Old 05-06-2012, 11:21 PM   #51
junkmen
junkmen's Avatar
Re: Rebuilding Vent Windows, How To...
thanks I'm going to bookmark this thread i have to do this when i reassemble my doors
junkmen is offline   Reply With Quote
Old 07-09-2012, 08:57 PM   #52
x ReAcT x
Great job. Definitely going to bookmark this
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 07-09-2012, 10:20 PM   #53
primrrd
primrrd's Avatar
excellent write up. Thanks for your time and for sharing the steps!
primrrd is offline   Reply With Quote
Old 07-10-2012, 01:09 AM   #54
Gordonr1973
Home Built '87
Gordonr1973's Avatar
x2
Needs to be a FAQ.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 07-10-2012, 04:19 PM   #55
Project82
Bretzke Racing Inc.
Project82's Avatar
Very nice info on this part of our trucks! i replaced my vent window seals about 2 years ago and i probably should've left the original vent window seals in because now with the windows all shut, it sounds like i'm missing an entire window lol. very LOUD wind noise. but im wondering if the seals i bought were right to begin with, i mean they fit but were not exactly the same. my windows are '82 model (2-piece weatherstrip), so i ordered the seal from LMC and they sent me 1-piece design seals??? i thought maybe they re-designed the seals to fit better than the 2-piece seals? so i installed them as-is, but i skipped out on buying some weatherstrip adhesive....so anyway im going to have tackle this project again, plus i have a couple spots to touch up paint too.
Just wanted to know how the reassembly process went with the rivets and the tool you ordered???
thanks, Kris
1982 Chevy Silverado C-10 RCLWB - IN PAINT - Inferno Orange Metallic
Lowered 4.5/6 - 358 SBC 10.5:1, Comp XE268H cam, Aluminum heads, 650 Double pumper Holley carb, 2400 Holeshot Converter, upgraded T/h350 Trans. Stock Rear end for now (3.08 gear)
2004 Chevy Silverado 1500 LS RCSWB - Dark Spiral Gray Metallic
Lowered 2/4 - 4.8L V8 4L60E 10-bolt. some goodies --- NEW DD 11/9/12
"Expect the Un-expected"
"Gas, Grass, Or Ass...No one rides for FREE!"
Project82 is offline   Reply With Quote
Old 07-10-2012, 04:56 PM   #56
JCampbell
Any re-assembly photos?
JCampbell is offline   Reply With Quote
Old 07-19-2012, 11:19 AM   #57
Precision Parts
Tech Help
Precision Parts's Avatar
thanks, Kris
The 81-85 were typically 2 piece style and unique to your assembly. That one piece does not fit snug so it's no wonder you're getting some wind noise. You can not use the 73-80 either as they will be slightly different.
The 2 piece style have been hard to get a hold off but I will have some coming in a few days.
-d
PRECISION
Updates
Subscribe --->Installation Videos
Follow ------->Instagram
Like---------->Facebook
Precision Parts is offline   Reply With Quote
Old 07-19-2012, 01:37 PM   #58
McSwine
McSwine's Avatar
-d
Would you mind shooting me a PM or replying to this thread when you get them? I'm like that other guy...my truck sounds like a 747 taking off.
McSwine is offline   Reply With Quote
Old 07-19-2012, 01:44 PM   #59
Precision Parts
Tech Help
I'll shoot you a PM
-d
PRECISION
Updates
Old 07-19-2012, 02:19 PM   #60
faribran
thank you for taking the time to do this tutorial...well done.
faribran is offline   Reply With Quote
Old 07-19-2012, 02:25 PM   #61
faribran
oops. duplicate post
Old 07-19-2012, 02:53 PM   #62
boatpuller
boatpuller's Avatar
Nice job,real informative.....Iv'e been needing to do this for a long time.But,i keep talking myself out of it.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 09-04-2012, 11:20 AM   #63
jhart625
Thanks for the write up. I just did my vent windows. I will say the hardest part was definitely getting the weatherstripping on the vent windows. Vaseline can be your best friend in the right spot and your worst enemy if there is any on the outside or if you don't immediately wipe your hands after putting it on the groove. Also i learned the weatherstripping glue comes out black but dries white, and did not hold very well. i would recommend getting another product instead.
Also i figured since i had everything apart i would install the keyless lock/unlock remote that LMC sells for like $60. I highly do not recommend it. Took a bunch of modifications and was just a pain in the *** the whole time.
jhart625 is offline   Reply With Quote
Old 09-06-2012, 10:57 AM   #64
Precision Parts
Tech Help
Whenever I've done test installs with our product I've always used silicone spray and a plastic weatherstrip stick.
http://precisionrestorationparts.com.../F32237082.jpg
The stick helps work in the rubber without piercing it.
By the way, the post seal rivets on the division bar and the main seal presses into the channel. There should be no reason to use weatherstrip glue on any of this weatherstrip.
-d
PRECISION
Updates
Old 09-06-2012, 12:22 PM   #65
JCampbell
Precision - I think my Pop's just bought some stuff off you. His name is Steve. He’s down in Vancouver, WA. Says he was real happy with your products…especially after dealing with the crap LMC sent him.
I just picked up a shortbed that I’m going through. I’ll be in touch.
Old 09-06-2012, 12:41 PM   #66
Precision Parts
Tech Help
Yep, I remember Steve, real nice guy and said the 81-85 2 piece vent weatherstrip worked well. Glad I could help with the correct product!
-d
PRECISION
Updates
Old 01-05-2020, 12:24 PM   #67
Hart_Rod
Hart_Rod's Avatar
Bump
Hart_Rod is offline   Reply With Quote
Old 11-24-2023, 01:17 AM   #68
Getter-Done
Getter-Done's Avatar
This needs Another Bump.
84 Chevy K-20
