01-23-2014, 01:07 AM | #1 |
16x10 wheels fit on a 1971 K-10
I have a 1971 K-10 4x4 1/2 ton 6 lug with disc brakes. I am installing a 4" lift kit and I am looking at a set of 16x10 wheels with 4.5" backspacing. Will these wheels fit without rubbing on any of the drivetrain components? Wheel outlets only show 15" wheels available for this year (I suspect because that is factory specs.) LMC has 16x10 6 lug wheels for sale but notes that they will not fit 4wd.
Anyone running 16s? will they fit without issues? Thanks. |
01-23-2014, 01:15 AM | #2 |
Windy Corner of a Dirty Street
Re: 16x10 wheels fit on a 1971 K-10
10” is a ridiculous wide wheel. How big of tires you plan on running to need such a wide wheel? 8” wide are ideal for the typical tire you would use under a 4” lift.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
01-23-2014, 01:22 AM | #3 |
I plan on running 33x12.50 tires. I like the deep dish look of the 10' wheel.
01-23-2014, 02:30 AM | #4 |
Won't rub on the drive train with that backspacing. But they will stick out wide. Definitely deep dish. 33" tires on a 10" wide wheel can look a little funny, like the wrong proportions. Also that really negative offset from the centerline will wear out bearings and ball joints faster as well as give you worse handling as the centerline of the wheels will be further out from the steering axis.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
01-23-2014, 12:38 PM | #5 |
20' Daredevil (Ret)
In fact, 10" is the correct wheel width for a 12.50-width tire. You shouldn't have any fitment issues with a 4" lift. The truck might actually look better with 35/12.50s instead of 33s, but the taller tires might have minor clearance problems.
Back to your 33-12.50s on 10" wheels. I'm running 33/12.50-16.5s on 9.75 wheels, with 2.5" Softrides. No problems at all, but my front fenders were notched many years ago to clear a different wheel/tire combo (before the Softrides). Just eyeballing it, I don't think there would be any problems even if the fenders weren't notched. You should be fine with your 4" lift. Plenty of guys run 33s on 8" wheels, which is a bit narrow but it seems to work okay. Upside is they won't stick out as far up front, and your bearings will be happier.
01-23-2014, 03:18 PM | #6 |
They'll fit fine. You have the same axle as a K/20 which would require 16" wheels to clear calipers. 4.5" backspace on a 10" wheel is only .5" off center,so no ill affects from excessive offset. Us old timers all ran 10" nominal width wheels with 12" nominal width tires. Only more recently has the school of thought turned to running 8" with that width tire. If you look at recommendations you will see 8-10" wheel,so simply a matter of taste. You will throw more slop up on your truck with 10s. But the actual tread will be under the top of the wheel openings. An 8" wheel with a 10.50 tire is the same proportion and anything less is getting too narrow. The wider the tire the more variation allowed.
01-23-2014, 05:40 PM | #7 |
I agree that the 33" tire will fit on a 10" wide wheel just fine. But trust me the proportions look a little funny. I used to run these on my bronco on a 10" wheel.
However a 10" wide wheel is actually 11" edge to edge. So a 4.5" offset is actually 1" from the centerline. Also you will note that stock steelies would have a positive offset, putting the wheel centerline closer to the steering axis. So 1" negative offset is even further away than what the engineers designed for. I know I didn't like the extra offset when I had wheels with 4.625" of backspace. But it will work! Just my two cents.
01-24-2014, 10:55 AM | #8 |
I'm just speaking from experience. I never experienced any negative effects/premature wear from offset with the various vehicles I've run 10" on,nor have heard of any from the scores of people I've known to run them. It's truly just a matter of preference and,more recently,8" is most preferred,including me. The whole purpose of wider track wheels and tires was floatation,and that is what the proportions say to me. My '85 Jimmy runs 10" wheels (originally on my '91 Burb) because the most off road use it sees is on the beach=flotation/no snow. In my case,I run various sets of wheels/tires for various uses to run between my 8-lug trucks.
These are going on my '72...8.25 x 16.5s with 37/12.50 SSRs. They will allow less lift and give the (a lot) beefier than stock look I'm after. But,I also have a set of 9.75 x 16.5 aluminum slots with 35/12.50 BFG A/Ts for flotation and '70s era custom look
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-24-2014 at 11:05 AM. |
01-24-2014, 11:15 AM | #9 |
I dig those SSRs! I would have bought a set if they weren't so stinking expensive. Let us know how you like them once you start driving on them.
01-24-2014, 02:18 PM | #10 |
This will give you and idea of what it will look like. I have a 2.5" lift and the rims are rockcrawler 16X10. The tires are Intero TRXUS 33/12.50/16.
I have gone back to the ford steel rims and 285/75/16 tires. I had some rub on the front fender when turning, and since this truck is not a hiway queen I was afraid of tearing up my fenders and tires. I also did not like the wide stance look. I still like tall skinny tires on these old trucks. No worries about the wide tires and rims......I've got an old blazer I use for hunting that they are going on.
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
01-24-2014, 11:01 PM | #11 | |
And jrdv,that's about what I want once I'm done with the bigger stuff,2"-4" lift with maybe 255/85s or 285/75s on Ford wheels or 4" lift,35/10.50s on 8". Here's one with about 4" lift,285/75s,and Ford 7" wheels:
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-24-2014 at 11:26 PM. |
