04-09-2017, 06:36 AM | #1 |
PCM questions
Working on a 5.3 truck engine that has had a ls1 intake and injectors and shorty headers thrown on it. The last ls swap I done was just a pull out 5.3 delete vats and emissions from the pcm and that was it.
On this setup though what exactly will I need to do to get this thing running properly. Do I need a so called mail order tune? Also if so anyone recommend anyone.. TIA |
04-09-2017, 08:54 AM | #2 |
Re: PCM questions
You'll need the ecm reflashed for the setup you'll be running..
04-09-2017, 07:43 PM | #3 | |
meowMEOWmeowMEOW
Re: PCM questions
Otherwise you can do a mailorder tune, get HPT yourself and flash something off the repository, or find a tuner that will do housecalls (they exist, just rare).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-09-2017, 07:50 PM | #4 |
Re: PCM questions
Thanks for the info brew. I'll probably send the pcm off for vats and emissions delete and get it up and running to check for leaks and do a shakedown run...just hate to make a appointment with a tuner and show up and end up with more problems because I haven't even heard it run yet and waste mine and the tuners time chasing small problems that could have already Ben taken care of.
04-10-2017, 12:21 PM | #5 |
Re: PCM questions
I would also ask them to update the tune with the LS1 injector data.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
