![]() Join Date: Apr 2005
I'm trying to wire up my cargo light that was converted to a third brake light. I mounted it to the hatch not problem. However I am having a problem going through the header panel that the hatch is attached through. I thought I could snake it through the where they hinge bolts up, but that turned out to be a closed in pocket. I even drilled through the pocket, but that was a dead end also. If you look at a the third picture with the yellow arrow there is a factory bolt in the bend of the header panel. Can someone try to snake a wire up through there to the roof? I would do it myself, but I welded it up before we did the paint work,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: Need a little help...
Too bad on the timing. A month ago I could have snaked a camera up there on mine:
Dang, that would have really helped.
I snaked a wire through the bolt hole and it does go into the D pillar.
Will it come out the overhead with the headliner removed?
#6 | |
