Old 04-19-2017, 09:19 PM   #326
MMcMasters
MMcMasters's Avatar
Re: 1970 Med Olive Project
I started making my A/C and heater hoses tonight. This is my first time using the EZ Clip hose ends and I have to say I love them. Very easy to terminate (using the right crimping pliers) and no more going to the AC shop to have hoses made!! The hose is much better looking too!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 04-19-2017, 09:35 PM   #327
rincones
rincones's Avatar
Mann I wish u were my neighbor. Lol.
So I could learn from u and all other forum members.
Just Dreamed Like I always do.
What if, we all lived in a C10 Subdivision.
It would be a car show and meet everyday.
Rincon
rincones is offline   Reply With Quote
Old 04-19-2017, 09:54 PM   #328
MMcMasters
MMcMasters's Avatar
I with ya, I wish I had neighbors that were car/truck guys and I wish some of my car buddies lived closer too
Mike
Old 04-19-2017, 11:11 PM   #329
Smittee
The beauty of forums like this! Just no way to borrow tools (that might just be a good thing)!
Smittee is offline   Reply With Quote
Old 04-20-2017, 06:10 AM   #330
Lorne
Lorne's Avatar
Mike did the VA come with all the EZ clips you needed or did you have to but additional ones?
Lorne
Si vis pacem, para bellum
48 Ford F100 Panel
67 Chevy C10
71 Camaro RS
73 Camaro RS (in progress)
Lorne is offline   Reply With Quote
Old 04-20-2017, 06:29 AM   #331
GR8-68
GR8-68's Avatar
I need help to Mike, you need to start traveling
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 04-20-2017, 07:52 AM   #332
builtbyKane
builtbyKane's Avatar
Where do you plan to run the lines through the firewall?
builtbyKane is offline   Reply With Quote
Old 04-20-2017, 08:45 AM   #333
Hart_Rod
Hart_Rod's Avatar
I have always wondered if there would be enough work for someone to do that as a business.....
Hart_Rod is offline   Reply With Quote
Old 04-20-2017, 08:51 AM   #334
MMcMasters
MMcMasters's Avatar
It's an upgrade to the standard hoses Lorne
I should be asking you to help me man
I am using a bulkhead
Mike
Old 04-20-2017, 09:25 AM   #335
Smittee
Good to know about that upgrade! I am getting close to ordering a unit and that will be very helpful. Thanks for that hint. I like that bulkhead fitting as well. That really cleans it up.
Old 04-20-2017, 09:30 AM   #336
MMcMasters
MMcMasters's Avatar
Rob,
Chub Tubz needs to branch out
Mike
Old 04-20-2017, 10:13 AM   #337
Hart_Rod
Hart_Rod's Avatar
Rob,
, need to do something, business has been slowly lately :.
Old 04-20-2017, 10:26 AM   #338
hewittca
hewittca's Avatar
Awesome work so far. I love your line work, veeery nice!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 04-20-2017, 01:09 PM   #339
knomadd
knomadd's Avatar
I love the EZ clip stuff! I have it on both my GTO and my C10! I'm about ready to redo my engine side after doing my LS swap. They make it so easy to custom route your A/C lines, and if you change your mind later, or change things and need to redo a line, you aren't having to rely on another shop to do it.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-25-2017, 08:45 PM   #340
MMcMasters
MMcMasters's Avatar
I have not mentioned this yet but I made the decision a few months ago to switch from outboard mounted bags to inboard mounted bags. I ordered a notch brace from PB that is designed for the inboard bags and it showed up last week. Today I picked it up from powder coat and got it installed.
If anyone is or knows someone who is planning to do a PB drop member, I have a rear notch brace and a set of lower bag mounts that I will save them a lot of money on.
Mike
Old 04-25-2017, 09:51 PM   #341
kehstr
kehstr's Avatar
what are the pros to inboard vs. outboard bags? or is it just a personal preference?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 04-25-2017, 09:59 PM   #342
MMcMasters
MMcMasters's Avatar
The only reason I did it is it will give me more wheel options should I decide to go wider in the future.
Mike
Old 04-26-2017, 08:19 AM   #343
flipper58
flipper58's Avatar
It turns out the precision converter I had was wrong. The mounting pads and the pilot snout were for a non LS 4L60. I called and talked to Brian at Circle D and he got me set up with the right converter that would be used with my stock flexplate without the need for a spacer.
The engine/trans are back in the chassis for good. I set it up for 5* down angle and mounted the trans crossmember. I'm going to have a local shop build the driveshaft this week. Small progress but I'm moving in the right direction.
Awesome build and incredible attention to detail. Lots of great info too. One question that I may have missed in your build thread: Can you provide details on your carrier bearing?
Thanks,
Phil
flipper58 is offline   Reply With Quote
Old 04-26-2017, 10:01 AM   #344
MMcMasters
MMcMasters's Avatar
Phil,
it's from Inland Empire. Here is a link
https://www.iedls.com/#Our_Difference
Mike
Old 04-26-2017, 10:47 AM   #345
Bennett68C10
Bennett68C10's Avatar
I'm thinking about doing the same exact thing with the notch brace, move to the internal mount bags for future wheel options as well.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-26-2017, 10:59 AM   #346
MMcMasters
MMcMasters's Avatar
It definitely cleared some room back there 12" wheels would be no problem now.
Mike
Old 04-26-2017, 11:09 AM   #347
Dustmaker65
Dustmaker65's Avatar
Biggest difference I found between Choppin Block and PB right out of the box. With the in board bags, it looks like a narrowed rear end is almost a must There is a LOT of axle housing sitting out side the frame.
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 04-26-2017, 11:14 AM   #348
MMcMasters
MMcMasters's Avatar
Yes there is Jimmy. Coy's now makes my wheel in a 20x12 so they may be in my future.
Mike
Old 04-26-2017, 11:36 AM   #349
Dustmaker65
Geesh Mike....they make them in 20x14. Why just take a baby step, jump in with both feet
Jimmy Hoelzel
Old 04-26-2017, 01:30 PM   #350
flipper58
flipper58's Avatar
Phil,
Thanks Mike.
Phil
