Old 04-19-2012, 09:01 PM   #1
Chevysdominate
Chevysdominate's Avatar
6000 rpm tach anyone...
I thought I'd share a little project I've been working on. I like the stock tachometers, but the 5000 rpm limit was a killer with a modern engine. So with a little thinking and tearing apart of a few tachometers this is what I've come up with. A 6000 rpm tachometer that looks very similar to the original. It really just bolts in with no fuss at all. I've gone through a few renditions of the gauge face and I'm still working on that. Its hard to find a font that matches the original. As you can see the titanium white paper really puts to shame the old and faded white markings from the cluster. I need to do something about that.
Chevysdominate is offline   Reply With Quote
Old 04-19-2012, 10:33 PM   #2
64shortbox
64shortbox's Avatar
Re: 6000 rpm tach anyone...
Excelent job!! What Tach did you use?
64shortbox is offline   Reply With Quote
Old 04-20-2012, 01:00 AM   #3
70cst
70cst's Avatar
Very impressive
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-20-2012, 02:20 AM   #4
jocko
jocko's Avatar
That looks good! I'm usually hesitant about stuffin individual non-factory gauges into a stock dash - because they often don't seem to "match". But yours matches quite well and the sweep and face size is perfect. Nice job!!
Old 04-20-2012, 09:00 PM   #5
qksilver
Let us in on the secret, what tach? I am trying to update my dash, I have the vacuum gauge already and was looking for a tach.
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 04-20-2012, 11:03 PM   #6
Chevysdominate
The tach is marked as a Super Pro but it's an 8000 rpm tach to start with. The secret is refacing it to 6000 rpm while retaining the same 90 degree sweep. Then running the tach in 4 cylinder mode. I know it sounds weird but the math works out. I was just testing the accuracy against my laptop with OBDWiz and it works great. I think I bought the tach at Carquest but I cant be sure. Ive seen them labeled as other brands too. They're all the same tach except the gauge face is different.
Its the same tach as in this article which was my inspiration, but I didn't really like the execution. I also didn't like the small resolution a 90 degree sweep 8000rpm tach gives. So I thought about it for a bit and realized I could reface it as a 6000 rpm tach and run it in 4 cylinder mode.
I'm not 100% satisfied with the first iteration of the tach so I'll probably make another one this week. I might do a small writeup showing all the things needed to convert the tach to a bolt in install too.
Old 04-21-2012, 07:13 AM   #7
MalibuKasey
Artist
MalibuKasey's Avatar
Please do. Looks good!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 04-21-2012, 08:58 PM   #8
qksilver
yes, please do............accuracy is nice, but for me being close is good enough for what I want.
Thanks,
Steve
Old 04-23-2012, 03:35 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
subscribed
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-25-2012, 02:51 AM   #10
Chevysdominate
I got it installed and love not having a tach on my column anymore. I need to get new set of white guage faces to match the white letters on the tach. Unfortunately my radiator died so that will postpone a second tach build for a week or so.
Old 08-04-2013, 10:31 AM   #11
earl84
Hey, chevysdominate, can you share any more details on how you did this? It looks SO NICE. And I do like your execution of it better than the original article you used as a reference. Would love some more details if you have the time.
Incidentally, that tach is available at Carquest, P/N 81316, $59.99 online.
earl84 is offline   Reply With Quote
Old 08-04-2013, 11:10 AM   #12
jesseo
jesseo's Avatar
Very nice. I am going to carquest today to pick one up. I am in the copy and print business and will play with fonts, paper types and font colors to see if I can't get something that works. I've been wanting to do this for a while. I sell decal materials that will work great for these. Need to get the font and color right to reproduce now.
jesseo is offline   Reply With Quote
Old 08-04-2013, 11:40 AM   #13
chevyrestoguy
chevyrestoguy's Avatar
Here's a gauge overlay that closely matches the original font. You could probably email the seller and see if he makes that gauge with the correct green font. Shouldn't be a problem at all.
http://www.ebay.com/itm/Premium-Dash...f7d98d&vxp=mtr
Is there any way you could do a step-by-step on how you did this mod? I have been doing a lot of research on using an older Sun tach and modifying it to fit, but like you, I wanted a more realistic RPM range.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-04-2013, 01:23 PM   #14
LostMy65
LostMy65's Avatar
I surely want to do this mod.
I also want to do the one where a voltmeter replaces the ammeter.
Old 08-04-2013, 02:02 PM   #15
jayoldschool
Moderator
Jesseo, can you share the image with us when you're done so we can print it ourselves?
Also, why the 2" version? Is the 3.5" too big?
jayoldschool is offline   Reply With Quote
Old 08-04-2013, 02:47 PM   #16
earl84
Lostmy65, here's a link (hope it shows up right) for replacing the ammeter with a voltmeter. I have my dash apart and have done this, but mine doesn't look as neat as this one.
http://67-72chevytrucks.com/vboard/s...ltmeter&page=2
Old 08-06-2013, 12:42 AM   #17
Chevysdominate
Its been a while and i never got around to doing the second one. I've been busy stuffing an lq4 into a series 1 1973 jaguar xj12.
i wish i had taken more pictures but i was just flying by the seat of my pants when i made it. I'll document the next build much better.
You basically remove everything from the 8000 rpm tach and you are left with what looks like it belongs in a clock. The spacing on the studs is close but you need to drill new holes for the gauge face to bolt to the studs of the tach mechanism. I'll try to aid as much as i can if you have any specific questions.
Old 08-06-2013, 12:47 AM   #18
Chevysdominate
I would be very interested in a good gauge face that matched the original better. The different font and color are something that still bugs me.
Old 08-06-2013, 10:56 PM   #19
MARTYZ
MARTYZ's Avatar
Subscribed, very interested
MARTYZ is offline   Reply With Quote
Old 08-09-2013, 10:10 AM   #20
earl84
So what did you print the gauge face on? Some kind of adhesive backed vinyl or did you have to go to a print shop or something? If you printed it, where did you get the black paper/vinyl/whatever it is?
Old 08-09-2013, 12:30 PM   #21
theastronaut
theastronaut's Avatar
Thanks for posting this, I wanted a tach that went to 10k and looked stock but didn't know how to do it... so I paid to have one made. I like to do stuff myself though so this is good info for the next project!
Here's mine, Jason at Greenback Decal built it from a block-off plate.
theastronaut is offline   Reply With Quote
Old 08-09-2013, 01:08 PM   #22
1963c-10
1963c-10's Avatar
astronaut....what tach did you use? I have an extra delete plate and his contact info, so that aspect is easy. Do you have a thread on the 10k tach build?
1964 Short bed trailer
Old 08-09-2013, 03:31 PM   #23
theastronaut
I don't, I didn't build it. I sent him the blank plate and he did everything else except for the shift pointers, I had those leftover from an original tach.
Old 08-10-2013, 07:28 PM   #24
LostMy65
LostMy65's Avatar
Summit has a couple choices with a 90 degree sweep
http://www.summitracing.com/parts/sun-fz88r
http://www.summitracing.com/parts/atm-2897
Old 08-10-2013, 08:32 PM   #25
Rich 5150 69
Rich 5150 69's Avatar
Hmmm...! 10k tach...heck of a motor to make 10 without self destruct..
What we really need is to have a 120 speedometer....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
