Old 11-19-2017, 03:06 PM   #1
vannatta20
vannatta20's Avatar
Budget Square Body Build with Gen IV LS power
I did a thread years ago on a budget build ls swap for the 67-72 trucks http://67-72chevytrucks.com/vboard/s...d.php?t=517347
Now its time to put into action everything I have learned over the years.
My dad found this truck for cheap on his way to the lake. It has a SBC and turbo 350 with A/C. Everything is worn out and he wants to daily driver. I now prefer the Gen IV drivetrains due to the much better 6 speed transmission. These have a 4.1 first gear instead of the 3.1 in the 4l60E. They handle good power and will shift up to .300 of a second. We acquired a 2012 5.3 LMG engine and 6L80E 2wd transmission. I have done a handful of gen iv swaps on muscle cars and early trucks. The power is incredible and the ability to roast the tires at will is awesome with stock un-modified engines. This truck will even have cruise control, tap shift, and a/c control all through the Gen iv computer.
vannatta20 is offline   Reply With Quote
Old 11-19-2017, 03:08 PM   #2
vannatta20
vannatta20's Avatar
Re: Budget Square Body Build with Gen IV LS power
The engine mounts are a new design. These give great clearance for headers and use a modern hydraulic filled rubber mount to make a smooth running engine.
Old 11-19-2017, 06:47 PM   #3
vannatta20
vannatta20's Avatar
Cab and body off. My dad will do as much as the work as possible to keep cost down. The entire build included the cost of the truck should be under 10K.
2900$ for the engine and transmission
1800$ for the truck
200$ powder coat the chassis
200$ fuel tank and new pump
Frame shortened and power coated
Old 11-19-2017, 06:49 PM   #4
vannatta20
vannatta20's Avatar
Engine and trans fitted.
Old 11-21-2017, 02:34 PM   #5
Low Elco
Man, Yall ain't jokin'! Are you gonna delete the dod?
Low Elco is offline   Reply With Quote
Old 11-21-2017, 09:00 PM   #6
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Nice! Keep it up!
--Josh
Old 11-21-2017, 09:06 PM   #7
Advanced Design
Advanced Design's Avatar
Very cool, tagging along. Good idea on the engine mounts!
Advanced Design is offline   Reply With Quote
Old 11-23-2017, 11:05 PM   #8
vannatta20
vannatta20's Avatar
Would like to delete it but then it snowballs into a cam swap and spending more$$
Old 11-23-2017, 11:12 PM   #9
vannatta20
vannatta20's Avatar
Hopefully test fire it tomorrow 😊
Old 11-26-2017, 08:13 PM   #10
rusty76
rusty76's Avatar
I’ll follow
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-26-2017, 08:15 PM   #11
vannatta20
vannatta20's Avatar
https://youtu.be/mMSOzuGpyiw
[youtube]mMSOzuGpyiw[/youtube]
Successful first start!
Anyone know how to embed a YouTube video?
Old 11-26-2017, 09:05 PM   #12
Advanced Design
Congratulations on the first start. Everything is looking very good.
Old 11-29-2017, 08:01 AM   #13
mcmlxix
Collector of Projects
mcmlxix's Avatar
Ok.. I'm following along as I have a 78 2WD Blazer I think I may do a budget swap on...
Rich
1972 K5 Blazer CST Click HERE
Old 11-29-2017, 10:08 PM   #14
StorminNorman
That engine seems to sit pretty far forward, Did you have to do that for trans tunnel clearance ?
StorminNorman is offline   Reply With Quote
Old 11-29-2017, 10:55 PM   #15
vannatta20
vannatta20's Avatar
It is standard position. Same as our last swap
Old 11-30-2017, 04:14 AM   #16
mcmlxix
mcmlxix's Avatar
I like the idea of the hydraulic mount, but it looks like its welded directly to the front cross member. It also looks like you eliminated the brace that the original mount was bolted to and would triangulate the frame to support upper control arm. Looking at it, I would be worried about flex/deflection on the frame under cornering load from the upper control arm.
Do you have plans to brace the frame?
Rich
Old 12-02-2017, 12:02 AM   #17
vannatta20
vannatta20's Avatar
Good point. My dad will probably weld it up to help stop any flex
Old 12-21-2017, 11:30 PM   #18
vannatta20
vannatta20's Avatar
More progress. LS3 exhaust manifold fit nicely
Old 12-22-2017, 02:02 AM   #19
mcmlxix
mcmlxix's Avatar
Do you have a PN for the motor mount you used?
Rich
Old 01-27-2018, 12:45 AM   #20
higgiec10
higgiec10's Avatar
Update nice build
higgiec10 is offline   Reply With Quote
