02-05-2012, 01:31 PM | #1 |
How are you guys using a engine hoist to lift the cab?
So last night we took the cab off my truck. We are moving it to another frame with all of the interior still in it. So its HEAVY. It took 4 of us and it was still a PITA. how are you guys using the engine lifts to pick the cabs up?
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
02-05-2012, 04:37 PM | #2 |
Re: How are you guys using a engine hoist to lift the cab?
I used a 4x4 after I made a holder for it that bolted onto my hoist.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
02-05-2012, 04:41 PM | #3 |
It works great. I also made one of the bed/cab lifts that rockrln sells plans for. I sold it and figured I wouldn't use it that much. I've used the 4x4 a lot since then.I will probably make another bed/cab lift one day. Its much easier to use if your by yourself as I am a lot of the time.
02-05-2012, 05:10 PM | #4 |
67-72 parts collector,…
Build the version that Rokcrln sells.
$20 for the plans. They work great and no worries of anything slipping. http://67-72chevytrucks.com/vboard/s...d.php?t=219353
02-05-2012, 06:04 PM | #5 | |
That plan from Rok would be awesome but I am only going to use it once so its really not worth me buying the plan, materials, building it then having it laying around forever.
02-05-2012, 08:50 PM | #6 |
I was lucky and used our two post lift and was able to lift the complete cab and complete front clip. Worked perfect, just put the lifting arms under the cab supports
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
02-05-2012, 08:59 PM | #7 |
Built my own and bolted it to my hoist
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where |
02-06-2012, 11:32 AM | #8 |
you need a few young bucks is all!!!!!!!!!!! unless you are doing a lot of trucks there is no need to fabricate anything. Of course unless you like making things!!
we have the lifts etc. but it easier to just lift it off with some help.everyone seems to want to come up with some kind of contraption. I have used 2x4 with a lift. cheap and dirty. cut some slots for the pinch welds at the door, duct tape it down. and position it and lift it.hahahaha |
02-06-2012, 11:36 AM | #9 |
02-08-2012, 07:51 AM | #10 |
Built a rokcrln lift, works great, lifts bed too. Actually farm it out to my buddies body shop quite a bit.
02-08-2012, 01:23 PM | #11 |
I did not take any pictures, but the last time I did mine with a couple nylon tow straps UNDER the cab between the frame. My doors were not on the truck so it made it easier. The front strap was located down where the rocker hole for the front fender mount is; rear was under the rocker panel. One person can pump and stabilize the rig, but two makes it easier.
02-08-2012, 08:37 PM | #12 |
never finish start another
Low budget but it works. used 2x10 and 2x4's. I think that 2x8 would work also. screw them together for strength.
02-08-2012, 08:50 PM | #13 |
One of my buddies was saying we could use the bolt holes for the seats and hook chains to them. That a good idea?
02-14-2012, 12:29 PM | #14 |
That's what I did...worked well
1972 Cheyenne (LWB now a SWB) |
02-14-2012, 02:14 PM | #15 | |
I'm about to take my cab off too and I think I'm going to make one of the type above. 4x4 or metal under the cab roof pushing up. .. just my .02.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
02-14-2012, 02:45 PM | #16 |
thats good to know.... Just so happens I bought one of those engine leveling hoist to put my motor in the other frame. I just might try that route.
Thanks guys.
02-14-2012, 03:12 PM | #17 |
Lifting with chains sounds good. Also note that the one that I made with wood will lift with the doors on. I suppose that would work with chains as well. Sounds like trial and effort to see what works best. The reason I used 2x12 is that I had them in the wood pile! I have also lifted boxes with the 2x12's by laying flat under the bed side lip just in front of the middle stake pocket and wraping a chain around them. worked well.
