Old 12-12-2013, 01:22 AM   #1
Cartelpaintshop
Help with z'ing a 68 c10 frame
I have a 68 c10 need some help zing the frame
Cartelpaintshop is offline   Reply With Quote
Old 12-12-2013, 03:45 AM   #2
tinydb84
tinydb84's Avatar
Re: Help with z'ing a 68 c10 frame
Have you tried the search button?
David
Instagram: myfabguy
Old 12-12-2013, 10:22 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
How did that help him? please dont reply if thats all you have to offer.
Please be more specific in your request. What info are you looking for? Do you need to know dimensions, required mods, or alternatives to a Z?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-12-2013, 10:29 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Look at this thread.
It shows all the work involved with a "z'd" frame.
http://67-72chevytrucks.com/vboard/s...d.php?t=607141
Keith
Convert to disc brakes.
Old 12-12-2013, 11:45 AM   #5
chevyrestoguy
chevyrestoguy's Avatar
Not sure how much of this will help, but I did a "Z" (2") on my '64, and it's detailed in my build thread posted below, starting at Post #196.
Our frames are very similar, and I think that a lot of the info will transfer to your '72. I have to tell you this before you start the job: The work of "Z-ing" the chassis is pretty simple as long as you take good measurements and try to stay as accurate as possible. Measure twice, cut once. Don't over-cut, and what I mean by that is, more is not always better. Honestly, I wouldn't go over a 2" "Z" because the higher you go, the more problems you will create. Problems like clearance between the steering shaft and the driver's side upper control arm, transmission clearance at the cab floor, drive shaft clearance at the rear of the cab, making a custom transmission mount, clearance between the top of the tire and the inner fender, and other issues. If you're willing to do a lot of fab work, then a bigger "Z" might be OK, but just prepared to do a lot more fab work.
A chassis "Z" is a very inexpensive way to lower the stance and gain ground clearance. The area where a "Z" can become a bit overwhelming is in the areas other than the chassis, meaning, everything that touches the chassis. Things like inner fenders, core support, steering, brake lines, motor mounts, and such. These items are the things that you'll wind up spending the most time on if you're trying to do a nice, clean job.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-12-2013, 11:50 AM   #6
tinydb84
tinydb84's Avatar
N2, normally I would do a search and post the links but if you look at the other threads he has started you will see at least 5 other threads that are all similar vague questions that he obviously didn't bother to search before he asked.
David
Instagram: myfabguy
Old 12-12-2013, 11:52 AM   #7
dec010974
dec010974's Avatar
Thank Lolife99. That was a very good build thread. It was on the best build threads on air bags, zeeing the frame theads, i have ever read. thanks for the information/pictures. i saved a lot of pictures. "Teach a man to fish and he eats for a life time." and a again, thanks for sharing.
dec010974 is offline   Reply With Quote
Old 12-12-2013, 12:06 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes sir, you usually do offer good advice, links, etc. I didnt mean to come across harsh, but I feel its better to not post than post with out offering assistance.
Articles-
"Refining Sierra"
Old 12-12-2013, 03:01 PM   #9
cg285
i think everyone is getting this all wrong. according to his question he didn't ask how he asked for help. i.e. give me a hand (clap clap)
cg285 is offline   Reply With Quote
