Old 06-09-2018, 07:34 PM   #1
NC_John
NC_John's Avatar
Vintage Air Compressor Connector Wiring - HELP!
Found out today that Vintage Air send me the wrong male plug to hook up and into the sanden AC Compressor clutch wiring connector. Does anyone know where I can get the other side of it? I might drop them a line but if I can get one easily enough I will. A google search wasn't productive in finding the other half of the connector.
thanks
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 06-09-2018, 08:36 PM   #2
sprint_9
sprint_9's Avatar
Re: Vintage Air Compressor Connector Wiring - HELP!
Looks like a weather pack single pin, 12010996
I like this page for info on them, http://whiteproducts.com/index.shtml
sprint_9 is offline   Reply With Quote
Old 06-10-2018, 06:24 AM   #3
NC_John
NC_John's Avatar
Originally Posted by sprint_9 View Post
Looks like a weather pack signal pin, 12010996
Yessir, looks like the one I need. Now I have to see where I can easily just buy one.
1970 C-10 LWB "Blu"
Old 06-10-2018, 08:41 AM   #4
Smitty
Smitty's Avatar
Call Vintage air customer service. They'll no doubt have one in t he mail the same day. Faster than chasing around trying to find the correct one.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is online now   Reply With Quote
Old 06-10-2018, 01:08 PM   #5
NC_John
NC_John's Avatar
Looks like I can one locally at the race shop where I get my other electrical stuff. VA might send me one but it might not be worth the hassle to get it from them.
1970 C-10 LWB "Blu"
Old 06-10-2018, 01:23 PM   #6
NC_John
NC_John's Avatar
1970 C-10 LWB "Blu"
Old 06-10-2018, 08:39 PM   #7
Dustytrix
I used VA on my 67, one of the hoses was a little short. I called them to try and maybe reroute it. Salesperson asked me how much longer it needed to be, I told him and it was at my house in 2 days. Very Very, good customer service from VA for me. So I don't think it will be any hassle, give them a call.
Dustytrix is offline   Reply With Quote
Old 06-11-2018, 06:53 AM   #8
NC_John
NC_John's Avatar
I sent them an email with some pics. We'll see how they respond. If they are in TX (I thought CA), it could get here quick enough.
1970 C-10 LWB "Blu"
Old 06-11-2018, 12:14 PM   #9
Wrenchbender Ret
I broke a switch on the control panel while installing my Vintage Air. I called them & they sent a new one right away no charge.
George
Wrenchbender Ret is offline   Reply With Quote
Old 06-11-2018, 01:47 PM   #10
Hart_Rod
Hart_Rod's Avatar
thanks
John you can just use a button type connector on that wire. I've done it many times without any issues.
Hart_Rod is offline   Reply With Quote
Old 06-11-2018, 02:46 PM   #11
jessemthompson
I just swapped mine out with blade typeconnectors from advance. I didn’t wanna deal with looking for the other connector.
jessemthompson is offline   Reply With Quote
Old 06-11-2018, 06:36 PM   #12
Mike (Asheville)
Mike (Asheville)'s Avatar
I'm all out of 1 pin connectors or I'd have gladly sent you one. There are single pair kits available on eBay for different wire gauges. Here's an example:
https://www.ebay.com/itm/Delphi-Weat...IAAOxy4dNS7SZi
You probably know, but you need a crimping tool to do it properly.
Mike (Asheville) is offline   Reply With Quote
Old 06-11-2018, 07:27 PM   #13
NC_John
NC_John's Avatar
Thanks everyone. I can easily change out the connector to something I have but I like the factory look of the weatherpack. i'll just get the other side from that auto electrical supply shop that did my new battery cables. Vintage Air never returned my call today - apparently you cant even talk to a live person when you call, you have to leave your info on a voicemail and they promise to call you back in 30-60 mins. They didn't.
Here is the response to the email I sent.
"John,
Unfortunately we do not carry that weatherpack connector, But it can be found at Summit or several places online. The GM part # is 2804F You will run the blue wire to the power side of the weatherpack conn.
In our wiring harness we only have one wire going to the comp. and tapping into a OEM comp. may require some extra connectors/fittings.
I hope this help and don’t hesitate to contact me if you have any questions.
Regards,"
So they knowingly send out a harness plug with a connection that they know doesn't work. I'm not impressed.
1970 C-10 LWB "Blu"
Old 06-13-2018, 05:00 PM   #14
wpotter
wpotter's Avatar
John,
I left you a message today so if you would contact me at your convenience. The connector you are looking for should have been in the box with the compressor. We can get one out to you so you don't have to search elsewhere.
Thank you,
Wayne Potter
Never a failure, Always a lesson!
1968 Chevy SWB Fleetside ECE 4/6 327/350
1987 Chevy V20 Scottsdale 4X4 350/400 4.10
1987 Chevy Custom Deluxe SWB 305/7004R4
1991 Suburban Silverado V1500 4X4 350/700R4
2015 Chevy Crew Cab SWB (Daily Driver) 5.3
wpotter is offline   Reply With Quote
Old 06-19-2018, 06:53 PM   #15
NC_John
NC_John's Avatar
Originally Posted by wpotter View Post
John,
Thank you,
Wayne Potter
Got the connector today Wayne. Thanks for the hook-up
1970 C-10 LWB "Blu"
