11-06-2016, 02:32 PM | #6 |
Re: 57 Panel "FAKMLC" build
Thanks guys.
Got the front clip off and the side panels. Lots more sheet metal clips than my old truck. Tip for others. Consider removing wheels and placing on Jacks to make getting to the 8+ bolts in the fender wheel part easy and quick to remove. Other tip .. you literally have to remove every bolt you can see including all those by front clip and support at rear near door hinges reverse side. |
