Old 02-10-2012, 01:52 PM   #1
mooseknuckles
mooseknuckles's Avatar
PSI Conversions
My harness and reflashed pcm from PSI showed up in the mail today...I'm impressed with it so far...I have heard some horror stories tho, but as far as I can tell everything looks awesome...
mooseknuckles is offline   Reply With Quote
Old 02-10-2012, 04:02 PM   #2
Kim57
Kim57's Avatar
Re: PSI Conversions
I hope it all works out as I sent them my TCM.
I'm also using them for a new harness and ECM on my LS swap.
What horror stories have you heard?
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-10-2012, 05:05 PM   #3
mooseknuckles
Re: PSI Conversions
Kim
I've heard that some connectors fall off, and some are miss-matched, but everything looks ok to me....I got them to send me a used pcm with a reflash to save time and shipping, plus it was only $200 vs the $150 for a flash....
Old 02-10-2012, 05:39 PM   #4
harnalien
TruckincrazY
harnalien's Avatar
Re: PSI Conversions
I got a harness from them and one of the fuel injector connectors was broken. Other than that, not bad for the price.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 02-10-2012, 06:25 PM   #5
Kim57
Kim57's Avatar
Re: PSI Conversions
That doesn't sound to bad.
I'm getting the same deal on the ECM.
How hard was it to replace?
Kim
My build thread
Old 02-10-2012, 11:58 PM   #6
clinebarger
Re: PSI Conversions
Kim
I Fixed that on harnalien's truck with a GM replacment plug/pigtail. Not hard at all, The rest of the plugs were fine. Harnalien's harness is the only PSI harness ive messed with but from what I saw it looked OK.
clinebarger is offline   Reply With Quote
Old 02-11-2012, 12:31 PM   #7
Kim57
Kim57's Avatar
Re: PSI Conversions
Thanks.
this is my first time dealing with this type of engine swap so it's all new to me.
I'm hoping for the best from these guys as money is tight and they had the best price for what I needed.
I went with them as another member used them and was happy with the outcome.
Kim
My build thread
Old 02-11-2012, 05:21 PM   #8
19seventeeCustom
Re: PSI Conversions
looks great, and I love to hear some great stuff about PSI.
I'm going with their harness and tune for my swap, unless
someone can recommend another with the same price,quality,
and customer service??
19seventeeCustom is offline   Reply With Quote
Old 02-11-2012, 08:16 PM   #9
mooseknuckles
Re: PSI Conversions
mocked up the harness on my motor today to see how it fit.....looks real good so far...only problem I found was, there is no connector for the oil pressure, and I may need a different MAF cause mine is out of a van and the connector's arent the same...
Old 02-11-2012, 08:18 PM   #10
mooseknuckles
Re: PSI Conversions
more...
Old 02-11-2012, 08:19 PM   #11
mooseknuckles
Re: PSI Conversions
last one...
Old 02-11-2012, 11:30 PM   #12
19seventeeCustom
Re: PSI Conversions
harness looks great!!
gonna be ordering close to the same
within a week or 2.
Old 02-12-2012, 12:53 AM   #13
Kim57
Kim57's Avatar
Re: PSI Conversions
Looks good.
I should be getting mine some time next week. I'm getting a MAF from PSI because I didn't have one.
Kim
My build thread
Old 02-12-2012, 01:05 AM   #14
mooseknuckles
Re: PSI Conversions
I should've done that too...
Old 02-12-2012, 12:00 PM   #15
ls1nova71
ls1nova71's Avatar
Re: PSI Conversions
Vans use a smaller MAF you probably need a truck one but they're not too expensive in salvage yards and very plentiful. On the oil pressure, the PCM doesn't use it, it was only for the original trucks gauge.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-12-2012, 12:21 PM   #16
mooseknuckles
Re: PSI Conversions
I was thinkin that also....thanks for the confirmation man!....now got any info on the trans switch for me?....my harness only has three connections, one big round one and two smaller ones, nothin that connects to the switch in the pic.?
Old 02-12-2012, 01:34 PM   #17
ls1nova71
ls1nova71's Avatar
Re: PSI Conversions
Are you running a 4l80e? The two small plugs are the input and output speed sensors, the big round one is the main plug to control the trans, and the one pictured is the neutral safety/back up lights/range sensor for the PRNDL on the dash. You don't really need it, but it is good to have it at least hooked up so that the PCM knows what gear it's in. But if your harness doesnt have a plug for it I guess that's not an option. Is there a wire in your harness that they say to hook up to your original neutral safety switch? It would be grounded in park and neutral.
Old 02-12-2012, 02:02 PM   #18
mooseknuckles
Re: PSI Conversions
yeah...4l80e...I guess they deleted that switch...not sure on the neutral saftey switch, but I think I got to run that 4 pin brake pedal switch...
Old 02-12-2012, 08:21 PM   #19
clinebarger
Re: PSI Conversions
Is your harness setup for a 4L60E? That would explain not having a ISS connector, How many wires are going to the "big" plug? 11 or 13.
Old 02-12-2012, 09:16 PM   #20
mooseknuckles
Re: PSI Conversions
4l80e..cant remember....and very hard to see in this pic...
Old 02-12-2012, 09:37 PM   #21
mooseknuckles
Re: PSI Conversions
there are wires for park/neutral and a brake signal.
Old 02-13-2012, 07:03 PM   #22
mooseknuckles
Re: PSI Conversions
11 pin
Old 02-13-2012, 09:16 PM   #23
ls1nova71
ls1nova71's Avatar
Re: PSI Conversions
Then you can just take the NSS off the side of the transmission.
Old 02-13-2012, 09:18 PM   #24
mooseknuckles
Re: PSI Conversions
is that all that is...is a fancy neutral safety switch?
Old 02-13-2012, 09:32 PM   #25
ls1nova71
ls1nova71's Avatar
Re: PSI Conversions
Pretty much, although it does also run the PRNDL on the dash of the original truck.
