Speedometer correction help
So having an issue on my 82 GMC K1500, Somehow my speedometer was pretty accurate (GPS Verified) with stock 3.08 gears and the 32s I put on. I now just did a 3.73 gear swap and naturally the speedometer was 10 MPH fast. So I did the math and ordered a 42 tooth green gear and pulled out my 40 tooth black gear and the speedometer didn't change... still read 10 MPH fast exactly.
What can possibly cause that with a mechanical speedometer? Note also, this has cruise control so the cables come from there first before the gauges.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4 1988 GTA Trans AM 305 TPI 700R4 1993 Formula Firebird LT1 T56 1995 GMC K2500 ECLB 6.5L 4L80E 1996 GMC K3500 CCLB LB7 6L90 |
![]() ![]() Join Date: Jul 2002
Re: Speedometer correction help
With my last truck when I went from 3.73 to 3.08s, I never could get it accurate with just changing the speedometer gear. The more research I did, the more I was going to need to change the gear on the output shaft also to get it right. I was too lazy to doi that, so I just drove with the tach and had a calculated cheat sheet on the RPM to speed I needed. Sometimes I even used the phone GPS.
Saw another post talking about this. https://67-72chevytrucks.com/vboard/...d.php?t=656949 I was thinking out loud about yours is a K and bet transfer case has some play in that.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 10-05-2021 at 07:09 AM. |
![]() Join Date: Feb 2000
You need a ratio adapter gear box to correct the speedometer. The guys at https://transmissioncenter.net/ made one for me and its dead on.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
![]() Join Date: Mar 2003
3.08 to 3.73 is a 17.5% difference. 40 to 42 teeth is a 4.8% difference. Doing a speedo is percentages. You can be off 10mph but it will be at a specific speed it will not be constant throughout the range
I found notes from when I had the ratio adapter made for my truck- this was 12 years ago so just going off my notes here:
Drive 10 miles according to your GPS Divide odometer reading by 10 = % the odometer is off Count the # of teeth on gear in the transfer case Multiply the # of teeth by the % the odometer is off = # of teeth needed When I called the transmissioncenter.net they explained this over the phone on how to do this. I ended up with a 16% increase ratio adapter and it matches the GPS.
Thanks for the tips guys, apparently the site I used to do the math wasn't right I guess.
#7 | |
Old Heap Driver
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
![]() Join Date: Apr 2005
I used this place: https://speedometercablesusa.com/gear_box_adapters.html
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Moderator
![]() Join Date: Oct 2008
You don't necessarily need a ratio box.
It depends on the transfer case. The NP205 and NP203 need ratio boxes. The NP208 uses the same drive and driven gears as the TH700R4. The parts books have tables for selecting speedometer drive and driven gears based on axle ratio and tire sizes. You can download the parts manuals from the manuals thread.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#10 | |
Moderator
There's a drive and a driven gear.
The drive gear is on the end of the transmission/transfer-case mainshaft. The driven gear is on the end of the speedometer cable. The 3.08 axle ratio requires an 18 tooth drive gear. The 3.73 needs a 15 tooth drive gear so you're going to have to change it. You'll have to pull the output shaft housing off the transfer case to access the driven gear. The 42 tooth driven gear paired with the 15 tooth drive gear is for 28" diameter 215/75R15 tires. The 40 tooth gear paired with the 15 tooth gear is for the L78-15 40" diameter tires. Pay attention to the markings on the aluminum driven gear carrier. It needs to be clocked to match the driven gear size used. Download the 1979-1984 parts and illustration books from the manuals thread linked in my signature. The speedometer gear tables are in the middle of the parts book in section 4S. The 1982 speedometer gear tables start on PDF page 1023. You'll need your tire size and axle ratio. The TH700 is the same speedometer gear setup as the NP208. There are 50-80 pages of tables in the parts book showing what combination of drive/driven gears you need for a given axle ratio, tire size, and transmission along with the GM part numbers and the color plastic GM originally molded them out of. If you refuse to download your own copies of the parts books this link is to Ian Hardings' GM Parts Wiki in roughly the right place to start looking. Ian has copies of my scans as well as other parts manuals other folks have scanned and Ian has scanned. The ones you're downloading from the manuals thread are the exact same thing as GM Parts Wiki. http://www.gmpartswiki.com/getpage?pageid=59796
And please let us know if and how your repairs were successful. Last edited by hatzie; 10-08-2021 at 10:00 PM. |
