Collector of Projects
Intermittent Wipers for any 67-72 truck
Found these and thought someone might be interested...
First is a module to convert your existing wiper http://www.revolutionelectronics.com...-wiper-module/ GM Intermittent Wiper Module Upgrades classic GM vehicles to include three intermittent wiper delays in addition to the stock slow and fast speed options. Utilizes the stock two speed wiper switch and motor for a totally stock appearance. Designed to work with GM two-speed, non-hiding wipers. Will not work with hiding (recessed park) wiper motors. Add intermittent wipers to your Chevelle, Nova, Caprice, El Camino, Corvair, Camaro, Firebird, trucks, etc. New software now works with C2 Corvettes (make sure you tell us so you get the latest software if you need this for a '63-'67 Corvette.) Yes, it works great with the '67-'72 Chevy Trucks! (Installation photos here) One year warranty $71.99 PN 13009 (GM cars and trucks from the 60's and early 70's with factory two-speed, non-hiding wipers) ![]() Second is a replacement motor with more speeds https://www.detroitspeed.com/1964-19...iper-kit.html# Selecta Speed Wiper Kit A downpour of rain will no longer hinder your ability to clearly see the road. This kit provides you with the performance and convenience of a late model wiper system in a package that easily and cleanly mounts in your truck. The wiper kit contains a low profile, seven-speed wiper motor with 5 delays, low speed, and high speed, rotary switch, adapter plate, and wiring harness. The CNC aluminum adapter plate mounts the wiper motor to the stock firewall bolt pattern and requires no permanent modifications to the vehicle. The supplied wiring harness uses the factory wiper grommet opening and requires no cutting of the factory harness. New improved features include: •Easier Installation: The wiper switch and wiring harness plug into a wiper control module located under the dash. The wiper motor connector is already installed on the wiring harness, saving you from having to pin out the wiper motor connector. The wiring harness has also been simplified with new wiper control module design. •Push Button Windshield Washer Function: The seven position rotary wiper switch now features a push button function for a windshield washer option. Once the push button function is released, the wiper blades cycle 3 times just like your current OEM vehicle. The wiper blades then continue to operate at the last switch position. The wiring harness includes a weather pack connector/harness for an inline windshield washer pump. •Smaller, Lighter Wiper Motor: Modern OE wiper motor design is more compact for a cleaner look giving you more room under your dash. P/N: 121632 Applications: 1967-1972 C-10 $575.00 ![]() |
Re: Intermittent Wipers for any 67-72 truck
Now that is just fabulous. When I win the lottery I am going for the motor assembly. Or maybe I could stop playing and just save up for this...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
WOW!
$575 is a little pricey.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
Only moisture my truck sees is dipsy water
But yeah that's cool.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
Why not support a board member here? Twouvakind has delay wiper modules for sale. I bought one a couple of years ago and works perfect, plugs right in. Contact him or search his UN.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
are they the 575 kind ?
Stan 67 swb BLU MULE posted via flip-fone |
That was for the new 7 speed motor with all switches and hardware needed to mount it in the 67-72 trucks.
Not goin in the rain wit the mule .. she cant swim
#9 | |
Thanks for posting mcmlxix ![]() |
#10 | |
Old member
Extra switches! Tacky... huh! You people think everyone should like the things you do! I can't understand it, why is it you just can't keep your mouth shut about something that you personally thinks tacky! The only thing tacky is your response.
As far as the extra switch goes it looks right at home on most trucks and if it weren't for this board most of you wouldn't even know what was stock on one. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by 70cst; 01-03-2018 at 12:21 AM. |
#12 | |
#13 | |
#14 |
I dont think you said anything wrong, please dont stop posting good informative info, I liked it!
#15 |
I like what you did. You did a lot of great mods on your build.
#16 | |
![]() Join Date: Feb 2001
Andy4639 ... lets settle down a little. We all have opinions which is good but lets not go over board with responses ... Thanks
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#17 | |
Old member
![]() Quote:
If he can express his why can't I? ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#18 |
I never called his work tacky. His work is great. That's why I bought his product over the ones above. Actually I bought 4 of them. Work great. Couldn't be happier. I don't like extra dials buttons switches etc. On my dash and neither did the member that posted before me so I simply offered a solution to make it suit his needs so maby if he likes that he will purchase from twoofakind instead of the others not on the board. Even posted a video using twoofakinds unit. Anyway this thread is about intermittent wipers not defending what is right or wrong so let's get back to that.
#19 | |
The Older Generation
The problem being, he posted an opinion, you attacked him personally because of his opinion. My 2˘. LockDoc
#20 | |
I also said I liked this OP's solution better personally, and want to be free to express that. I like to solve problems and be able to share that info with others. We can all choose to buy what we like. Also, It is good that there are folks here who sell various supplies but that does not make them sacred by any means. Its a plus that most sell superior quality goods. But remember, anyone with $20 can sell here, what makes that special exactly? I like that the OP's posted product solves this solution much simpler and is a better design that simply uses one original switch instead of two for same operation. Watch the video, he also makes dome light dimmers, headlight/radio relays etc. |
#21 |
Old member
So, as I stated before his opinion is ok but mine not!
And yes you called his added switch tacky but yet you bought them to make yours. OK that's fine. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-03-2018 at 01:31 PM. |
#22 |
Moderator
![]() Join Date: May 2007
Thanks for posting up your idea Rod, please continue posting and contributing to the board and do not let one persons opinion affect your coming here.
I’m not going to even bother telling anyone to settle down, they will just keep posting and arguing and jawing cause they have nothing better to do... it’s like talking to a cinder block, so the thread is now closed.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
