06-17-2019, 09:38 PM | #1 |
67 Chevy c20 250 thermostat housing leak
I have a stock 67 Chevy truck 250. I tried fel-pro gasket twice and I also tried black rtv . I lightly Sanded and made sure everything is clean and smooth. I'm using the blue composit fel-pro gasket. Both times I didn't use and gasket sealer ... I cant get nothing to work it's a light leak. Any ideas or part numbers would be great guys thanks. The thermostat housing where it bolts to the head...
06-17-2019, 11:02 PM | #2 | |
The Older Generation
Re: 67 Chevy c20 250 thermostat housing leak
Are you sure it isn't cracked? I would try another housing. How does the flange on the head look? LockDoc
06-18-2019, 07:27 AM | #3 |
Don't see any cracking. Flange? It's just a flat surface that it bolts 2 on the head
06-18-2019, 01:29 PM | #4 | |
Just different terminology, we are talking about the same thing..... It could also be cracked. You obviously have something else going on besides a leaking gasket. LockDoc
06-18-2019, 05:50 PM | #5 |
I think I have a spare 250 t stat housing at home, ill dbl chk for you in case you need it
1967custom |
06-20-2019, 10:22 AM | #6 |
Could I use k seal to fix this
06-20-2019, 01:20 PM | #7 |
All they have are aluminum thermostat housing for these ... thoughts?
06-23-2019, 12:59 AM | #8 | |
It's steel or cast iron. Has 1/2'' plug for a temp probe, too.
