12-09-2013, 09:57 PM | #1 |
The Dirty-Burb sure looks good in my driveway.
New to the forum, i just picked this up on saturday. I'm sure you guys have seen the build thread on this but i am excited to keep going with it. I will have my share of questions getting to know this vehicle. Talk to you guys soon
Dustin |
12-09-2013, 10:28 PM | #2 | |
The Older Generation
Re: The Dirty-Burb sure looks good in my driveway.
Hey Dustin, That would look really nice if you could get it an inch or two lower..... just kidding! Great looking Burb and welcome to the truck board... LockDoc
12-10-2013, 12:22 AM | #3 |
What?
Hey Dustin,
Welcome to the forum! I know that burb too. What are your plans for your new ride?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-10-2013, 01:05 AM | #4 |
So sick. Welcome. And I'm so jealous...That's been my favorite burb on here for a long time.
Aaron Anderson *1971 GMC Burban - Daily *1962 Nova |
12-13-2013, 01:26 PM | #5 |
67-72 parts collector,…
Welcome to the board!
Congrats on your new purchase.
12-13-2013, 02:18 PM | #6 |
Junior Member
Welcome. You got a sweet burb from Dave. It sounds like you got a deal too!
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
12-28-2013, 12:57 AM | #7 |
Thanks guys.
Plans right now are to fix a bunch of little miscellaneous things. New window regulators, door hinges are sagging, new rubber, new grill trill and modify the hood release since it has a forward tilt hood. The release does not quite open all the way so its hard to get the hood open. Then build a new center console and put a headliner in. Right now its just sprayed orange with a bunch of stickers. It looks cool and gives it a surf wagon look, but i prefer a nice headliner. Maybe black with some orange cross stitching. Then upgrade the stereo a little. The two speakers on the dash are not quite enough. I have some stuff laying around at the house from previous builds i can throw in there. Any of you guys had trouble with your door hinges? I was going to try to find new ones, or maybe replacement pins/bushings? |
12-28-2013, 01:47 AM | #8 |
One of my favourite Burbs, I really dig the roof treatment. Does it look as cool in person as it does in pics?
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
12-28-2013, 02:13 AM | #9 |
What?
I've personally never seen or heard about these trucks having sagging door hing issues, are you sure the hinges are the problem and not striker plate shim or placement issues?
12-28-2013, 03:28 AM | #10 |
YbNorml- It does look cool. It has 3 coats of clear with orange flake and then 3 coats of clear on top of that. I think over time it will need to be repainted. I was told it was painted about two years ago. It still looks good but there are very slight hints of surface rust in areas. It is not bad at all, i just think over time it will need to be sanded down and painted. Maybe since clear is not really a sealer. Either that or it did not get every single spec off of it when it was prepped. The truck has always been garaged and i keep it garaged as well, so it should last for awhile. One day i will probably shave the handles and gas filler and repaint the car. I love the look of it but personally i would not do it again due to those reasons.
Vectorit- When i open the door,i can lift up on it and get at least 1/8". Maybe even 1/4" on one of the doors at the furthest point. I almost have to lift the door up to get it to close properly. |
12-31-2013, 01:36 PM | #11 |
PROJECT 7DEUCE
I have seen that burb all over good to see its stayin on the board ... Are you a member of sunset?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-31-2013, 07:52 PM | #12 |
No not a member of Sunset. Found about this forum while searching for the thread on the suburban before i bought it. I live in Southern California so i will try to hit as many local shows as i can.
01-08-2014, 07:17 AM | #13 |
member
The doors on the 67-72 trucks often weaken and the door itself will crack around the upper door hinge. It can be hard to see.
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
01-08-2014, 01:43 PM | #14 |
Yup, hinge bushings go bad, which leads to hard hits and the door cracking issue. LMC/Classic/Jim Carter/Brothers sell pin and hinge kits. 10 min with a hammer and BFH, once they're off.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
