Old 03-16-2012, 06:23 PM   #4052
Strodder
Daring to be Different
Strodder's Avatar
Re: Project Vitamin C-10
The rods were still good. It had too much boost.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-16-2012, 06:27 PM   #4053
padresag
sometimes there is perhaps a little to much fuel and it doesn't just all jive at the same time, boom
ron
padresag is offline   Reply With Quote
Old 03-16-2012, 08:04 PM   #4054
Strodder
Strodder's Avatar
Those engines are like a Controlled BOMB!!
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-17-2012, 12:19 AM   #4055
shrunken66stroker
shrunken66stroker's Avatar
Most of the time something breaks in the valvetrain and an intake valve gets stuck open, fills the cylinder full of fuel and bang. Could also have been too much pressure. Alan is about 7600 short of the horsepower the top fuelers are making but should still check it out.
shrunken66stroker is offline   Reply With Quote
Old 03-20-2012, 11:58 PM   #4056
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by hemifalcon View Post
...I'm by far an expert in the matter or methods of diagnosing engine issues.. But, that definitely has that "hollow" sound that you mention which sould not be indicative of anything in the valvetrain.. I think you should just pop the oil pan off and see what's going on..
I wish it was that easy to pop the oil pan off. I have to raise the engine up at least 2 inches.
Originally Posted by chad64chevy View Post
alan, i was thinking that it might be something in the oil pan, but i dont know what kind of oil pan you are using! if its a stock oil pan then its going to rub, the stroke on a 400 is different then a 350
Yeah I clearanced the oil pan for that. At least I thought I had it good enough, but don't remeber rechecking it after I bolted it down.
Originally Posted by padresag View Post
I would chk the flex plate for cracks first as that is a lot simpler than pulling the pan and finding nothing wrong there and then find it was the flex plate
ron
I looked at it and didn't see anything that looked like a crack.
Originally Posted by cjracing15 View Post
Eaxust looks awesome! It's hard to tell from the video bu, that does not sound like a loose rod or main. That does sound like something is hitting something low. Sorry u haveing this trouble. But I think it's going to be easy to fix once u find the noise. Good luck man.
Thanks for the comments.
Originally Posted by McMurphy View Post
Alan if you shoot me a PM with a good mailing address I will send you an old sthescope. People rotate thru Military hospitals every 6 months, new in-old out and providers tend to leave things like these behind so I have quite a few of them.
I use it every once in a while with a long metal rod just to "listen in" on my engines.
If you would like I will shoot one off to ya.
thanks!! I might take you up on that.
Originally Posted by awbrown View Post
Alan , I diagnose that stuff all the time and a 3 ft piece of hose heald to the ear and touching the areas that you think the sound is coming from will tell you real quick where it is coming from .. also a handy way to find loose rockers ... but if it is hitting the pan or the baffle you should be able feel it with your hand on the pan... good luck my friend ,I have been through that before...
I'll give that a shot, never tried a hose before. Thanks
Haven't been able to fool with it. Most of the reason is no time, but some of it is I don't want to. Kind of disheartening. I'll power thru it.
has anyone use this type of oil pan gasket? My block falls into the year range for this gasket, but I read tonight it is for a thin front gasket, and I believe I have a thick one I'm not really sure. I thought it might be easier to deal with under the trruck.
Alan's Classic is offline   Reply With Quote
Old 03-21-2012, 07:59 AM   #4057
jimmythompson1964
jimmythompson1964's Avatar
I had a stock pan on my 383 and did the same thing, my friend just finished the motor in his 84 put a stock pan on it and the same noise. I am sure you will leave no stone unturned to find both issues power and noise and then burn up some asphalt
jimmythompson1964 is offline   Reply With Quote
Old 03-22-2012, 11:43 PM   #4058
Alan's Classic
OK, the pan gasket above had the thin front gasket and I didn't use it. i went with the standard cork.
Dropped the pan last night and found where it was rubbing. Massaged it a little and with Shannon's help we got the pan installed tonight.
The rubbed place is the shinny spot between the 2 reliefs.
Old 03-23-2012, 10:35 AM   #4059
66BowTieBoy
66BowTieBoy's Avatar
Hey Alan,
Glad to see your C.S.I. skills solved the mystery, but I never doubted you for a second.
Looking forward to the next tire smoke'n video.
You are an inspiration....!
Danny
HAPPINESS IS A COLD BEER, A SATELLITE DISH & QUALITY TIME WITH MY DOG....!
66BowTieBoy is offline   Reply With Quote
Old 03-23-2012, 10:42 AM   #4060
jimmythompson1964
I put a small block 400 pan on my friends motor and fixed the problem just ordered one from Summit. Glad you found the problem you have to be breathing a little easier and sleeping better
Old 03-24-2012, 02:20 PM   #4061
Alan's Classic
Originally Posted by 66BowTieBoy View Post
Hey Alan,
Danny
Jimmy, I'm a little slow sometimes. I actually thought of that when I took the pan off and checked Jegs for a 400 pan and couldn't find one. I should have thought about it when I ordered this pan 2 years ago. Anyway problem is fixed. Thanks for the input.
Got everything buttoned up this morning and was jonesin' to drive around town. I made a 7 miles round trip. Stopped at the gas station to try the pump to see if I got any splash back. Tried full blast and the pump justed stopped. It filled pretty good when I throttled it just below full blast. Then to church for work day.
It was funny watching people as I went by. Alot of pointing and lookin'.
Old 03-24-2012, 03:04 PM   #4062
scotts62
One day...
scotts62's Avatar
Very good looking truck Alan!! I bet the feeling is great driving it finally!!
Scott
93 crew cab build
Project 62
Old 03-24-2012, 03:11 PM   #4063
likaroc13
Rollin' Old Skool
gotta love that feeling!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 03-24-2012, 03:34 PM   #4064
pdxhall
pdxhall's Avatar
It's great to see your truck on the street. I've been following since I found this site and your build has given me inspiration more than once to keep going. I knew when I started mine that it would be a long process and seeing your accomplishments helps my motivation.
pdxhall is offline   Reply With Quote
Old 03-24-2012, 04:15 PM   #4065
FetchMeAPepsi
FetchMeAPepsi's Avatar
Same here PDXHall. I've been reading this thread since I joined and it's kind of a "you can do it!" to see him behind the wheel and toodling around town after all the hard work.
Congrats Alan!
When do you want me to drop off mine? Don't want you getting out of practice now
FetchMeAPepsi is offline   Reply With Quote
Old 03-24-2012, 06:00 PM   #4066
flips72
flips72's Avatar
congradulations alan, extremely happy for you, cant wait to see it in person.
flips72 is offline   Reply With Quote
Old 03-24-2012, 08:32 PM   #4067
Strodder
Strodder's Avatar
Lookin great Alan. Glad your using good gas.
Now everywhere you go you'll be answering questions about your truck. You won't be able to even go to the grocery store without someone stopping you to talk.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-24-2012, 09:18 PM   #4068
66ChevyMax
66ChevyMax's Avatar
Labor of love that you will be telling people about for many years to come. Congrats
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 03-24-2012, 09:26 PM   #4069
LEEVON
LEEVON's Avatar
Alan, the truck looks great (my favorite color). I've enjoyed your build thread over the last couple of years. Hope you get lots of windshield time!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-24-2012, 09:50 PM   #4070
Alan's Classic
Yes, it is Scott. The smile gets bigger every time. BTW, thanks
Thanks for bearing with me during this process. This build will be around for a long time. I say that because, I still have a lot to do.
Congrats Alan!
Thanks, man. i can't wait to see yours as well.
I answer a bunch of questions today. It won't be going to a grocery store unless there is a show in the parking lot.
Thanks, and I hope so. Just wish I went with an LS. Your ride will be and already is a conversational piece.
Me TOO!!
I forgot to mention this.
At the muffler shop I had an old geezer tell me I had my bumpers on upside down. I said no and he disagreed saying he just sold a 66 that was all original and his bumpers were right. I just said ok and went on.
Still insearch of a steering wheel. The 15" 59 Impala whell i wanted is $360. i can't do that right now. I found others styles cheaper, but undecided on what would look good for $150, suggestions..........
Old 03-24-2012, 10:19 PM   #4071
XtechX
XtechX's Avatar
Really cool Alan, Glad to see you have it on the road!!! I'm about to get mine on the road too, bolt the seats down, final timing, and alignment and "Hear.. We.. Go!"
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 03-24-2012, 11:10 PM   #4072
allaboutchevelles
allaboutchevelles's Avatar
Hey Alan, Your truck looks so good sitting at the pump, You have done an excellant job on it. Will you be coming or possibly driving your truck to the Charlotte auto fair april 24th weekend??? Me and flips are going to meet up there on saturday. I would LOVE to see your truck in person!!
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 03-25-2012, 12:46 AM   #4073
Woogeroo
Woo hoo back on the road and at the gas station, congrats AC !
-W
Woogeroo is offline   Reply With Quote
Old 03-25-2012, 08:05 AM   #4074
duallyjams
duallyjams's Avatar
That's a really good stance , looks good with the tinted glass, can't wait see it with the hood on it.Bet that was a fun 7 mile ride.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-25-2012, 08:12 AM   #4075
Running Trucks
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
