Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-10-2010, 03:33 PM   #1
Rich Rykowski
67' C-10 radio nightmare!!
Hi folks, I have a 67'C-10 and took the crappy radio out that someone put in it. I bought the correct Delco AM radio and knobs, and an $80.00 replacement speaker from LMC truck. When I looked under the dash, there is NOTHING to screw, attach, or bolt this speaker to!! I went on ebay and found a dude selling a radio "AND" a speaker!! The speaker has 4 brackets on it!!! I'm starting to think the speaker was mounted on top of the radio instead of the underside of the dash!! Anyway, check out ebay item # 170442950090 and SOMEONE help me here if you can!! Maybe you know how I can install this speaker. My email address is Rykowski@comcast.net or 203 888 9617. I've been driving around with the glove box torn out for 3 weeks!!Thanks, Rich........
Rich Rykowski is offline   Reply With Quote
Old 02-10-2010, 05:39 PM   #2
71 super
71 super's Avatar
Re: 67' C-10 radio nightmare!!
The speaker does attach to the dash. Four brackets are correct if you include the unit that attaches to the radio. Those brackets may be some of the hardest brackets for these trucks to find, especially the support strap from the firewall portion to the back of the radio. The correct speaker is still available but in NOS form is expensive. If you use the stock radio be sure that the ohms are correct on the speaker or you will mess up the radio. I have found a source for the speakers called electro-tech. They refurbish them for around $50 and worth it if you want stock stuff.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 02-10-2010, 05:46 PM   #3
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Talking Re: 67' C-10 radio nightmare!!
you know it would be cool ( BUT KIND OF WEIRD) to have a working radio in a 60's vehicle , I have never had a radio , my 67 camaro has it's original AM radio it doesn't work but I would not take it out for NOTHING !
my 67 C10 has it's factory RADIO DELETE PLATE which is the coolest thing EVER ! maybe I will get a vehicle one day to have a radio in ??
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 02-10-2010, 06:09 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I have an original AM radio for each of my trucks. The chevy came with it and the GMC came without one but I found one in a junkyard. The problem is they only have AM and only goes up to around 1550 on the radio dial. Newer radios go up to 1720 or higher. Locally I can pick up a Spanish language station and a religious one and that's about it.
Remember you will need one of these connectors if you go stock.
68gmsee is offline   Reply With Quote
Old 02-10-2010, 08:43 PM   #5
67mater
67mater's Avatar
I just bought a 70 gmc with original EVERYTHING. I'm going to change to kick panel speakers, so if you want I'll pm you about the brackets that should be in mine.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 02-10-2010, 08:46 PM   #6
cjohns
cjohns's Avatar
electro-tech is right down the road from my house so I stopped in and picked up a new retro speaker,works great.He will also take a stock GM am radio and make it am/fm!A real nice guy too!
cjohns is offline   Reply With Quote
Old 02-10-2010, 08:49 PM   #7
cjohns
cjohns's Avatar
I should also post what I did...I picked up one of these off greadbay,works great.
http://cgi.ebay.com/ebaymotors/VINTA...Q5fAccessories
Old 02-10-2010, 08:49 PM   #8
67vetteal
Jerry Rudbeck specializes in our old radios. He evan puts iPod Jacks to them so you can play your iPod threw the existing radio. Not expensive either. Great guy and communication that is understandable. Al W.
http://www.electrodesign.us/contactus.htm
67vetteal is offline   Reply With Quote
Old 02-10-2010, 09:50 PM   #9
red71c10
The Red Menace
red71c10's Avatar
Metal Plumber's tape is always useful when installing car radios, and would make a good substitute for the support strap.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 02-11-2010, 03:35 AM   #10
red71c10
The Red Menace
red71c10's Avatar
I've had really good luck with old radios. The one in my truck came straight from the wrecking yard. I got the radio, speaker and all the knobs & brackets for $20! I cleaned it up and it works great! I used to have a '54 Mercury and that radio still had tubes! I found another radio at same wrecking yard and between the two managed to put together a good working radio. Most of the time the old radios just need cleaned up and they are good to go!
Old 02-11-2010, 05:24 AM   #11
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
That bracket and that speaker on ebay item # 170442950090 doesn't look original to our trucks to me at all unless GMC's were different..heres a link to a thread I started awhile back about some reproduction speakers.
http://67-72chevytrucks.com/vboard/s...d.php?t=379836
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 02-22-2010, 08:27 PM   #12
michael bustamante
michael bustamante's Avatar
110496806522 heres an e bay auction for the bracket youre looking for I believe
1967custom
michael bustamante is offline   Reply With Quote
Old 02-22-2010, 08:33 PM   #13
msgross
msgross's Avatar
Please don't turn this into a sale ad, lots of good info here that would be a shame to lock.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-22-2010, 08:41 PM   #14
LockDoc
The Older Generation
LockDoc's Avatar
Here are some pics of the stock mounting brackets... The bracket with two holes you see in the first three pics mounts to the firewall
LockDoc
Leon
Old 09-05-2012, 10:07 PM   #15
Daner
Daner's Avatar
I picked up a 52 Nash last fall. Found an add pushing the superior sound a 6 tube radio has over one with less. Radio works but the speakers are shot. 5ft antenna doesn't hurt anything either. lol
My 67 has the radio delete also. Waiting til i can scrounge up some money to hide one away somewhere.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 09-05-2012, 11:49 PM   #16
Tuff Gong
Tuff Gong's Avatar
Here is some info to ad to this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=518727
Tuff Gong is offline   Reply With Quote
Old 09-06-2012, 09:16 AM   #17
leftybass209
leftybass209's Avatar
In terms of guitar amps, tube amps are still highly sought after and regarded as some of the best amps available, vs solid state amps. I'm sure tubes would give a radio a beautiful colored warm sound.
leftybass209 is offline   Reply With Quote
Old 09-12-2012, 08:47 PM   #18
76stepsidechevy
Tube amps are sought after in the hifi world as well. Theres a lot of high end audio equipment out there that still employs tube technology.
76stepsidechevy is offline   Reply With Quote
Old 07-23-2013, 04:40 PM   #19
singinsarge
LockDoc
These photos are perfect for what I needed, thanks!
Now... to get the speaker refurbished...
singinsarge is offline   Reply With Quote
Old 09-04-2015, 10:41 AM   #20
iambull
Thanks for these pics. saved me a ton of time doing my speaker replacement.
iambull is offline   Reply With Quote
Old 10-18-2016, 11:41 AM   #21
B-Redd
The gift of pictures keeps on giving. Saved me a bunch of time of trying to figure out what my missing bracket looked like.
B-Redd is offline   Reply With Quote
