Old 02-02-2012, 02:57 PM   #1
nate c10
73-87 chevy stepside lowered pics
I have recently gotten a 84 chevy stepside 2wd and want to lower it i was thinking about flopping the axle over the spring in the rear and cutting the front springs, I would like some pics and if you could tell me how, and how much of a drop you did thatd be greatly appreciated thanks,
nate c10 is offline   Reply With Quote
Old 02-02-2012, 03:29 PM   #2
cory d
cory d's Avatar
Re: 73-87 chevy stepside lowered pics
i flipped the rear and cut 1 1/2 coils off. at stock hight the gap from the front wheel well to tire was about 4" and the rear about 7". after the flip and cutting 1 1/2 coils the front is not about a 1/2" gap and the rear tucks about 1/2". the hardest part was freeing up the rusted bolts. as far as ride quality goes, its not bad. the raer has 5 leafs and the overload so its fairly stiff and the front as a little softer then the rear.
cory d is offline   Reply With Quote
Old 02-02-2012, 03:33 PM   #3
Keith Seymore
Keith Seymore's Avatar
Cut coils in the front; relocated spring hangers and removed springs in the rear.
Probably 4" drop in front; approx 5 or 6" in rear.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-06-2012, 08:32 PM   #4
nate c10
thanks cory, do u ever have anny troubles with the axle hitting the rubber stoppers? i was told if i did this and didnt c the frame it would bottom out
Old 02-07-2012, 12:59 AM   #5
ivorton74
ivorton74's Avatar
i want to do the same to my 74 fleetside. did u change the shocks too?
ivorton74 is offline   Reply With Quote
Old 02-07-2012, 01:12 AM   #6
ringger14
ringger14's Avatar
Are you not wanting to notch the frame nate? Youll want to get drop shocks if you flip your axle, givin you have the extra coin.
ringger14 is offline   Reply With Quote
Old 02-07-2012, 01:16 AM   #7
Stepper562
Stepper562's Avatar
With 20`s...
Wih 17`s Billet Speciealties...
Lowered 6/8.
Stepper562 is offline   Reply With Quote
Old 02-07-2012, 09:59 AM   #8
nate c10
Ringger, i was wondering if i have to notch the frame kuz i was told i had to or else it would bottom out but i really dont have the money for it
Old 02-07-2012, 01:17 PM   #9
ghettoluxury
ghettoluxury's Avatar
just cut your rear bump stops off
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-07-2012, 01:31 PM   #10
Stepper562
Stepper562's Avatar
You can do it yourself bro for 150 bucks. It'll take you one day, 150 bucks, a good drill, cut off wheel, one buddy and a couple of cases of beer.
Old 02-07-2012, 03:06 PM   #11
cory d
cory d's Avatar
my bump stops were all ready removed. i still have a good distance between my axle and frame, i bottem out my shocks before i get anywhere close to the frame
Old 02-07-2012, 06:13 PM   #12
Stepper562
Stepper562's Avatar
Good no need for a C notch then...just purchase some drop shocks and you are A OK.
Old 02-10-2012, 12:07 AM   #13
lilpoindexter
lilpoindexter's Avatar
Flipped in the back with a djm kit, 2.5" spindles and 2" springs up front. If i had to do it again, i would only have used 1" drop springs up front because I don't like slowing down for speed bumps and with my current balloon tires I bang my inner fenders on occaision...I also don't like the rake...i'd prefer it level
Chisel off those gnarly bumpstops in the back, put one of those little mushroom tips on, and you've got 3 inch + clearance..you won't bottom unless you are way overloaded. I had to use the shortest shocks summit racing has up front, and my kit had drop brackets for the rear so it uses the stock shocks.
lilpoindexter is offline   Reply With Quote
Old 02-10-2012, 12:11 AM   #14
Low84
Low84's Avatar
Nice truck and stance
Low84 is offline   Reply With Quote
Old 02-10-2012, 01:49 PM   #15
steemin_ehman
False Lies
steemin_ehman's Avatar
What are ya talkin about? level... it sits PERFECT as it is!! IMO the space between the fender lip and top of the rim has to be the same on the front as it is on the rear, otherwise it looks like the front is higher (even though it isn't) - gving the truck a desert truck look (Cali-lean, stinkbuggin, gasser, bulldogged, etc) Not my kind of look, but to each their own...
Mine is a flip kit in the rear, with a drop hander kit, and 2.5" drop spindles and 2.5" drop coils. The wheels are 20x8.5 all around.
Kyle (Steemin) Ehman
-1979 Chevy CCLB, 6.7L Cummins swap - Project "RAMERADO"
-2015 Yukon XL Denali (Family ride)
-1977 Chevy stepside, carb'ed vortec 350 (SOLD)
-Father of three daughters who will also have something cool...
steemin_ehman is offline   Reply With Quote
Old 10-08-2014, 08:44 AM   #16
ddr11
ddr11's Avatar
Here's mine 87 stepside>>>Rear is flipped with shackles and relocated front spring hangers (moved up 3") with c notch..I did mine a little different in the front, i have 2' dropped spindles with afco 11'' 1000# springs and adjustable spring cup to insure that it sits level (side to side)18x8 front and 20x10 rears
ddr11 is offline   Reply With Quote
Old 10-08-2014, 08:47 AM   #17
ddr11
ddr11's Avatar
Steemin Ehman what is that on the top of your truck Spoiler or 3rd brake light just wondering?
Old 10-08-2014, 08:16 PM   #18
Ryan87
My 79, spindles, springs, flip kit, C-notch, & shackles.
15x8's & 15x10's 245/60, & 295/50's
Ryan87 is offline   Reply With Quote
Old 10-09-2014, 10:49 AM   #19
Tilt
Here's a couple of mine. 3" spindles, 1 coil cut off stock springs, rear flip. Stock steel wheels were 15x7 with 225/75/15. New wheels are 20x8.5 with 5" BS and 245/40/20, & 20x9.5 with 5.22" BS with 275/45/20. No C notch.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 10-09-2014, 02:21 PM   #20
Rich84
Rich84's Avatar
I love this thread..
Rich84 is offline   Reply With Quote
Old 12-01-2014, 04:09 AM   #21
bh86
ditto i wanna see more
bh86 is offline   Reply With Quote
Old 12-02-2014, 12:36 PM   #22
kevinmfduane
This is my new 79. Top pic is from today. Moon discs were given back to the previous owner.
kevinmfduane is offline   Reply With Quote
Old 12-02-2014, 12:51 PM   #23
aggie91
I'm just glad to be here!
aggie91's Avatar
Here is one we did:
Front has 2.5" drop spindles, crossmember raised 1.5" in the frame. PPBFab Lower Forward Arms, Air bags (no air management, only a schrader to set height). 20x8.5 4.5" BS with a 255/40R20 tire.
Rear is flipped with the hangers moved up 1" on the frame. 20x10 5.5" BS with a 315/35R20 tire.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-02-2014, 01:28 PM   #24
bh86
I like both of those, that red is gorgeous. Here's one I'm workin on. Was gonna leave the body as is but looks like I'm gonna do the paint and body work now
Old 12-02-2014, 06:04 PM   #25
muncher
This is my 87 Stepside. Not sure of much of its history as I shipped it over from California. It does sit a little lower than others I have seen here. I plan on going lower. Great thread!!
muncher is offline   Reply With Quote
73-87 chevy truck, lowered, pics, spring over, stepside
