Old 05-14-2017, 02:54 PM   #1
oldtrux
oldtrux's Avatar
steering shaft question
hi all,purchased an ididit retrofit tilt column.looking for opinions on steering shaft,
collapsable or solid.steering box is 3/4 x 30 spline,column is 3/4 x 36 spline.
any thoughts??
oldtrux is offline   Reply With Quote
Old 05-15-2017, 09:47 AM   #2
AcampoDave
AcampoDave's Avatar
Re: steering shaft question
Collapsible is safer and in my opinion the way to go.
AcampoDave is offline   Reply With Quote
Old 05-15-2017, 10:08 AM   #3
vince1
Rag joint with two different spline count halves? Borgeson Joint?
Definitely collapsible. From a safety aspect, the box is way too close to the front for a straight shaft. I knew a guy that got speared by one. It only happened once.
vince1 is offline   Reply With Quote
Old 05-15-2017, 01:41 PM   #4
61K10
61K10's Avatar
these kits are avl. a new piece that bolts to the rag joint. double d that slides into that piece and a u-joint to the column from the DD shaft.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-15-2017, 08:22 PM   #5
oldtrux
oldtrux's Avatar
thanks guys!collapsable it is!
Old 05-15-2017, 09:33 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Do you have the part #s ?
66 C20 Service Truck:
Old 05-16-2017, 09:19 AM   #7
oldtrux
oldtrux's Avatar
if you look on the borgeson website you can piece it together for your'e application
with rag joint,collapsible shaft and coupler for column end
Old 05-16-2017, 07:28 PM   #8
LostMy65
LostMy65's Avatar
Yeah, I've been browsing their site.
I guess I don't know exactly which pieces I need for a 65 2wd.
I even sent them an email asking. They still haven't replied.
I just figured if someone ordered such and such pieces and it worked, then I could just order the same.
I'll keep researching.
Old 05-16-2017, 07:58 PM   #9
oldtrux
oldtrux's Avatar
i ended up ordering borgeson 3/4 DD x 3/4 x 30 vibration u joint for the steering box end (my box is 3/4 x 30 spline )part#154931 (stainless)
column end u joint (stainless) 3/4-36 spline x 1'' DD part # 113452
collapsible shaft part #450024 they also have 36" but i don't think we need that long
just have to check your steering box spline size and your column end spline size
funny,i emailed them and they got back to me within minutes.maybe they got busy.ordered through summit.hope this helps....dan
Old 05-16-2017, 08:33 PM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
So the shaft itself is 24" long. https://www.borgeson.com/xcart/produ...&cat=22&page=1
Old 05-16-2017, 08:43 PM   #11
LostMy65
LostMy65's Avatar
Thank You!
Old 05-16-2017, 08:50 PM   #12
LostMy65
LostMy65's Avatar
Amazon Link:
https://www.amazon.com/Borgeson-1549.../dp/B004A65U0A
Old 05-16-2017, 09:05 PM   #13
LostMy65
LostMy65's Avatar
Here's the other thread I've been posting in:
http://67-72chevytrucks.com/vboard/s...d.php?t=668946
Old 05-17-2017, 12:38 AM   #14
The Rocknrod
Moderator
I've been watching you ask the same question for day's.
What is the part number?...
Hope you find it and share it with all of us.
