Old 11-10-2014, 10:11 PM   #76
502ms
502ms's Avatar
Updated Dirty Dianah
Motor/transmission:6.0 LQ4/T-56
Fuel tank: 20 gallon aluminum fuel cell mid frame, under lifted floor
Motor mounts: Dirty Dingo/75 Motor Mounts
Tranny mount: Custom
Oil pan: Stock LQ4
Radiator: 4-core aluminum
Shift linkage: Hurst/F-body
Exhaust manifolds: BBK Shorty Headers
Gears:3:73
Rear End:12 bolt, LSD
Tire size: 28"
Bagged:Yes
Running:Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=563056
Carb or FI:FI
Go Fast: Preparing for Twin Turbo
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 11-20-2014, 07:06 PM   #77
Hart_Rod
Hart_Rod's Avatar
Re: LSX swappers what ya got?!?!
Guys I finally have a solution for people wanting an easy way to mount a truck/SUV drive by wire pedal in a 67-72 truck. Check out my thread:
http://67-72chevytrucks.com/vboard/s...40#post6926040
Hart_Rod is offline   Reply With Quote
Old 11-23-2014, 05:52 PM   #78
brushbuggy
brushbuggy's Avatar
model: 51 3100 swb
motor/trans: 04 5.3 4l60e
exhaust: stainless block hugger headers, ebay
shifter: lokar floor shift
column: ididit
gauges: dakota digital VHX
motor mounts: cpp
trans mount: cpp
front suspension: tci
rear diff: s10 4x4 3.42
fuel tank: 36 chevy truck
fuel pump: tanks ink in tank
radiator: champion
brushbuggy is offline   Reply With Quote
Old 11-28-2014, 02:29 PM   #79
whitels1
whitels1's Avatar
Updated for the K10
Model: 84 K10
Motor/transmission/transfer case: 5.3, SM465, NP205.
Fuel tank: Stock 81 K5 Blazer tank modified for an 03 Silverado Pump.
Motor mounts: Advanced adapter plates, stock mounts.
Tranny mount: Stock.
Oil pan: Truck.
Radiator: Stock with 98 windstar fans
Shift linkage: N/A
Headers: Schoenfeld 1302LS1
Gears: 3.73
Rear End: 10 bolt front, 14 bolt sf rear.
Tire size: 35"
Bagged: N/A
Running: Like a BOSS!!
Build thread: 84 K10 Custom Deluxe 5.3 build
Carb or FI: EFI
Go Fast: Flat topped 4.8 pistons, 10.4 compression, Schoenfeld 1302LS1 Headers, LS9 Cam.
Build Videos Here Project Chevy K10
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 03-22-2015, 09:51 AM   #80
Macster
Model: 1979 GMC C1500 S/B
Motor: 5.3, 700R4
Fuel tank: stock with external Fuel pump
Motor mounts: Hooker adapters/stock BBC engine side (had to relieve pass side due to AC provisions on 5.3 block)
Oil pan: Stock 5.3 truck
Radiator: aluminum direct fit (summit racing)
Shift linkage: stock auto- so far no exhaust clearance issues
Headers: do not fit-hit pass side firewall due to head offset on 5.3 (and mt location)
Gears: 3.73 richmond/eaton posi locker
Rear End: 12 bolt
Tire size: 255/70R-15 Stock rims
Bagged: N/A
Running: Not Yet
Build thread: need one
Carb or FI: Carb; Edel-7118 LS kit; 600 CFM carb
Still hooking everything up
Macster is offline   Reply With Quote
Old 03-23-2015, 12:10 PM   #81
mattcrp1
mattcrp1's Avatar
Originally Posted by whitels1 View Post
Updated for the K10
Model: 84 K10
Oil pan: Truck.
Shift linkage: N/A
Gears: 3.73
Tire size: 35"
Bagged: N/A
Carb or FI: EFI
Great build, dig the videos.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 04-10-2015, 08:32 PM   #82
Tilt
Model: 86 SWB step side
Motor/transmission: 2004 LQ9/2005 4L80 w/ Yank Pro Truck 3600 stall
Fuel tank: Stock 87
Motor mounts: DD Sliders w/ original SBC mounts
Tranny mount: Summit universal 3" offset
Oil pan: CTS-V
Radiator: Stock 87 454
Shift linkage: Lokar Rod shifter
Exhaust manifolds: Schoenfeld 1302LS1 LS1/LS7 Engine Swap Long Tube Header
Gears: 3.42 (for now)
Rear End: 10 bolt
Tire size: 255/40/20-275/45/20
Bagged: No
Running: YES
Build thread: Not yet
Carb or FI: FI
Go Fast: Comp 231/235 .630/.610 cam, 799 heads (10.9:1 comp)
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 04-23-2015, 08:48 PM   #83
engairuph
Model: 1969 4wd Suburban
Motor/transmission: 2005 LM7 5.3 / 4L80e stage 3 1500 stall
Fuel tank: stock
Motor mounts: ECB
Tranny mount: factory 1969
Oil pan: stock
Radiator: Aluminum 4 core / dual fans
Shift linkage: Shift Link
Exhaust manifolds: LS3 camaro
Gears: 3:73
Rear End: 12 Bolt posi
Tire size: 295-65/15
Bagged: no
Running: Yes
Build thread:
Carb or FI: FI multitech
Go Fast:Just going first
the transfer case is a np205 with 32 spline upgrade, 2 1/2 pipe from front to rear with Borlas mufflers complete dualed.
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 04-23-2015, 09:08 PM   #84
whitels1
whitels1's Avatar
Thanks!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 05-27-2015, 05:10 PM   #85
Bowtiguy
Bowtiguy's Avatar
Model: 1968 C10 SWB
Motor/transmission: 2013 LC9/ 2014 Camaro SS TR6060
Fuel tank: No Limit EFi setup mounted under bed
Motor mounts: CPP sliders
Tranny mount: CPP w/ poly
Oil pan: CTS-V
Radiator: OEM replacement w/ dual 16" SPAL Fan
Shift linkage: Core/Hurst shifter
Exhaust manifolds: Doug's Tri-Y
Gears: 4:11
Rear End: Mark Williams rebuilt 12 bolt (C-clip elim, eaton posi)
Tire size: 255/45R20 Front 295/45R20 Rear
Bagged: NO
Running: YESSS!
Build thread: None
Carb or FI: MSD Atomic EFi
Go Fast: NLE sways, panhard, shock relocation, & power R & P. CPP big brake w/ hydroboost, Ridetech HQ shocks all four corners.
Bowtiguy is offline   Reply With Quote
Old 08-06-2015, 01:59 PM   #86
BigCountryx
BigCountryx's Avatar
Model: 1970 SWB C10
Motor: 2001 Silverado 5.3 with 221/228 600/605 112+2 cam
Transmission: 1997 c3500 4L80e, hd2 shift kit and circle D 3000 stall
Oil pan: 2001 Silverado, hangs an inch below the factory crossmember
Motor mounts: ECE
Tranny mount: ECE
Tranny Tunnel: Low hump
Radiator: Champion for Big Block w/ 2002 camaro fans
Fuel tank: Jeep Cherokee tank with 87 Chevy TBI sending unit and ep241 pump... don't think it's enough pump
Shift linkage: 72 c30 floor shift column... nothing on the column. 2001 silverado shift cable, 1967 C10 E-brake used as shifter.
Exhaust manifolds: 1998 camaro
Gears: 3.73
Tire size: 29
Carb or EFI: EFI
Bagged: no, 5.5/8 static
Running: yes, drove the second half of the 2015 Power Tour in it.
Go Fast: just a cam and tune
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 09-10-2015, 11:23 AM   #87
MattPSU
MattPSU's Avatar
Model: 1972 Cheyenne SWB
Motor/transmission: 5.3l / 4L60e from a 2005 Avalanche
Fuel tank: Boyd Welding
Motor mounts: Stock SBC stands & mounts with eBay plates
Tranny mount: Stock
Oil pan: Cadillac CTS-V
Radiator: Champion LS Swap 3 Row
Shift linkage: Modified stock
Exhaust manifolds: BBK Camaro Headers
Gears: Stock 3.08
Rear End: Stock 10 bolt
Tire size: 275/60R15
Bagged: Yes – Porterbuilt Stage 1 front, Stage 2 rear
Running: YES
Build thread: http://67-72chevytrucks.com/vboard/s...22887&posted=1
Carb or FI: FI
Go Fast: Brian Tooley Racing Stage 3 Cam 218/224/.553/.553 113+3
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 09-10-2015, 12:21 PM   #88
solidaxel
solidaxel's Avatar
Nice ride!
I like the coil covers.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-11-2015, 06:54 AM   #89
Macster
1979 GMC S/B
2003 5.3/4L60E
dirty dingo mts
Hedman Husler headers( i will update Picture)
CPP tranny Cross member
Stock Driveshaft
3.73 posi
Dakota Digital VHX
Vintage air (on order)
Old 09-11-2015, 02:07 PM   #90
kitsbeach
kitsbeach's Avatar
Tranny mount: Stock
Gears: Stock 3.08
Running: YES
Carb or FI: FI
Originally Posted by Macster View Post
1979 GMC S/B
2003 5.3/4L60E
dirty dingo mts
Stock Driveshaft
3.73 posi
Dakota Digital VHX
Both nice clean installs..!!
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 09-11-2015, 02:45 PM   #91
Clyde65
Clyde65's Avatar
Ill add mine.
Model: 1965 C10
Motor/transmission: 2005 4.8/4L60E
Fuel tank: Boyds Non-EFI
Motor mounts: POL
Tranny mount: CPP
Oil pan: Stock Truck
Radiator: Champion 2 Row
Shift linkage: Locar
Exhaust manifolds: Sanderson CSLS1 Shorties
Gears: 3.73
Rear End: 12 Bolt
Tire size: 29
Bagged: Rear only
Running: Oh yes!
Build thread: None
Carb or FI: FI
Go Fast: Nothing, pure stock.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-10-2015, 11:16 PM   #92
Badger69
Badger69's Avatar
Model: 1969 C10, original paint NC truck
Motor/transmission: 2008 6.0L LS2 from a TBSS w/ 4L70e with e38 ECM
Fuel tank: Tanks Inc.
Motor mounts: CPP
Tranny mount: CPP
Oil pan: CTS-V
Radiator: Griffin Aluminum
Shift linkage: Custom Fab
Exhaust manifolds: Headers
Gears: 4.10
Rear End: 12 Bolt
Tire size: 31
Bagged: Accuair eLevel with dual viar compressors and 5 gal tank
Running: Yes, but working out some tuning issues
Build thread: None
Carb or FI: FI
Go Fast: Nothing, pure stock LS2
Other goodies:
Dakota Digital VHX Gages
4 wheel disc brakes: CPP
2 1/2" drop spindle: CPP
Porterbuilt C-Notch
Porterbuilt Stage 2 rear kit
Push button start: Painless
Vintage Air A/C
Detroit Steel Wheels (20x8 and 20x9)
Auburn Locker
Retrosound Stereo with Bluetooth
Tilt steering wheel: CPP
Cruise control: Custom
'69 C10 | LS2 | 4L70e | 4 Wheel Disc Brakes | Accuair eLevel | 20" steel wheels | Porterbuilt goodies | Push Button Start | Tilt | Cruise
'79 Burbo | 2wd | 8100 Vortec/Allison swap | A/C | soon to be bagged.
Badger69 is offline   Reply With Quote
Old 11-20-2015, 12:58 AM   #93
Alex41
Model: 1981 1/2 ton
Motor/transmission: 2005 LS2/4L65e from GTO
Fuel tank: Stock saddle with walbro 255 intank
Motor mounts: Home made
Tranny mount: Also home made
Oil pan: F body
Radiator: Stock 05 GTO radiator and fans
Shift linkage: Stock modified
Exhaust manifolds: Trail Blazer SS Pacesetter headers
Gears: 3.40
Rear End: 1974 12 bolt
Tire size: 245 40 20 305 35 20
Bagged: Static 6/8 drop
Running: Damn skippy
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=656792
Carb or FI: FI
Go Fast: My fat foot...for now.
Alex41 is offline   Reply With Quote
Old 12-02-2015, 11:41 AM   #94
Billyburban
Hello everyone I see a lot of ppl using tbss manifolds did you have to cut frame or modify anything ? Thanks
Billyburban is offline   Reply With Quote
Old 12-03-2015, 02:46 PM   #95
grad70
Model: 1970 C10 LWB
Motor/transmission: 2010 L96/2004 4L80E
Fuel tank: Byod Fuel Cell
Oil pan: Stock (currently)
Radiator: Entropy LSX Radiator w/ dual elec fans
Shift linkage: Lokar Adjustable Column shift linkage
Gears: 3:07
Rear End: '70 12 bolt
Tire size: In Process
Bagged: NO
Running: YES!
Build thread: None
Carb or FI: FI
Go Fast: Stock for now, Cam in future?
grad70 is offline   Reply With Quote
Old 12-09-2015, 02:00 PM   #96
tucker69
tucker69's Avatar
Model: 1969 c/10 stepside
engine: 2001 lq4 6.0, stroked to 408
trans: 4l80e
diff: Stock 12bolt with 3.73 posi
frame: Boxed & "x" braced
suspension: 4-wheel coilovers with new front crossmenber & 4-link fatbar all from "no limit"
steering: Power rack & pinion
fuel tank: Boyd's 19 gallon relocated to rear of frame
, used corvette fuel pressure regulator/filter to delete the return line from engine
just fired engine for first time this past weekend, still have several body mods, driveshaft, interior, gages, wheels/tires, bed, climate control, paint and numerous other tidbits....gee and i thought i was making headway
tucker69 is offline   Reply With Quote
Old 12-09-2015, 10:34 PM   #97
mild68
mild68's Avatar
Model: 94 S10
Motor/transmission: 5.3 NV3500 5speed
Fuel tank: stock
Motor mounts: current performance poly urethane
Tranny mount: stock
Oil pan: GM muscle car pan
Radiator: S10 V6 HD w dodge Intrepid dual elec fans
Exhaust manifolds: Sanderson shorty headers
Rear End: changing out to 8.8 w 373:1
Build thread: http://67-72chevytrucks.com/vboard/s....php?p=7400447
Carb or FI: fuel inj w truck intake
mild68 is offline   Reply With Quote
Old 12-14-2015, 11:39 AM   #98
roushinator
roushinator's Avatar
Model: 1972 C10 Stepside
Motor: 2014 6.2 (Camaro)
Transmission: 2014 6L80E
Oil pan: 2008 Cadilac CTS-V
Motor mounts: ECE
Tranny mount: Porterbuilt Inner Frame Stiffner
Tranny Tunnel: High hump
Radiator: Entropy dual pass with electric fans
Fuel tank: Boyd's Welding stainless in tank pump
Shift linkage: TBD
Exhaust manifolds: Doug Thorley 324Ys
Gears: TBD
Tire size: TBD
Carb or EFI: EFI
Bagged: no
Running: not yet...
Go Fast: TBD
Build thread:
http://67-72chevytrucks.com/vboard/s....php?p=5532411
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 02-07-2016, 06:47 AM   #99
OKGMC4
OKGMC4's Avatar
Model: 1969 C10
Body mods: 67 GMC front clip, bed cut 23 inches, unibodied, mild chop
Motor: 2005 6.0 LQ4 bored .020, flat tops, 224R cam on 112 centers
Transmission: 2005 4L60E
Oil pan: silverado
Radiator: 2001 TA with stock dual fans
Fuel tank: TANKS inc poly for 48 Ford
Exhaust manifolds: Doug Thorley long tube
Gears: 3,73
Tire size: 285/35r20 rear, 255/40r20 front
Carb or EFI: EFI
Bagged: no
Running: not yet...
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 10-07-2016, 11:04 AM   #100
Qwk
Qwk's Avatar
Model: 87 R10
Motor/transmission: LS1/T56
Fuel tank: Stock w/Racetronix 340 pump
Tranny mount: Energy Suspension
Oil pan: GM
Radiator: Afco
Shift linkage:
Exhaust manifolds: Hedman Headers 1-7/8"
Gears: 4:10
Tire size: 295/50-15
Bagged: Nope
Running: Yes
Build thread: http://ls1tech.com/forums/conversion...t56-build.html
Carb or FI: Holley HP
Go Fast:
My LS/T56 C10 build...http://ls1tech.com/forums/conversion...t56-build.html
Qwk is offline   Reply With Quote
