Old 02-14-2022, 04:55 PM   #1
Ziegelsteinfaust
Someone say Gulstrand???
https://i.imgur.com/eMWbqvZ.jpeg
https://i.imgur.com/3c9RMDm.jpeg
https://i.imgur.com/Z2k87H9.jpeg
Dick Gulstrand is a genius. Typically its 4 holes to legendary, but the stamping is a bit different here.
Ziegelsteinfaust is offline   Reply With Quote
Old 02-14-2022, 10:03 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Someone say Gulstrand???
We went up with the upper.
2° camber change thru the travel.
Looks like you might have some undesirable camber changes
Old 02-14-2022, 10:30 PM   #3
Ziegelsteinfaust
It is slightly more then a regular Gulstrand mod, and close to the improved version.
Last time I did it. It worked pretty well.
The 2nd part of the Gulstrand mod is moving the Upper a arm back will be accomplished by moving the lower arm forward. As per the typical C10 way.
If not there is not mix up a grinder can't fix up.
Old 02-15-2022, 04:13 AM   #4
theastronaut
theastronaut's Avatar
Why not just add a taller upper ball joint for the same effect?
With 1" narrowed arms (quicker angle change for more camber gain) and .50" taller upper ball joints my C10 had -1.6 degrees gain per inch of travel compared to -.86 per inch stock. You also gain camber when turning with a lot of caster so you may want to map out exactly how much camber gain you're getting to see if you actually need that much.
theastronaut is offline   Reply With Quote
Old 02-15-2022, 10:09 AM   #5
Ziegelsteinfaust
Mostly being cheap, and I love welding to get my mind off of Life's B.S.
As for the mod. I think of it as the icing on the cake of the traditional mod of moving the lower A arm forward. Needed no, but adds a little bit of confidence to the end off tire grip or your limits. What ever happens first.
I want to learn how to measure suspension gains one day. My uncle gave me a old kit he had for rebuilding rear ends. Which has the guage to measure the run out is it?
Plus I have another C20 crossmember I will mod, rebuild, and store for my future square body Suburban or crew cab. I need a matching pair. Come to think of it. I like pairs of other things too.
