02-24-2018, 12:18 AM | #151 |
Re: NJ Suburban
Soon
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
02-24-2018, 08:28 AM | #152 |
Equal opportunity joke ofender
Re: NJ Suburban
Nice looking work so far Paul.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-24-2018, 11:03 PM | #153 |
Re: NJ Suburban
X2
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-30-2018, 07:35 AM | #154 |
DND Trucks
Re: NJ Suburban
Great work! Any updates
03-30-2018, 09:08 AM | #155 |
Coordinator of Synchronicity
Re: NJ Suburban
You're making great progress. Great job
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be |
04-04-2018, 09:04 PM | #156 |
Re: NJ Suburban
Almost all done with the left side. Not completely happy with the bead in the wheel lip but I'll work on that later. The entire side is painted with Omni primer then coated with Nasco 2K. Tomorrow I'll spin her around and start working on the right side!
Paul
04-05-2018, 06:49 AM | #157 |
Re: NJ Suburban
Looking good Paul.
04-11-2018, 09:50 AM | #158 |
Re: NJ Suburban
Nice progress
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-18-2018, 09:58 PM | #159 |
Re: NJ Suburban
Been making some progress. The drivers rocker is removed and I'm trying to sandblast the rusty inner front door jamb area before paint. Kind of a pain to do inside in the garage. I've set up plastic all around the area and sealed it off with masking tape. Dust is still flying all over the place! The replacement patch panel for in front of the rear wheel opening is in and primed!
Paul
05-19-2018, 02:46 PM | #160 |
Re: NJ Suburban
I hate sandblasting! With all the plastic taped in place and two exhaust fans (one with a furnace filter on it) and there is very little fine dust in the garage.
Paul
05-19-2018, 03:55 PM | #161 | |
Re: NJ Suburban
jz
06-03-2018, 08:44 AM | #162 |
DND Trucks
Re: NJ Suburban
Looking good man! Did you have any rust in the rear wheel arches? From what I know that area seems like it would be hard to repair. I thought someone took a truck 8' bed side and made it work.
06-18-2018, 07:20 PM | #163 | |
Re: NJ Suburban
They make a patch panel. Only problem is that the bead doesn't quite match the original. Paul
06-20-2018, 10:37 AM | #164 |
DND Trucks
Re: NJ Suburban
Was thinking of starting a build thread with my burban. However both 1/4s are junk and trying to decide if it's worth the effort to repair it or change out the body.
08-01-2018, 08:52 PM | #165 |
Re: NJ Suburban
And I'm back in the saddle again! Great to be back at welding!
Paul
08-04-2018, 05:45 AM | #166 |
Re: NJ Suburban
Great read! Nice work and progress Looking forward to future updates
09-09-2018, 09:23 PM | #167 |
Re: NJ Suburban
I'm trying to fit the left lower panel and having trouble. Anyone else done this?
It fits fine in the wheel arch and along the bottom but the long part along the top is bowed way out! Paul
09-09-2018, 10:02 PM | #168 |
DND Trucks
Re: NJ Suburban
Man, your really doing great considering what's involved with replacing 1/4s on a burban! Keep up the great work.
09-10-2018, 09:33 AM | #169 |
Re: NJ Suburban
What happens when you unclamp the lower pinch weld clamps? Does it pull back where it should be?
09-10-2018, 12:11 PM | #170 | |
Paul Posted via Mobile Device |
09-10-2018, 12:37 PM | #171 | |
Re: NJ Suburban
Richard
09-10-2018, 03:31 PM | #172 | |
Re: NJ Suburban
09-10-2018, 03:46 PM | #173 |
Re: NJ Suburban
Paul is my hero!
I started out with nothing - and I still have most of it |
09-10-2018, 04:23 PM | #174 |
Re: NJ Suburban
Paul
This is the bend I am talking about. If it is over bent and you clamp it, it will bow the top out. If you unclamp it and the top comes back in to where it should be, I would try gently massaging the lower bend, but it needs to be done before you start welding. It may take numerous tries. Richard
09-10-2018, 07:25 PM | #175 | |
Re: NJ Suburban
Thanks Richard I'll try that. Paul
