Pro-Touring rear axle widht ??
Guys,
I would need to order new rear axle for 69 C10. I have DSE quadra link with bolt on brackets and plan to use 13 x 19" rear wheels in future. But before I can order wheels, I need the rear axle. What is the recomend rear axle widht ? |
#2 | |
The Older Generation
Re: Pro-Touring rear axle widht ??
I will have to ask my friend what the custom rear end width is on his build. Here is a thread that I posted about it: http://67-72chevytrucks.com/vboard/s...d.php?t=851312 .
67-72 parts collector,…
![]() Join Date: Nov 2002
I recommend getting the wheel/tire combo and then ordering a rear axle to place them exactly where you want them under the truck.
![]() Join Date: Dec 1999
This is custom stuff. The axle width would be determined by the amount of backspace of the wheel with needed clearance in fender well. Many like the look of a wide "lip" on the rear wheels which would require a narrower axle. The 13" wheels with a 6" backspace would look good. You are also maybe creating more issues by needing temporary wheels to use for a time. If wheel reveal is not important just make axle stock width and have wheels made to fit.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
My 8.8" out of an Explorer is 56.5" wide from WMS to WMS. I have a 13" wide rim with 2.75" BS. The smallest they will make the backspace is 2.5". They are 20" wheels and 28" overall height.
#6 | |
Post Whore
![]() Join Date: Feb 2016
Get the tires mounted on the wheels and mock them up in your truck, at ride height, then you can determine the clearance on both sides of the tire and when your satisfied measure your width between the wheel mounting surfaces for your axle width.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
