09-30-2016, 07:34 PM | #26 |
Re: Wilwood C10 Drop Spindles
I seen on Wilwood web site there 755 dollors I hope I can find them cheaper and would like to no how much they weigh
10-01-2016, 02:45 AM | #27 |
i picked up these new spindles today, the unit bearing as its called is pretty heavy
the other parts are cast or forged alum. they came black as you see them i just had them sitting on the painting table. will post more when i get them on my truck...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
10-01-2016, 06:11 AM | #28 |
motor exploder
Care to share where you picked those up from?
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
10-04-2016, 10:15 PM | #29 |
Can you let us know what the weight difference is between these and the stock spindles? The closest to an apples to apples comparison would probably be spindle, hub and rotor. thanks.
I can still count my vehicles on two... wait three hands. |
10-09-2016, 10:35 PM | #30 |
Are they the same height as the stock spindles or are they a tall design to improve camber and roll center?
10-10-2016, 07:36 PM | #31 |
Also, do these have the same caliper mounting points as the CPP modular spindles? I would love to use these in combination with a big brake kit that is not wilwood.
10-10-2016, 07:57 PM | #32 |
10-10-2016, 07:59 PM | #33 |
From my understanding from reading and what the kid told me from Wilwood. These will only work with the Wilwood big break kit.
10-11-2016, 07:31 PM | #34 |
Ahh that sucks. I would love to use these with some 6 piston CTSV brembos.
10-24-2016, 07:45 AM | #35 |
10-24-2016, 08:27 PM | #36 |
motor exploder
Pretty sure they use the stock dimensions. This is from Wilwood's website.
10-25-2016, 09:38 PM | #37 |
I used .500" taller upper ball joints from QA1 to help with camber gain. Details and camber gain measurements are on page 27 of my "Goldilocks" build thread. Depending on the amount of weight loss I may be trading in my CPP spindles for these if I can make my 2nd gen CTS-V brakes work on them. I still needed caliper brackets for the CPP spindles anyway, and I already have the late style ball joints so these will bolt straight on.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
10-25-2016, 10:03 PM | #38 |
Can someone post the weight of the new spindles and hubs?
I have weighed both stock-style 12" disc brake spindles/rotors/calipers, and my CPP Modular spindles/hubs and 2nd gen CTS-V rotors/calipers for comparison. As you can see, the StopTech rotors are very heavy, so I'll probably end up using something lighter. The factory dual-cast rotors are lighter but GM recommends replacing them every pad change so they won't last long on a truck built for the track. I thought the StopTech rotors would last longer. 12" Stock-Style Disc Conversion Parts:
Total assembly- 65 Pounds 3.7 oz, each side. CPP Modular Spindles, CPP forged hubs, 2nd gen CTS-V Calipers, and StopTech slotted iron rotors- 2nd gen CTS-V fitment:
Total- 60 pounds 5.8 oz
11-02-2016, 11:52 AM | #39 |
We have been waiting for these to be released for a while now! They are finally out and we will be posting a special Forum price in the vendor section. Drop me a PM if anyone here is interested in a set.
MCB PARTS
MCB - Matt's Classic Bowties 5360 Gateway Plaza Dr. Benicia, Ca. 94510 925-828-5555 www.mcbparts.com Email: forums@mcbparts.com Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts Hours: Monday to Friday 8am - 4pm Pacific We ALWAYS enjoy talking to our customers! We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking! |
08-31-2019, 10:17 PM | #40 |
This thread is a few years old but has anyone made a bracket to bolt c5/c6 calipers to the pro spindle? I see wilwood sells a lot of brackets but I am not sure if any will work.
https://www.wilwood.com/hardware/bracket
Jesse 72 4x4 Sold 59 GMC air ride ls swap |
09-01-2019, 12:36 AM | #41 |
BMW & ASE Master Certified
That bracket is for a totally different caliper type.
You might not be able to with the spacing of the mounting points of both caliper and spindle. Look in my build thread I used those spindles on some 2018 Silverado calipers. Pretty much same as the nnbs with 13" rotors. Custom designed spacers and bracket to fit the rotor which was the be best option for my 17" Only decent progress pic in MDF Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
11-14-2019, 06:45 PM | #42 |
It looks like they turned out good, I was hoping to find an easy adaptor to throw a set of vette or newer camaro brembo calipers on them.
11-14-2019, 11:08 PM | #43 | |
Clint
01-10-2020, 08:39 PM | #44 |
This is an old thread but i stumbled across this new CPP X10 spindle. Similar to the wilwood but i believe it will accept stock C5 brakes and rotors on page 8.
https://www.classicperform.com/Catal...ct-Section.pdf
01-11-2020, 01:29 PM | #45 | |
I find it annoying (typical of CPP) that you can't purchase the "X10" spindles & hubs only. You get to pay for a kit w/the extra 'value' of the included BJ's, TRE's, & TRE sleeves that usually aren't top tier quality of parts.
01-12-2020, 10:23 AM | #46 | |
I am sure the reason they sell it this way is because they did not want to have to build 3 different variants of this spindle and have to deal with the inevitable problem of mismatched ball joints and tie rod problems that people constantly have with the 63-89 trucks. In this instance one package should cover this wide range of years. If anyone was going to run the Wilwood spindle on their 67 they would have to change all of these components anyway. So it does make sense for CPP to package them this way. Posted via Mobile Device |
01-12-2020, 12:09 PM | #47 | |
01-14-2020, 12:55 AM | #48 |
Nice to have options
02-09-2021, 04:40 PM | #49 |
So an earlier post said 18lbs for the modular cpp spindle and the forged hub at 5lbs. I would like to get rid of some un-sprung weight my self. I have the Modular drop spindle and a wilwood big brake kit. Sure would be nice to know if the Pro spindle with bearing and hub weighed any less.
The sight says 43lbs shipping weight but I would think that would include the box or what every they ship it in. If there is only 3lbs different per side its hard to justify the extra dough. |
