02-12-2011, 12:50 PM | #1 |
c10 front suspension - what differences between 73-87?
Hey Guys
Im usually in the 60-66 forum but looking to swap front ends from your era for a stop, drop, and roll upgrade. Theres a crap load of info in our section but its got my head swimmin so I thought Id come straight to source - please point me elsewhere if its already been covered besides 1.00 and 1.25 rotors, is there ANY differences/improvements, or things to steer clear of between 73 and 87 c10 front ends? Did all (or any) of these years come with front sway bar? I am either trying to find a parts truck on CL or headin to pick-a-part and want to know if there is a particular year to hunt for or shy away from one last - these 2wd c10 are referred to as Silverados, right? Cheyenne is c20/ 3/4, right? Thanks! |
02-12-2011, 01:19 PM | #2 |
Re: c10 front suspension - what differences between 73-87?
Not all 2wd's are silverado's, its different trim packages radio, heat, ac, etc. What exactly are you looking to swap over? The spindles will slide into your stock ball joints if yer runnin a 63+, that will give you disc brakes etc.
When I worked for Checker, I checked about the 1.00" and 1.25" rotors and it was the same part number, I wouldn't worry too much there, I've swapped back and forth in the past without any issue.
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
02-12-2011, 01:23 PM | #3 | |
67-72 parts collector,…
The 63-70 balljoints are different than the 73-87 ball joints. The tie rods are also different. As far as the 1" vs 1.25" wide rotors,... They are completely different. Different bearings. Different calipers. Different rotors. Different spindles. Please check your info before posting.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-12-2011 at 01:24 PM. |
02-12-2011, 01:20 PM | #4 |
C10= 1/2 ton
C20= 3/4 ton C30= 1 ton Custom Deluxe, Scottsdale, Cheyenne, and Silverado are are "trim packages". (options) When you are looking for parts,... try to get it all. Steering linkage and M/C, prop.valve, and booster.
02-12-2011, 01:27 PM | #5 |
blackmopar,... you might want to look at this "sticky" from the 60-66 Meassage Board area.
http://67-72chevytrucks.com/vboard/s...d.php?t=443871
02-12-2011, 01:37 PM | #6 |
lolife - thanks - yea I did check out your sticky on the 60-66 forum - i think I get the interchangeable and not interchaegeable stuff but my plan is to try to get a complete parts truck from 73-87 era - so i can do a complete resto and rebuild on the cross member on the bench so to speak.
So my basic question here is which one? do they all have sway bars? something I need. which years have the 1.25 rotors? My basic thought is an 87 front end should be in better shape than a 73 from a wear perspective - but Im figuring any year i get Ill need to replace bushings, bearings, etc so does year even matter? i also figure a compelte truck donor is to my bennie to get m/c, lines, vlavles, and so on...... Mines a 64 c10 lwb by the way Last edited by blackmopar; 02-12-2011 at 01:38 PM. |
02-12-2011, 02:22 PM | #7 | |
I get using the donor parts,... like steel brake lines, prop valve, spindles, dust shields, and steering linkage. How much of the other used stuff do you want to use? Are you just slapping on disc brakes? Or are you rebuilding the front end? Ball joints? Tie Rod ends? Calipers? Rotors? Are you adding drop spindles? If so,... (in my opinion) there are very few donor parts to re-use. I would buy all new wear items. (including rubber brake hoses) Since the aftermarket came out with "year specific" drop spindles(63-70 in your case),... there is no need to use the later 73-87 stuff. These are a bolt-on spindle.
02-12-2011, 02:44 PM | #8 |
yea the main goal is to drop the b1tch, If they had a drop spindle that accepted drums I might consider just that, but my entire front end also needs a rebuild now, so what i read is moving to the 73-87 gets me better design bushings, etc. and since I need master cyl, lines, and all the lil crap anyways a donor seems liek it would be a good choice, would really be lucky if I found a 73-87 that already got dropped too , but My main issue is i dont want to get a donor and wind up in the auto parts or aftermarket for everything anyway
02-12-2011, 04:35 PM | #9 | |
.. !WAR FEDOR! ..
"san diego chargers #1" |
02-12-2011, 04:43 PM | #10 | |
yea thatd be great - I useually try to start with gallant or San Luis Rey - they all want a grip a $$ for everything I need though |
02-12-2011, 04:48 PM | #11 |
.. !WAR FEDOR! ..
Yeah gallant chargers way too much man. i know ecology has a few solid c10's right now, ill shoot you a PM.
02-12-2011, 04:50 PM | #12 |
perfect - thanks a bunch!
02-12-2011, 06:40 PM | #13 |
Get a sway bar off a big ass 8 lug suburban...i got a 1.25" bar for my c10 that had no sway bar from the factory...I'd get a parts truck off craigslist...strip the good stuff, then put your old crossmember on it so it could roll, and call pick your part to come get the carcass
02-12-2011, 07:46 PM | #14 |
Watch out for your cornhole !
Here's what I learned when doing my 63 truck with a donor.
In my experience, Suburbans are the best donors. I have never seen an 81-91 Suburban that did not have the bigger rotors and a sway bar. There might be some out there but I looked pretty deep and never found one equipped otherwise. Plus Suburbans seem to lead easier lives than pickups do so your chances are better of the parts being in better shape. Look through my blog a bit. You might have to go back a few pages, but I built a 63 truck and used the entire 73-87 brake and suspension system. The master cylinder bolted directly to the firewall without mods. The brake lines all worked without mods. The proportioning valve laid right on the frame and just required me to drill two holes for the mounting bolts. I used 73-87 brake hoses front and rear. Seriously, other than drilling the two 5/16 holes for the prop mount bolts, it was bolt in. Even the holes for the later model front brake hoses were already in the frame. Again, check my blog back a bit for details and if you have any questions just ask. My photobucket account has thousands of pictures so I probably have one that would clear up any questions. And, that slammed427 guy is flat wrong on just about all he wrote. Disregard that stuff.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 02-13-2011 at 07:41 AM. |
04-05-2021, 10:57 PM | #15 | |
04-06-2021, 10:47 AM | #16 |
A quick/easy search of that board members name yielded.....
http://67-72chevytrucks.com/vboard/s...d.php?t=373970
04-06-2021, 09:32 PM | #17 | |
02-12-2011, 08:13 PM | #18 |
.. !WAR FEDOR! ..
so I went to ecology and only found one 1/2 ton with the suspension all together, sorry, i couldnt attatch pics in a pm. here it is.... should be all you need. These are from a 86 suburban... hope this helps.
"san diego chargers #1" Last edited by joe1982; 02-12-2011 at 08:14 PM. |
02-13-2011, 05:48 AM | #19 |
right on - thanks Tex and Joe - any idea what ecology wanted for it all?
02-13-2011, 12:59 PM | #20 |
Happy to be here
Get a quote, the check Craigslist. Like Tx Firefighter said finding a complete donor Burb is a great way to source a LOT of parts and they are usually cheap.
02-13-2011, 03:27 PM | #21 |
.. !WAR FEDOR! ..
not sure man, give them a call though, I think they are having a sale this week.
02-13-2011, 01:05 PM | #22 |
I scrapped two of those complete crossmember assemblies,... because I couldn't get $50 each for them.
Look around. They can be found cheap. Another good source is people selling "pickup bed" trailers. They always have the front half of the frame laying around or ready to got to scrap.
02-13-2011, 01:16 PM | #23 |
nice idea lolife! yuea n2trux im searching everyday but again, i wanna make sure I get it right.
There is a burb up in Berdoo 87 or 88 I think, for def the right price but it is an 8 lug 454 truck - Arent the burb 8 lugs at least a 3/4 like the pickups? that stuff I need to steer clear of, right? LPDex above mentioned 8 lug - was that JUST for the bar? |
02-13-2011, 01:34 PM | #24 |
8-lug trucks are 3/4-ton or 1-ton trucks. (burbs too)
They are a great source for the large front swaybars. Balljoints, lower a-arms and tie rods are different from the 1/2-ton trucks. (besides the obvious 8-lug spindle/rotor assembly) Keep looking for 1/2-ton stuff.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-13-2011 at 01:34 PM. |
02-13-2011, 03:32 PM | #25 | |
Happy to be here
If you are lowering your truck you can use the Early Classic Enterprises (ECE) lowered stands. If your going really low, you can just bolt the bushing clamps directly to the frame.
