Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-07-2011, 01:15 PM   #551
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Project - '69 4x4 named "Patches"
Originally Posted by sdailey View Post
PM sent.
Thanks Heath. It's progress right? Anything new happening on your K10 build?
unfortunately not Shannon, hopefully soon....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-07-2011, 04:50 PM   #552
Booya
Booya's Avatar
Hi, been watching your build and have to say, great job. I'm just past the tear down stage on mine and my throttle cable was not stock, way too long (actually was looped around the carb) and I was wondering in the length comparison between the Lokar you bought compared to the stock version? I really like the look of the Lokar. Thanks Bill
Booya is offline   Reply With Quote
Old 03-07-2011, 05:32 PM   #553
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Bill. The Lokar cable is a "trim to fit" cable. It's pretty simple. Check out the link below for more info.
http://lokar.com/product-pgs/throttl...le-cables.html
Shannon
sdailey is offline   Reply With Quote
Old 03-07-2011, 10:41 PM   #554
Booya
Booya's Avatar
Perfect. Thank you....
Old 03-08-2011, 06:28 PM   #555
Gene
Gene's Avatar
Let's see some update pics!!!
Gene is offline   Reply With Quote
Old 03-08-2011, 11:24 PM   #556
sdailey
The Few, The Proud
sdailey's Avatar
Anytime.
Nothing to update so far this week.
Shannon
Old 03-09-2011, 12:23 AM   #557
daverod
SSN 706
daverod's Avatar
Not even some more pictures of Allan. boring
daverod is offline   Reply With Quote
Old 03-09-2011, 12:39 AM   #558
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Don't want to bore you with my big head.
Alan's Classic is offline   Reply With Quote
Old 03-16-2011, 09:06 PM   #559
jaros44sr
jaros44sr's Avatar
nice work, always enjoy stopping back to see your progress...
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-17-2011, 12:08 PM   #560
sandking
.....I am working on it.....
sandking's Avatar
Nice build!!!
I wish I had the time, patience, skill, tools and money to do what you are doing....
View my build thread HERE
sandking is offline   Reply With Quote
Old 03-17-2011, 03:12 PM   #561
sdailey
The Few, The Proud
sdailey's Avatar
Thanks for stopping by Jim. Where do you stand on yours at the moment? Take care bud.
Originally Posted by sandking View Post
Nice build!!!
Me too!
Thanks for going through my build.
Shannon
Old 03-18-2011, 06:17 PM   #562
jaros44sr
jaros44sr's Avatar
[QUOTE=sdailey;4559180]Thanks for stopping by Jim. Where do you stand on yours at the moment? Take care bud.
Sad story...I'm on my 4th intake manifold, First one was a stock two barrel, second one was for a standard SB w/four barrel, third one was for Vortec heads and I galled the threads on an alum. plug. Out comes the #6 Spiral easy out, and it developed so much pressure getting the pipe plug out it cracked the 'brand new' manifold
Wifey said I could borrow 200 bucks off of her, but I wonder what the interest rate will be
Pretty cool having a guy like Allen live next door
Thanks for listenin', I'm starting to feel better
SAFETY FIRST
AS usual, off topic
Jim
Old 05-02-2011, 12:44 PM   #563
sdailey
The Few, The Proud
sdailey's Avatar
Still here......
Here's an update of where the truck stands now.
My cab didn't have a rear view mirror so I measured and drilled holes for one (major progress I know) If the holes look crooked its because the cheap aftermarket mount had the holes drilled uneven.
Cut the cab for a cargo light thanks to this thread...http://67-72chevytrucks.com/vboard/s...d.php?t=202391
Installed cargo light switch
Marked the doors and drilled holes for my sport mirrors.
With the driver's side buttoned up, I've been working getting the passenger side squared away.
No pictures, but got the kick panel area repaired during this process as well.
Added a new drip rail
Got the door hung (again) trying to line up the rocker. The passenger side is going a lot smoother than the driver's side did that's for sure.
Got the fender mounted checking the gaps at the door and rocker. Notice the tape on the door window hoop, I've got to cut it and remove a little material like I did on the driver's side door.
At this point the rocker is almost ready to get welded in. There are a couple areas where I need to fill in the door/fender gap a little, but nothing major. I'll just add a little metal to the door edge and blend it in. Once that is done then I can get the cab corner installed and hopefully move to another area of my cab. I'm tired of hanging and re-hanging doors and rockers.
I'm going to tackle the firewall next. I plan on smoothing it for the most part, but I've got to get the new cowl panel installed first. Wish me luck.
Shannon
Old 05-02-2011, 01:06 PM   #564
198plus
198plus's Avatar
Nice work !!!!!!!!!!
198plus is offline   Reply With Quote
Old 05-02-2011, 02:28 PM   #565
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Ronnie. Slowly, but surely.
Glad to see your truck is coming along as well.
Shannon
Old 05-02-2011, 03:16 PM   #566
Gene
Gene's Avatar
Nice progress! Wish I had a shop, i'd be getting so much more done if I did!
Old 05-02-2011, 07:36 PM   #567
freakshow108
freakshow108's Avatar
This part of your project could not come at a more perfect time, Im at the same point but just far enough behind that you are figuring out all of the weird quirks so i dont have to use my limited brain matter. Thanks a million. Also, you can hold your head a little higher these days, our military is something else, God bless all of you.
freakshow108 is offline   Reply With Quote
Old 05-02-2011, 07:37 PM   #568
msgross
msgross's Avatar
nice to see that you are still at it, and that the Tornados didn't hit your area.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-03-2011, 09:42 AM   #569
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Gene. I'll get there one day. Is yours completely buttoned up now?
Glad to help. I owe all the credit to this board and my neighbor Alan. Without their knowledge and support I'm not sure I could've tackled this project. Thanks for the well wishes. Our military is truly something to be proud of.
Still scratching away at it. It's slowly starting to take shape. Any time allocated in your schedule to work on yours in the near future? You're close enough now that with a solid week of work you could have it mobile.
Luckily the tornados just skirted around us. It was a little hairy at times though.
Shannon
Old 05-03-2011, 11:57 AM   #570
Gene
Gene's Avatar
Oh no, ran out of money Still gotta get my front and back glass installed so I can get it back to the body shop for colorsand n buff. Then I have about a gazillion little things to do!
Old 05-03-2011, 01:36 PM   #571
msgross
msgross's Avatar
no plans here... been working on finishing my basement so I have a mancave IF we have an NFL season this year...
The Garage:
Old 05-04-2011, 01:29 PM   #572
jaros44sr
jaros44sr's Avatar
job well done, always nice to see quality work being preformed(get it? using patch panels...give it a minute) body lines look great from here
enjoying your progress, keep plugging away
SAFETY FIRST
AS usual, off topic
Jim
Old 05-04-2011, 03:23 PM   #573
sdailey
The Few, The Proud
sdailey's Avatar
Good luck getting the nick picky stuff finalized. Are you going to install your own glass?
Gotta post some pics of the man cave when you get done. After the bad storms/tornados last week my wife is wanting a safe room built in our basement now.
Thank you sir. Yeah, these patches preform pretty well. Much better than I expected. The body lines match up extremely well and the gaps aren't all that bad either. A little tweaking and it'll be good. Thanks for checking in.
Shannon
Old 05-04-2011, 03:33 PM   #574
jaros44sr
jaros44sr's Avatar
good idea on the man cave/ bomb shelter, can never be overly safe against mother nature...gotta keep the wifey safe
My wife is a work in progress when it comes to home safety, I have to tell her what and how to shut down systems, how and where to exit, plus where the guns and keys to the trigger guards are
Hope all is well with you after the bad round with weather
ok, time to get back in the shop!!
SAFETY FIRST
AS usual, off topic
Jim
Old 05-04-2011, 04:32 PM   #575
Gene
Gene's Avatar
No, I paid my paint guy today for the windshield and front and back gaskets. He is gonna install them so he can sand n buff it without ruining my interior. Should have the truck back to him next week. Then I gotta get started on refinishing my trim, I decided to go this route instead of buying it all new aftermarket.
