks!
Thanks 67cheby. Can't wait to see some paint on that cab of yours! |
07-16-2012, 03:10 PM | #29 |
I don't want 2 sound like a know it all but in pic 7 the spring on the right looks to be a bit short, looks a lot like the new ones I just got and all 4 of mine are 2 short. can't wait 2 see how they look. Your truck is looking good and I like the color
07-16-2012, 04:50 PM | #30 |
I'm assuming that you're referencing post 7 where the 2 springs are sitting side by side on the rear trailing arm. The spring on the left is the stock spring that came on the truck and the spring on the right is a 6" drop spring that came with my ECE 4/6 drop kit. It really helped the looks of things, but I can not attest to how they feel on the road yet. Some day....some day. Thanks for checking things out. I always appreciate some feedback.
07-17-2012, 12:10 AM | #31 |
Collector of Projects
How is the hood clearance? I have the same setup with CaptainFabs bracket and a 2005 GMC hydroboost / MC combo.....
Also, what are you doing for a proportioining valve/block? I picked up a Wilwood adjustable piece because I swapped to rear disc brakes. That MC uses a 7/16x24 fitting and most are 3/8x24. Last edited by mcmlxix; 07-17-2012 at 01:22 AM. |
07-17-2012, 08:29 AM | #32 | |
07-17-2012, 09:17 AM | #33 |
www.Kore3.com makes a really nice braided hose that I'll be using. I was thinking that I will probably run them from the proportioning valave to the frame as well to replace the coils in the hard line. It would absorb any amount of chassis flex and look cleaner. Still trying to figure out the specifics. AutoZone had a 3/16 hard line with the correct end on each side to go from the MC to the Wilwood valve....
Here is a link to some good brake tech ....CLICK HERE |
07-17-2012, 11:25 AM | #34 | |
07-17-2012, 05:13 PM | #35 |
My power steering hoses were hacked off. I ended up buying -6 AN fitting for the HB and steering box. I'll have a local hose place make some AN hoses when I get to that point....
07-25-2012, 08:45 AM | #36 |
No real progress lately, as things have been a little hectic. However, my soon to be grandmother-in-law, has temporarily handed me the keys to her 54 F*rd truck to cruise around in for our upcoming wedding. I know it's not a Chevy, but it does give me some motivation to get kicking on my own project and get it back on the road. Plus, anytime you can put some miles on a classic, it's a good day.
07-25-2012, 09:54 AM | #37 |
Sweet...just keep the small projects going and eventually it will be done....
True |
07-26-2012, 01:21 PM | #38 |
Thanks! Still plugging away at it. Thanks for checking in.
07-26-2012, 02:53 PM | #39 |
nice lookin F*rd. May not be a GMC but I think I would drive it anyway, once in a while
07-26-2012, 10:21 PM | #40 |
Like your project. Four eyes rule!
Eddie |
07-27-2012, 12:16 AM | #41 |
VA72C10
Great looking project!!!
Looking for a 67-72 swb or blazer project in or around VA. |
07-27-2012, 06:45 AM | #42 |
Amazed Member
Looks Great, I'm subscribed...
71 LWB Fleetside 1950 3100 Original Project! |
08-01-2012, 03:49 PM | #43 | |
Thanks! Thanks! Thanks! I'm hoping for more frequent updates in the next few weeks. |
09-24-2012, 01:01 PM | #44 |
So it's been ages since I've posted any real progress. This past week I've dove head first back into my LS engine wiring harness. With any luck, I hope to have it wrapped up by the end of the week, and ready for a test fit on Saturday. I'll post some pictures soon.
09-24-2012, 10:04 PM | #45 |
Man your project is looking great! We will be having a swap meet in Nashville soon if you would like to come.. here is the link for the info..
http://67-72chevytrucks.com/vboard/s...d.php?t=541395
-Rus |
09-25-2012, 04:35 PM | #46 | |
09-25-2012, 09:02 PM | #47 |
Yes sir! Hope you can make it!
-Rus |
10-01-2012, 07:57 PM | #48 |
Update!
I've finally been able to squeeze in a little time with the old girl again. The past week or so I've been back into the wiring. I have my wires ready to start creating a fuse box, and recently laid them out on an old 5.3 I have lying around to see how things are going to fit. Unfortunately I forgot to snap a picture of that. Also had a chance to stick on new calipers and pads and mount some new tabs for the brake hoses. And finally, I followed along with Hart_Rod's mounting of the gas pedal and created a bracket to mount it up. My brake pedal needs to be bent over slightly, but I think it fits under there pretty well. Last edited by shearjs; 10-09-2012 at 08:20 PM. |
10-01-2012, 08:13 PM | #49 |
Is that a 'drive by wire' throttle assembly?
10-02-2012, 03:20 AM | #50 |
Yes. look close and yo uwill see the connector on top... This looks like where mine will be as well....
