01-15-2011, 10:28 AM | #101 | |
Re: My 84 CC Dually mod thread - there will be plenty of pics
The rear shock clears the tank. Posted via Mobile Device
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE |
01-15-2011, 11:23 AM | #102 |
Amazon.com: Smart Eraser Pad with Drill Adaptor...you can use one of these to remove all that adhesive from where you removed the trim i have used em they work great just fyi
01-15-2011, 11:08 PM | #103 | |
01-15-2011, 11:17 PM | #104 |
Some updates....
- modified original crossmember to be used as rear tank mount - a bunch of cutting and welding - decided to not c-notch the frame at this time. I will see how the truck rides this summer and if I find it bottoming out then next winter I will yank the bed again and install the c-notch - tank should be mounted tomorrow Posted via Mobile Device
01-15-2011, 11:23 PM | #105 |
It followed me home?
Damn you are making some good progress! Its looking great. Looks like you know what you are doing but I can't see why you wouldn't notch it now? Beds already off why mess with it later? Anyway I'm liking the project!
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-16-2011, 12:04 AM | #106 | |
01-16-2011, 12:32 AM | #107 | |
01-16-2011, 09:54 AM | #108 |
I thought so too
01-16-2011, 10:09 AM | #109 |
C35 Crew Dually
Great progress trucks looking very nice!
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
01-16-2011, 10:31 PM | #110 |
Tanks mounted....
01-16-2011, 10:41 PM | #111 |
Decided to tackle the hinged tail light door for the hidden gas fill. I have about 5 hours in the build. It's pretty close, I have some small adjustments to make and then pretty everything up but it's functional! Next will be to start building the custom filler neck!
01-16-2011, 10:44 PM | #112 |
filler is going to be cool. Please slow down with all the work you are making me feel like I get nothing done haha
01-16-2011, 10:45 PM | #113 |
Some more....
01-16-2011, 11:02 PM | #114 |
C35 Crew Dually
That filler cap is a great looking piece great work!
Question. On your rear shackle and hanger kit whats with the home on the hanger you made just a lil more drop or alignment issues? Reason i ask is i'm in the process of buying the same rear kit.
01-16-2011, 11:11 PM | #115 | |
Yes I drilled the second hole to gain a little more drop. I was able to move the hole up 1.25" which gave me another 5/8" at the axle. Every little bit helps Posted via Mobile Device
01-16-2011, 11:13 PM | #116 | |
Hahaha, spring will be here soon enough and I will need the truck for towing the boat. I haven't even started on the engine! Posted via Mobile Device
01-16-2011, 11:20 PM | #117 |
C35 Crew Dually
How much longer till we get to see the bed on the truck? lol i want to see what the drop looks like on the whole truck (so i know what mine will look like )
01-16-2011, 11:59 PM | #118 |
Nice progress on the filler. What wheels/tires are you planning to run?
01-17-2011, 12:49 AM | #119 | |
01-17-2011, 12:54 AM | #120 | |
01-17-2011, 01:44 AM | #121 |
Yeah, I checked those out & like them too (except for that dang logo across the c.cap).
01-17-2011, 09:17 AM | #122 |
Cool project and nice hinge!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-17-2011, 10:47 AM | #123 |
C35 Crew Dually
What size are your front tires? and any issues? Sorry to be a bother with a 101 Questions. just looking at what i'm getting into
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 Last edited by 1tonchevy; 01-17-2011 at 10:48 AM. |
01-17-2011, 11:02 AM | #124 |
Thanks to another member of the forum for providing me the part number of the hinge he used.....LOL
01-17-2011, 11:07 AM | #125 | |
In regards to the 101 questions, don't worry about it! That what these forums are for. I am more than happy to provide any assistance I can Posted via Mobile Device
