Old 10-19-2005, 10:49 PM   #1
Green Machine
Green Machine's Avatar
How hard to add paint divider chrome to cab ?
I may want to add the divider chrome to my 70 and do two tone paint job. Cab did not come with that trim. I have the trim and clips from a donor and my other truck has the trim so I can get measurmennts and spacing, but how would you fasten the clips to the cab ? I thought of pop rivits but they seem to big and could make potential leak and rust spots. Is there a way to weld the little studs like original to the cab ? Any thoughts ?? Thanks
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 10-19-2005, 11:43 PM   #2
weasel29gm
SLOW BUT SURE,BUT CLOSER
Re: How hard to add paint divider chrome to cab ?
Dont' know if this would work, how about 3-M double side tape. I've seen it used on emblems,moulding,side trim etc. Tough stuff!!
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 10-20-2005, 12:22 AM   #3
70C/20CHEV
Yes You Can Have The Little Studs Welded To Cab. My Bodyman Had One Of Those Spot Welding Guns For Welding The Nails To Sheetmetal For Pulling Dents. Used An Adaptor For The Short Nailheads And Just Welded New Nail Heads To Cab And Now Have Cab Divider Chrome.
70C/20CHEV is offline   Reply With Quote
Old 10-20-2005, 12:35 AM   #4
EighthD
EighthD's Avatar
there is a pop rivit that you can use. You just drill a 1/8 inch hole and pop them in and it sticks out so you can slide the plastic clip on it. I used them when I installed the chrome around the back of my cab. And they worked real good.
EighthD is offline   Reply With Quote
Old 10-20-2005, 09:28 AM   #5
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
We have the little screw-in studs for trucks that do not have the welded studs. They are part number 100339. Also have the replacement plastic clips that slide over the "nailhead" stud if you need some. http://www.mar-k.com/Moulding_Clips_install.pdf If you have not painted yet, the best bet is to have the body shop weld replacement studs on. This assures no rust or leaking over time. As mentioned above, just be sure they are they are the right length and in the right position. Fortunately you have a donor cab for a pattern.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 04-19-2018, 01:33 PM   #6
1slowM6
Bringing back an old thread,do you know where I can find those rivets?i can’t find them anywhere
1slowM6 is offline   Reply With Quote
Old 04-19-2018, 10:31 PM   #7
EighthD
EighthD's Avatar
google au ve co products look on their on line catalog page 240 at the bottom. it say its to replace ford weld on studs
Old 04-19-2018, 10:33 PM   #8
EighthD
EighthD's Avatar
I hope this helps you if you cant get them let me know and I will look to see if I have any left some where
Old 04-20-2018, 06:33 AM   #9
Zeroman
Zeroman's Avatar
I went a different route. It was not exactly cheap, but I wanted something different.
I had the trim airbrushed......
Zeroman is offline   Reply With Quote
Old 04-20-2018, 07:52 AM   #10
Hart_Rod
Hart_Rod's Avatar
Mark-K.com sells a kit to install the divider.
Hart_Rod is offline   Reply With Quote
