07-13-2018, 10:09 PM | #1 |
4L80e drops out of drive to D3
I am using a stock auto column from 67-72 with the Lokar rod shift linkage on my 6.0/4L80e. Whenever I get on the gas, the engine torques enough in the mounts drop the trans out of drive into d3 and I have to shift it back to drive after I let up on the gas. Advice on how I can fix this? Anyone else dealt with this?
07-14-2018, 10:14 AM | #2 |
Re: 4L80e drops out of drive to D3
Change to Locar cable??
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-14-2018, 12:15 PM | #3 |
07-14-2018, 04:10 PM | #4 |
Good grief, what kind d of motor mounts are you using???? Sounds like what happens when one is broken. You could always use a cable to tie the engine down I guess...
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-14-2018, 05:28 PM | #5 |
i was going to say sound like u have a broken mount , on my 71 i have the stock linkage and and motor mounting and mine doesnt flex at all
07-14-2018, 06:26 PM | #6 |
Engine mounts are fine, they are CPP. The trans is mounted to a CPP crossmember. All bolts are properly torqued.
Motor may not be torquing much at all, in neutral it doesn't move a millimeter. The shifter moves very easily (had the pan open recently to change the internal harness and no, the internal detent mechanism isn't broken or bent either) and since I"m using a stock column, the detents on the column don't quite match up (when in Drive, the gear indicator shows between N and D) and the stock shift lever is heavy. If I support the shift lever while accelerating this doesn't happen. Could just be the weight of the shifter and some slight movement (remember, motor mounts and trans mounts have some rubber in them) that is enough to move the shifter. So please, save the grief for someone who died. I'll call Lokar and ask them what they recommend. |
07-15-2018, 11:15 AM | #7 |
My suburban will pop out of reverse when backing up tye camper trailer. I am thinking a cable or stock type shifter is the answer.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
07-15-2018, 01:12 PM | #8 |
07-17-2018, 09:44 AM | #9 |
Sounds like it just needs some adjustment...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-17-2018, 09:58 AM | #10 |
07-26-2018, 02:30 PM | #11 |
Just to report back and close this thread out - I followed Lokar's recommendations and adjusted the rod with both the trans and the shifter in D. Problem disappeared. Truck stays in Drive no matter how hard I get on it.
