Old 03-28-2012, 07:40 AM   #1
BadCompany
BadCompany's Avatar
Question Factory Rear Sway Bar
How does the factory rear bar mount? Is it bolted to the axle tubes and frame as i have seen on other vehicles? If I could get my hands on a factory bar how easy would it be to put it on my 87 R10? Any pics or info would be greatly appreciated. Thanks
BadCompany is offline   Reply With Quote
Old 03-28-2012, 09:48 PM   #2
86454k30
86454k30's Avatar
Re: Factory Rear Sway Bar
The only "factory" rear sway bar came on 73-87 C30 dually pickups and on some 73-80 C30 single rear wheel trucks with the camper special package. No other 73-87 model was available with a rear sway bar from the the factory.
86454k30 is offline   Reply With Quote
Old 03-28-2012, 10:03 PM   #3
BadCompany
BadCompany's Avatar
Thanks for the reply. If I found one would it just bolt on or would I have to fab brackets?
Old 03-28-2012, 11:10 PM   #4
86454k30
86454k30's Avatar
If you found one from a C30 you would need to replace your ubolts with the square style, opposite position of the round one and add the axle plates like a 1 ton has on the bottom of the axle. It would be much easier to install a new hellwig rear sway bar than try and install one from a c30...IMO.
Old 03-29-2012, 02:35 AM   #5
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Question Re: Factory Rear Sway Bar
I really wanted to do that to my C/20!
What all do I need?
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 03-29-2012, 03:55 AM   #6
BadCompany
BadCompany's Avatar
Does sound like it would be less of a headache to just go aftermarket. From what I have read it also seems to be difficult to find a factory setup (kinda makes me want a factory bar more). Is there a company that sells the square u-bolts?
Old 03-29-2012, 10:05 AM   #7
86454k30
86454k30's Avatar
What all do I need?
Find a c30 and take the rear sway bar, brackets that attach sway bar to ubolts and ubolt plates.
Old 03-29-2012, 10:06 AM   #8
86454k30
86454k30's Avatar
Anyone who builds springs makes ubolts. You can even buy them from napa.
Old 03-29-2012, 12:15 PM   #9
Mattman2010
Mattman2010's Avatar
A rear sway bar off of a c30 will not fit on a c10/20 because the spring pads are mounted closer together on a c30 than on a c10/20. You won't be able to adapt a c30 rear sway bar easy at all so it is best to go with an aftermarket.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 03-30-2012, 04:56 AM   #10
BadCompany
BadCompany's Avatar
Found a rear bar at pull-a-part yesterday evening. Got lucky someone had already taken the rearend and just left the sway bar hanging by the end links. Got the bar, u-bolt brackets, and round spacers that go between the u-bolt bracket and plate for 28 bucks. Didnt realize the springs were closer together on a C30. I guess I will have to knock the dust off of the old tape measure today and see if it will work on my truck. If not I made the trip worthwhile by grabbing a beefy 1.25'' front bar also!! Are the u-bolt plates the same on a C30 and C10?
Old 03-30-2012, 08:41 AM   #11
crewcabsquared
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
crewcabsquared is offline   Reply With Quote
Old 03-30-2012, 11:19 AM   #12
RPOZ11
RPOZ11's Avatar
Cool Re: Factory Rear Sway Bar
I found this image online for the 1-ton trucks.
I believe that there are 2 different dually rear axle widths.
Ive wanted to do this to my C/20 and have seen a few trucks using this.
HO72 build :
2017 SS
Old 03-30-2012, 11:20 AM   #13
RPOZ11
RPOZ11's Avatar
Can someone post a good image for the 10-bolt truck rear sway bar; Factory & aftermarket?
HO72 build :
2017 SS
Old 03-30-2012, 07:25 PM   #14
BadCompany
BadCompany's Avatar
I will try and post pics as soon as I get new bushings and find some u-bolts and u-bolt plates.
Old 03-30-2012, 08:01 PM   #15
cory d
cory d's Avatar
i saw a rear sway bar on a g20 van and the pick n pull today that i am temted to get. let us now how it handles after you put the bars on
cory d is offline   Reply With Quote
Old 03-30-2012, 09:52 PM   #16
KrazyRay
KrazyRay's Avatar
I parted a 77 K10 and it had a rear sway bar, but it was missing the bracket to the axle.
It looked factory. Maybe it was retrofit years ago.
KrazyRay is offline   Reply With Quote
Old 04-01-2012, 09:38 AM   #17
GM72K10
Next!
GM72K10's Avatar
Factory parts book showing rear sway bar
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 04-01-2012, 10:51 AM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Are you showing that for reference? It looks to be the breakdown for a C/K 30 DRW assembly. AFAIK GM never offered a rear sway bar on a C10 truck.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-01-2012, 12:11 PM   #19
RPOZ11
RPOZ11's Avatar
It shows the R3, C3, & V3...denoting the 30 series applicaion.
Would the 3/4 C/20 Trucks use the same C/30 sway bar we all have shared above?
It would be cool if there was a GM drawing showing the 1/2 ton units.
This thread still needs to work towards showing what a 1/2 ton C/10 would get.
HO72 build :
2017 SS
Old 04-01-2012, 02:55 PM   #20
GM72K10
Next!
GM72K10's Avatar
Just for reference I happen to have that set up in my k30 dually cucv
86 K30 CUCV M1028A1
Old 04-01-2012, 03:05 PM   #21
RPOZ11
RPOZ11's Avatar
Can you share a pic with us how it looks installed on your truck?
HO72 build :
2017 SS
Old 04-01-2012, 05:07 PM   #22
GM72K10
Next!
GM72K10's Avatar
On an 86 K30 CUCV with a dually Dana 70 rear. Truck needs to be cleaned underneath!
86 K30 CUCV M1028A1
Old 04-01-2012, 05:36 PM   #23
East End K5
anybody notice a difference with the sway bar added?
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP
[B]1972 Chevrolet K5 Blazer RIP
1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP
1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP
[B] 1995 Chevrolet Tahoe 2D [B]
East End K5 is offline   Reply With Quote
Old 04-01-2012, 11:32 PM   #24
RPOZ11
RPOZ11's Avatar
what do you guys think of this?
HO72 build :
2017 SS
Old 04-02-2012, 08:48 AM   #25
77BBGMC
77BBGMC's Avatar
Yes, more than I expected. Mines a half ton with an aftermarket rear bar.
77BBGMC is offline   Reply With Quote
bar, rear, sway, sway bar
