05-01-2018, 02:52 AM | #1 |
Junior Member
Budget progressive front spring?
Can anyone point me to a good value on a pair of PROGRESSIVE front springs for our trucks? I have a 73 and looking for a 2" drop. I cut a coil out of my originals and they are too bouncy. Yes I have new shocks. Maybe we don't have any good choices as I haven't found one. I'd like to stay close to $100 for the pair.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Gold White Fleetsides/Saddle |
05-01-2018, 10:41 AM | #2 |
Re: Budget progressive front spring?
What 'stock' spring? What 'new' shock?
Cutting 1-coil will not alter spring rate significantly. It's usually about 10-20% increase in spring rate & most stock springs aren't very high. What are your travel dimensions vs. your shocks dimensions?
05-03-2018, 12:44 PM | #3 |
Junior Member
Just looking for progressive springs.
05-03-2018, 01:34 PM | #4 |
Hotchkis
"Budget" manufacturers won't list spring rates; they usually just advertise how much drop the springs should yield. I can't ever remember seeing an aftermarket/drop/progressive rate spring for the front of C10's. Was the truck 'bouncy' before you cut the coil off?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-03-2018 at 01:39 PM. |
05-11-2018, 05:16 PM | #5 |
Did you cut the bump stops/brackets off?
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
