LS1 air intake for a 67-72
I have gone through lots of build threads, but I cant seem to find what I'm looking for.
What air intake setups are you using in your 67-72? I've seen some real cheap ones on ebay for around $60-70, but its difficult to envision what is going to fit and what wont from pictures. I think just a simple 90* coming out of the TB with a 6-7" pipe and cone filter would work best. Street and Performance also makes a square element that bolts right to the TB. Any downside to this? Also, what size tubing are you using? I am using the OEM 98' LS1 TB and MAF Thanks! edit: I am using a '98 F body rad and e-fan setup
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e Last edited by chevy72blu; 04-08-2013 at 12:47 PM. |
Re: LS1 air intake for a 67-72
mine is a k&n cai for a 99-up silverado.. fit pretty good, didnt use the box thing tho....can't see why it wouldn't work for 67-72's
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
That is what I am using too. Not a 67-72 but for the price buy it and cut the angle part off if you don't like it. 69 bucks shipped.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
Collector of Projects
I started with a 90* silicone elbow and a K&N filter, both with a 4" inner diameter. What I have come to find out is that the MAF is slightly smaller outer diameter. I still need at piece of 4" pipe too.. I feel like I should have just bought a kit. I may save a few bucks in the end, but its a pain piecing it all together...
That is why I got a kit again. I was way over 70 bucks for the parts I wanted to make the intake and was having to use a tiny air filter. The one in my pic was 69 shipped with everything.
Boosted Member
Here's my air intake.
![]() Kinda looks like one of these Tornados inside. ![]() ![]()
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Hahaha nicely done ^^^
Thank you all for the help, this is perfect.
Do those tornado things really make more power? ![]()
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
Boosted Member
Mine does. haha.
Spectre makes one for an ls swap into a 69-72 truck. I'd show you pics of mine but I haven't installed it yet.
Check out my build: 1972 LQ4 Swap http://67-72chevytrucks.com/vboard/s...=1#post5427693 |
#11 | |
Boosted Member
FYI, since you're running a MAF (and not running Speed Density), you will not be able to come directly off the TB with a filter, unless you have room to sandwich the MAF in there. I was MAFless on my jet boat, and did just the filter. ![]() The monte carlo I built just had a quick and dirty intake on it. I have since put another 90 on the end to get the filter in front of the radiator to draw less warm air. I was seeing some pretty high IATs on hot days with it sucking under hood heat. ![]() ![]() I'm a DIY guy, so I'd have a hard time paying someone to put something this simple together for me. If you want to source the parts to do it yourself, I've had good luck with www.siliconeintakes.com and www.racepartsolutions.com for finding silicone elbows, t-bolt clamps, aluminum tubing, air filters, etc. That's pretty cool that they are developing a product for such a niche market.
#13 |
Here ya go. Hope it works. http://item.mobileweb.ebay.com/viewi...id=38484525345
Posted via Mobile Device Posted via Mobile Device
#14 | |
Posted via Mobile Device |
#15 |
Well you can get that one and later on buy a k and n filter later if you want one.
#16 |
#17 |
I have it installed right now. It's kinda a pain to remove but I can get a measure ment of it installed if you want me to.
#18 |
sounds about right....
#19 |
I have two set up two different ways. The red one is 20-21 from filter base to middle of throttle body. The blue one is 23-24.
#20 |
Blue
#21 |
#22 |
True Addiction
Street & Performance
RCC |
#23 |
Ya one may be compressed more then the other. There is some adjustment that can be made. And the blue one has a different water pump so the hose will route different to the rad.
#24 |
Truck and auto performance nut
you running a SD tune BigShoe?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#25 |
bought one of those cheap ebay CAI's
this one http://www.ebay.com/itm/SIERRA-SILVE...fd4583&vxp=mtr seems exactly like every other one i have seen. $65 shipped. the seller included a 10% discount code if anyone needs it K2-110109 good till the end of may |
