Old 01-19-2017, 08:43 PM   #1
tinydb84
tinydb84's Avatar
My brother's Nova
Started back on my brothers 72 Nova. He bought it years ago and it had an oil leak in the pan.
We put the engine back in and it had another leak. It sat like this for a few years.
David
Instagram: myfabguy
Old 01-19-2017, 08:44 PM   #2
tinydb84
tinydb84's Avatar
Re: My brother's Nova
We didnt take any pictures of the front suspensioon upgrades. The front end was updated with disc breaks, drop spindles, and new control arms.
I finally convinced him to start on it again.
I started patching and shaving the firewall.
Someone caught me welding.
Little epoxy until I can do the bodywork.
David
Instagram: myfabguy
Old 01-19-2017, 08:45 PM   #3
tinydb84
tinydb84's Avatar
Changed out the master cylinder.
New stainless lines.
David
Instagram: myfabguy
Old 01-19-2017, 08:45 PM   #4
tinydb84
tinydb84's Avatar
Then started an LS swap. Running a LQ4 with 243 heads and a 230ish duration cam. Sorry for the shtty Instagram pic.
Tried 3 different oil pans. None fit well enough to run without modifications.
Tacked in.
Boxed in.
David
Instagram: myfabguy
Old 01-19-2017, 10:41 PM   #5
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Looks like a great project.
Zoomin is offline   Reply With Quote
Old 01-26-2017, 03:17 PM   #6
tinydb84
tinydb84's Avatar
Thanks Zoomin. Since I am spending my brother's money this one might get done a bit faster than my build.
Put the pump and sending unit dropped in the tank
Mated the engine and trans
Dropped the engine in on the stock stands
Engine fit fine but the pan hung too low
David
Instagram: myfabguy
Old 01-26-2017, 03:18 PM   #7
tinydb84
tinydb84's Avatar
Decided to make new motor mount towers rather than buy all new mounts. Made a jig to hold everything in place.
Cutting some tabs
http://s20.photobucket.com/user/Tiny...43741.jpg.html
Picked this up at the craft store. Works great for laying out radius.
Also got these tab magnets from Strong Hand Tools. Makes holding the tabs much easier.
Mounts burned in.
David
Instagram: myfabguy
Old 01-26-2017, 03:18 PM   #8
tinydb84
tinydb84's Avatar
Engine going in.
Engine in.
Moved the engine up and forward one inch. Seems to clear everything really well. Need to make the trans crossmember next.
David
Instagram: myfabguy
Old 01-26-2017, 08:34 PM   #9
Advanced Design
Advanced Design's Avatar
Cool project, tagging along.
Advanced Design is offline   Reply With Quote
Old 02-20-2017, 08:38 PM   #10
Joe Pass
Joe Pass's Avatar
Well,, there goes the new neighborhood...lol
Joe Pass is offline   Reply With Quote
Old 02-20-2017, 10:05 PM   #11
Rickysnickers
Cutting some tabs
Mounts burned in.
Very nice welds!!
Old 03-02-2017, 03:07 PM   #12
tinydb84
tinydb84's Avatar
Thank you, hopefully you will like what you see.
This neighborhood was gone before we got here. I am in a constant battle with people abandoning their cars on my street...
Originally Posted by Rickysnickers View Post
Very nice welds!!
Thank you. I had intended to tig it all together but it was such a tight fit in the engine compartment I got lazy and mig'd it all in.
David
Instagram: myfabguy
Old 03-02-2017, 03:07 PM   #13
tinydb84
tinydb84's Avatar
I think my brother is pretty motivated since we have been making good progress. He has been coming home from work to get **** done.
I filled in all the extra holes that were drilled in the floor and raised up the tunnel just a bit to give us a bit more space around the transmission:
My brother stripped all the rust and brushed on some epoxy (we were too lazy to strip the floors):
Got some knock off dynamat:
Applied it to the areas that sounded hollow when we knocked on them:
Put a layer of closed cell foam to act as a decoupler:
Then mass loaded vinyl on top:
Still need to work it down on to the floor more. The stuff is thick and hard to shape.
David
Instagram: myfabguy
Old 03-02-2017, 03:10 PM   #14
tinydb84
tinydb84's Avatar
He ordered his headers (didn't get a chance to take a pic yet). I welded in his O2 bungs while he was doing the floors.
Not the prettiest tig but it will do.
David
Instagram: myfabguy
Old 03-06-2017, 01:39 PM   #15
tinydb84
tinydb84's Avatar
Long weekend of really crappy work! Pulled the engine and stripped the engine compartment and underside of the car for paint.
The car hand an oil leak for years. There was so much crud we pressure washed and degreased multiple times.
I thought the car was black underneath...apparently it was just dirt and grease.
My brother wire wheeling away.
David
Instagram: myfabguy
Old 03-06-2017, 01:39 PM   #16
tinydb84
tinydb84's Avatar
I did a bit of body work on the firewall.
Blocking to check for highs and lows.
Did a bunch of hammer work and first pass of filler.
Masking.
Spraying.
First coat and bad lighting.
David
Instagram: myfabguy
Old 03-15-2017, 01:07 PM   #17
tinydb84
tinydb84's Avatar
Here is a better pic of the engine compartment. Broke all three bolts to the wiper motor so now we need to deal with that.
The nice thing about working on his car is that I don't have to do any of the dirty work. He spent the last week finishing stripping, cleaning, and painting the underside of the car.
Didn't bother with the rear end or the leafs because we will likely pull it out at some point to either rebuild it or replace it with something stronger.
He started pulling the engine apart for paint.
David
Instagram: myfabguy
Old 03-15-2017, 02:00 PM   #18
Joe Pass
Joe Pass's Avatar
Lookin good....
Old 03-15-2017, 04:12 PM   #19
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice Nova and cool project! Nice welding and fab work too. That will be a sweet ride when you guys are done with it. Do you plan to heat up the foam to get it to lay down better? I haven't tried any of that but may some time.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-15-2017, 04:30 PM   #20
tinydb84
tinydb84's Avatar
Lookin good....
Thank you sir.
Thank you. The foam laid down fine. It also has a sticky side so it conforms to the floor where it is applied.
The MLV on the other hand was a pain! He cut it in sections and laid it down horizontally. Once it was cut to length he used a combo of heat gun, a few relief cuts, and aluminum tape to get everything in place and sealed down.
David
Instagram: myfabguy
Old 03-27-2017, 02:46 PM   #21
tinydb84
tinydb84's Avatar
Started putting the fuel system together. Never used push lock hoses before. Not as hard as everyone says. Froze the fittings, heat gunned the hoses, a bit of tranny fluid for lube and ta da!
Modified an old exhaust bracket to mount the roll over valve.
David
Instagram: myfabguy
Old 03-27-2017, 02:46 PM   #22
tinydb84
tinydb84's Avatar
My brother started to assemble the engine. New TCI converter and flywheel.
Together.
No pics but my brother started scrubbing it clean and scuffing it for paint. Hope to get it in by this week since I am out of two for the next two weeks.
David
Instagram: myfabguy
Old 03-27-2017, 10:11 PM   #23
Joe Pass
Joe Pass's Avatar
You're doing it right...very cool
Old 03-29-2017, 01:12 PM   #24
tinydb84
tinydb84's Avatar
Thanks. He wasn't initially planning on doing this much work but it has been coming out well and I think that has been motivating him to keep doing more work. Not bad for a garage build!
David
Instagram: myfabguy
Old 03-29-2017, 01:13 PM   #25
tinydb84
tinydb84's Avatar
My brother finished prepping and masking the engine.
Then shot it with Eastwood's 2k Aero Spray Ceramic Engine Paint.
The paint sprays out like a gun but has quite a bit more overspray. There isn't much paint in each can as you would think. He got about one coat per can. It has isocyanates in the paint to so be extra careful. He is going to add an additional coat today. Kinda regret not buying a clear for it.
David
Instagram: myfabguy
