Old 03-11-2014, 09:33 PM   #1
hotrod1
56 - autocross
hotrod1's Avatar
Transmission Tunnel Build
So I need to build a transmission tunnel. Moved the engine back far enough to change this now.
Anybody have any pics of their mod or know of a build that shows options? I need ideas.
Thanks in advance!
hotrod1 is offline   Reply With Quote
Old 03-11-2014, 10:33 PM   #2
Kim57
Kim57's Avatar
Re: Transmission Tunnel Build
Here's what i did. Built the frame out of some steel rod and then covered it.
Would have been a lot easier if I had a roller to put a curve in the sheet metal first.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-12-2014, 12:05 PM   #3
RedneckRodder
RedneckRodder's Avatar
Are you looking for a rounded one like Kim did, or squared off corners? Most folks use poster board to design it, then transfer that to sheet metal.
I've heard of people using an acetolene bottle and a ratchet strap to form the curves, or for the squared corner style you can just throw a piece of sheet in a press brake and form it that way. I even have a buddy that modified an old John Deere model 40 hood to make one for his '48 Ford pickup.
Its all in what you like and the style of the build.
RedneckRodder is offline   Reply With Quote
Old 03-12-2014, 06:28 PM   #4
55dude
55dude's Avatar
Kim
super clean!
55dude is offline   Reply With Quote
Old 03-12-2014, 06:32 PM   #5
FarmerSid
FarmerSid's Avatar
Thanks in advance!
AD or TF? If AD, Check out Nsane, Xpickup or 99 to Life's builds. Great idea's. Just a few off the top of my head.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 03-12-2014, 10:34 PM   #6
BlueJeep
BlueJeep's Avatar
Here's mine:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-13-2014, 03:53 AM   #7
msaintg
msaintg's Avatar
i just cut mine out of the donor S10 vehicle.
msaintg is offline   Reply With Quote
Old 03-13-2014, 12:47 PM   #8
nacho55
http://67-72chevytrucks.com/vboard/s...d.php?t=566811
Here's the link on this topic and what a lot of us did, the bottle trick works good,
nacho55 is offline   Reply With Quote
Old 03-13-2014, 04:23 PM   #9
RusteeNutz
Would you still need to create the hump if installing a 350 motor and Th350 trans?
RusteeNutz is offline   Reply With Quote
Old 03-14-2014, 05:31 PM   #10
_Ogre
_Ogre's Avatar
i have a 350 w/ 700r4 trans and had to do a minimal mod on the stock trans cover because i moved my motor back an inch
in stock location a 350/350 will fit without any modification to the floor
shop air compressor timer
Old 03-14-2014, 08:39 PM   #11
focusedontheprize
focusedontheprize's Avatar
@BlueJeep and Kim57: Very clean and quality builds
focusedontheprize is offline   Reply With Quote
