04-12-2009, 07:19 PM | #1 |
67-72 parts collector,…
Project: NO-LIFE,...
I guess it's time to post a build on my red '69 swb.
I purchased this truck around the first of January 2009. I bought it because it was a clean short fleetside truck. It's got a 292 6 cylinder and a powerglide transmission,... which I thought was kinda odd for a short wheelbase 1/2 ton truck. Anyway,... I've been trying to use only parts that I had laying around, which includes robbing a ton of stuff off of my old '71 swb parts truck. So far I purchased a nice used grill from member tcb-1, powdercoated headlight bezels from txfirefighter, and a bunch of misc. small parts from other board members. This truck is a perfect example of the deals you can find on this board. Well worth the $25 subscribing members dues,... for all the parts I have found on here. The suspension is a 5.5"/7.5" static drop. I'm using some swap meet '71-'72 McGaughy's drop spindles ($100), a set of $89 Summit 3" drop springs, and my old Belltech drop shocks from the blazer. In the rear I have a set of 6" ECE drop springs, ECE Super Track Bar, and ECE shocks and relocators from my '71 parts truck. I also made a set of 1.5" lowering blocks to get the rear down. This weekend I swapped the alternator for an "internal regulating" off the parts truck. I recently purchased a new Optima battery for the blazer,... so the old AC Delco battery got swapped into the '69. The grille ($75)and swap meet front bumper ($20) got put on last weekend. Wheels are a set of 7" and 8" 6-lug ralleys I had, with some Ebay centercaps. Tires are 215/70-15's and 275/60-15's for a little rubber rake. I got the bed installed this afternoon, and took it for a quit trip up the road. (setting on a 2-1/2 gallon bucket. Ha) The front a-arms are the old stock lowers and CPP uppers off of the blazer. All the tie rods, idler arm, etc. are new. I've got a ton to still do,... but here's what it looked like when I started, (after a wheel change and minor clean up), and the "new stance" photos I took today.
04-12-2009, 07:27 PM | #2 |
Re: Project: NO-LIFE,...
I really thought the rear would be lower.
I also installed a POL (Performance OnLine) bolt in c-notch, since I was adding 1.5" blocks to my 6" lowering springs. Maybe it will come down a little more, after I get some miles on it.
04-12-2009, 08:07 PM | #3 |
I like it!
04-12-2009, 08:13 PM | #4 |
Tot Roddin'
Keith, it looks killer! Can't wait to see you rollin' up in that thing.
Glad to see if finally came back together.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
04-12-2009, 08:26 PM | #5 |
Nate,... it's no where close to being road ready.
But at least I can move it out of the garage,... so I can work on the blazer if I have to.
04-12-2009, 08:29 PM | #6 |
Tot Roddin'
BTW... how did the ol' 292 do?
04-12-2009, 09:08 PM | #7 |
It did ok. The powerglide is not my favorite. I think I found my tranny leaks. (Rear tailshaft seal and the dipstick o-ring).
So the powerglide will stay for a little while longer.
04-12-2009, 09:39 PM | #8 |
Blaze-Air
Beer money, champagne looks...Hey, what do you think the rear ratio is with a pg. I couldn't imagine less than 3:73.
04-12-2009, 09:52 PM | #9 |
I've never checked. It doesn't have too much "off the line go power",... I would guess 3:08's.
04-12-2009, 11:38 PM | #10 |
Much better.
I've never seen any 7" 6-lug wheels so that's cool to know about (learning something new each day means we're still in the game!). Since the PG is a bleeder, it makes that much more sense to upgrade to a used 200r or 700r4 tranny (gotta keep the theme consistent ).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-12-2009 at 11:39 PM. |
04-12-2009, 11:47 PM | #11 |
I like it!
Kevin LFD Inc. |
04-12-2009, 11:56 PM | #12 | |
I think the original application was 4x4 Blazers/Jimmys from the 70's. I would love to swap in a 200-4R, but I'm not quite sure about connecting the TV cable to the 292. I may just cheap out and do a TH350 swap. I'd really like to do a 454/TH400 transplant.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-13-2010 at 07:03 PM. |
04-13-2009, 12:00 AM | #13 |
Cool truck the drop looks great.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
04-13-2009, 12:10 AM | #14 |
Sweet truck, U have very nice rides.
04-13-2009, 09:44 AM | #15 |
Hey Kevin,... your "LFD cab/bed lifting tool" has been a lifesaver for me. (or should I say back saver)
Anyone that has to do this stuff by themselves,... should purchase the plans from Kevin and build one of these handy lifting tools.
04-13-2009, 09:15 PM | #16 |
Truck looks great! Please tell me your not getting NO-LIFE for plates!
04-13-2009, 10:25 PM | #17 |
Uh,... maaaaaybe!?!
It actually fits me. I don't do much else except work on these trucks. No other real hobbies. Unless drinking a cold Bud Light counts. Tonight I spent a great deal of time cussing/changing my LH window regulator. I had forgotten how much of a pain these are to change. So I "googled" for some info,... and guess what,... it took me right back to this board for correct information. Tomorrow night I will tackle the RH side. (Hopefully in half the time). You guys with nice paint,... I don't know how you install the vent windows and door glass without scratching up the paint.
04-13-2009, 10:42 PM | #18 |
72 Chevelle Club
Very Nice ..........
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
04-13-2009, 11:11 PM | #19 | ||
04-13-2009, 11:21 PM | #20 |
Yeah,... not like I am busting my a$$ every night on a truck build,... I just piddle around.
I wish I could do a high dollar build like so many of the NICE show trucks on here.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-13-2009 at 11:22 PM. |
04-13-2009, 11:29 PM | #21 |
You & me both. But..... we can always say we did most of it ourselves, in the driveway.
04-14-2009, 07:52 AM | #22 |
Under Construction
very nice truck... job well done on the lowering.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
04-14-2009, 09:43 AM | #23 |
Nice truck/stance!!
R.I.P. Killer 71 10/26/07 |
04-14-2009, 09:44 AM | #24 | |
Blaze-Air
I've seen at least three trucks you have that would make for a nice high dollar build. Pick one..... And as far as "No Life", and all you do is work on trucks...I'm confused, is there a problem there? At least your hobby isn't needlepoint, or baking. |
04-14-2009, 03:44 PM | #25 |
Keith, the truck looks awesome! Everything is right on, the staggered wheel size, the center caps, the tire sizes, and the fact that the front wheels don't stick out further than the rears. I wish more people would take time planning things before throwing parts on. Excellent job my friend.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
