Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-29-2013, 10:24 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
Budget LS/ S10 footbrake project
Bought this today 89' S10 set up for an LS . It will get a junkyard 5.3 and th350 and a loose converter . This one will be a back up /trainer for the wife .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-01-2013, 07:42 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Budget LS/ S10 footbrake project
That is going to be a fun project!!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-01-2013, 10:40 AM   #3
Super73
Super73's Avatar
I see a 12 second truck in the making.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-01-2013, 10:09 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Need pointers on 5.3 power tricks as ive never meesed with thee LS engine at all . Key word budget
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-02-2013, 12:10 AM   #5
Super73
Super73's Avatar
Is it going to be stock computer or carb with msd box?
Old 05-02-2013, 08:00 AM   #6
shortbed70
shortbed70's Avatar
That's going to be a runner!!! I woul love to have one for my ls
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-02-2013, 09:35 AM   #7
hotrod 80
mini truck racer
hotrod 80's Avatar
At this point carb and MSD box . Looking at a 5.3 with a cam swap or a 5.7 LS1 with a cam . something like 224/230 over whatever on a 110 and up .
This is my first LS motor . I originally wanted to do a newer model with full fuel injection and a/c more as a street driver , but this thing popped up.
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-02-2013, 04:25 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its all pretty straight forward with the ls motors, they just do a nice job of making power with some sense of economy.
The z06 takeout cams are popular used for a budget upgrade. Trailblazer SS exhaust manifolds fit easily into almost anything, if you run into a problem finding a header or manifold you like.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-02-2013, 04:55 PM   #9
Super73
Super73's Avatar
What RPM are you willing to spin the stock bottom end to?
Why are you limiting yourself on the cam? a 224 or 230 is pretty small for a 5.7 if you go there. I would probably put a mid/high 230 in the 5.3 and a high230/low 240 in the 5.7.
I had set up my first cam to peak where a stock Z06 did, but it had much more bottom end and power through the full curve. It was a 223/228 106/106 with .58x lift on both lobes.
I'd love to help you figure out a cam based on your RPM you are willing to spin. I am assuming you are going to run a converter at peak TQ to get the best 60' you can?
Old 05-02-2013, 10:06 PM   #10
hotrod 80
mini truck racer
hotrod 80's Avatar
6500-7000
good info
I was thinking something like this . Converter i have is a 4000 ish. At this point straight race truck
I will turn it up , but this is what i have to work with . 26 x 8.5 slick , 3.90 spool , th350 , 4000 ish stall , Truck already has bbk shorty headers with 2.5" to a single 3" pipe . Stock tank and pump with Mallory regulator . Homemade caltracs with stock leafs . This set up went 6.40's with a 6.0 and spray
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-03-2013, 01:18 AM   #11
Super73
Super73's Avatar
A stock bottom won't live long spinning 6,600+ but a set of rod bolts before the motor goes in would make me sleep a bit better. With that said, figure out what motor you are going to run and I will give my advice on a cam.
Old 05-03-2013, 09:30 AM   #12
hotrod 80
mini truck racer
hotrod 80's Avatar
The single plane intake shows it makes power from 3500-7500 RPM , so i'll probably go with the dual plane intake which shows 1500-6500 RPM
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-07-2013, 10:19 PM   #13
hotrod 80
mini truck racer
hotrod 80's Avatar
Powerglide it is with 4100 converter . Being freshend now . 5.3 im looking at is 187K for $299 . Looking at craigslist LS1 cam at this point trying to stay on budget of 5K.
$2800 for truck
$700 for stock case 1.76 glide with brake and turbo spline and converter from Yellow truck ( 25 passes )
26 x8.5 hoosiers i had stacked in the corner
$200 for new windsheild with seals and plastic clips to fix door windows
It also needs 2 mirrors which i will junkyard source . Also the fuel tank is bad . This will also be a junk yard source . I plan to fuel it with the 2.2 factory fuel pump with a return style regulator . This project really has me pumped .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-08-2013, 12:16 AM   #14
tinydb84
tinydb84's Avatar
I dont think the LS1 cam is different enough to justify the change and you can probably find the 5.3 for cheaper than that. There was one on Craigslist over here with 40k for $500.
David
Instagram: myfabguy
Old 05-08-2013, 10:00 PM   #15
hotrod 80
mini truck racer
hotrod 80's Avatar
Not down here . I cant find anything under 100K at all . I would like a 6.0 or LS1 . I am working on a LS 1 for 400 .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-08-2013, 10:21 PM   #16
tinydb84
tinydb84's Avatar
Check eBay. If your willing to do a 4.8/5.3 you can get a much better price than a 6.0/ls1
David
Instagram: myfabguy
Old 05-09-2013, 01:29 PM   #17
hotrod 80
mini truck racer
hotrod 80's Avatar
LKQ here in Houston has the 5.3's for $274 to around $650 depending on miles .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-09-2013, 11:19 PM   #18
Super73
Super73's Avatar
As ar as stock block go, it looks like this. Simply due to bore size helping to unshrouded the valve.
Good power - better power - even better power - best power
5.3 -------------- 5.7 ---------------- 6.0 ------------- 6.2
Old 05-10-2013, 06:27 AM   #19
hotrod 80
mini truck racer
hotrod 80's Avatar
OK , thanks more good info .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 05-13-2013, 07:56 AM   #20
shortbed70
shortbed70's Avatar
I bought my 5.3 out of a truck for $200 with 200k complete minus a few bolt ons. Check out I think it was car craft tht did an ls cam comparison in a 5.3. Ls1-ls7 cams and a few aftermarket and where they made power.. I seen it on ls forum!
Troy
Big Red Dog build
Old 05-13-2013, 01:10 PM   #21
Super73
Super73's Avatar
Yes, this months car craft they tested like 9 stock GM cams and then 3 crane cams. I just think a custom grind would be a better choice, might cost a little more, but will compliment the decided combo more.
