Old 12-17-2016, 04:52 PM   #276
62stepside longbox
62stepside longbox's Avatar
Re: 1962 chevy c10 update.
Good decision John, I'm sure you'll love how smooth the t5's are. Not to mention better gas mileage
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 12-18-2016, 11:13 AM   #277
62 Barnfind
62 Barnfind's Avatar
I'm ready to get it in. My truck has been down since last April.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-16-2017, 11:30 AM   #278
62 Barnfind
Just a little update. After some hard work trying to figure out how to get the T5 in it finally happened. It's in! Last Saturday I want on a test drive to test it out. The trans works great! Shifts good, performs better than I expected! I must have sucked up some trash in my carbs because I had a major stall and had to limp it to the body shop. After a week of setting AC (fabricator at the Body shop) help me clear out the trash and get it going. Now after a big tune up, carb adjustment and linkage reset I'm running better than before. i still have to install the high hump, new carpet and shifter boot and the trans install will be done!
I had to remove the torsion bar x member to get the trans in.
Not a good 360 pic but you can see that there is plenty of room now. Except I have to cut in between the top front tunnel cover bolts. This will allow the top of the trans to clear. If you have a high hump this cutting isn't required.
Trans installed! As you can see the lower part of the T5 is what was hitting the torsion bar x member. It wouldn't allow it to slide all the way back into the x frame.
Transcend shifter installed!
Here is a shot when I went to pick up my truck.
John Z
62 Barnfind
Old 01-31-2017, 09:32 PM   #279
62 Barnfind
It was such an nice day Saturday I put on some trim rings and detailed under the hood. I am still having problems with the turn signals and parking lights and found out the turn signal switch is bad. None in stock so I broke down and orders a steering column and new steering wheel. Will post pics of the install.
John Z
62 Barnfind
Old 02-25-2017, 01:14 PM   #280
metalprelude
Truck looks awesome. Question about your disc brake conversion. Who made it? And, do you have any issues with fitment or clearance with your wheels?
metalprelude is offline   Reply With Quote
Old 02-25-2017, 01:52 PM   #281
Vincenthdfan
Originally Posted by 62 Barnfind View Post
That lower bolt hole tab is going to get cut off flush with the rest of the tail housing on my S-10 tail housing when I go to re-install mine into my 62.
It doesn't serve any purpose on our trucks, doesn't add any structural strength to the housing and just serves to get caught on the cross member when installing or removing.
I told myself when I yanked it all outta my truck (getting hung up numerous times in the process) that bugger was coming off before the tranny/engine combo goes back in!
Vincenthdfan is offline   Reply With Quote
Old 02-25-2017, 06:57 PM   #282
62 Barnfind
The make is CCP and this kit is for the 60-62 manual transmission. No fitment problems at all. The only problem with the kit was it doesn't come with instructions. So be ready to cuss a little on where things go. The front brakes clear the wheels with no problems.
John Z
62 Barnfind
Old 12-22-2023, 08:43 PM   #283
62 Barnfind
It痴 been a while since I posted on this build. I have been working on a 57 truck that I sold in September, so now I知 back on the 62. I知 getting ready to start a big update on the truck. I知 planning on doing a V8 swap, front suspension swap, rear axle swap and A/C install. I already started putting the engine together. I have a 355 with a 480 lift cam going in the truck. The 235 runs great but I知 really wanting some power under the hood. Stand by for some updates.
John Z
62 Barnfind
Old 12-24-2023, 01:30 PM   #284
LT7A
Whoa. You're not kiddin around. Aluminum heads and all! I never saw your thread back in the day so I just read through it. I like how you've phased it. You made a plan, executed it, enjoyed the truck. Then did phase 2 when the time was right, etc. Great truck! I'm in to watch the updates. Also cool how your wife is part of the "truck team".
Old 12-24-2023, 06:24 PM   #285
62 Barnfind
I知 doing all the things I didn稚 do when I first built the truck. I sold my 57 that I was working on for 5 years. It was full custom with a LS. This truck was just setting with little driving time. After doing all the work on the 57 I now see flaws in this build. Lucky it痴 painted so I won稚 be doing any exterior body mods. Now I have time to do some upgrades to the truck. Drivetrain, AC wheels. I won稚 be in a big hurry. I will have the engine, 12 bolt rear axle and suspension prepped before I actually install it. As they say they are never done.
John Z
62 Barnfind
Old 01-06-2024, 08:23 PM   #286
62 Barnfind
Found a 78 C10 front suspension on line for a good price. Tomorrow I will start tearing it down and get it ready for paint and reassembly. Any advice is welcome on the 60-62 front suspension swap that would make it easier.
John Z
62 Barnfind
Old 01-06-2024, 10:01 PM   #287
SkinnyG
SkinnyG's Avatar
I have a drilling jig template that references the factory holes and moves the front crossmember forward 1"
Print This Full Size
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-09-2024, 11:15 PM   #288
duramax55
Skinnyg what is the reason for moving the crosmember???
duramax55 is offline   Reply With Quote
Old 01-10-2024, 02:02 AM   #289
SkinnyG
SkinnyG's Avatar
It centers the wheel in the wheel opening better.
Old 01-10-2024, 09:53 PM   #290
62 Barnfind
Thanks for the response. I was thinking of doing that but I値l still be running my t5 trans and it will still be mounted to trans mount. I guess I could re adjust everything.
John Z
62 Barnfind
Old 01-11-2024, 11:23 PM   #291
cwcarpenter98
cwcarpenter98's Avatar
If you don't want to mess with the engine and transmission mounts, you can do the caster mod which will help center the wheel a bit more and provide better suspension geometry.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-12-2024, 11:12 PM   #292
duramax55
Skinnyg i guees if you move the crossmember forward i will have to move steering box ahead 1 inch also
Old 01-13-2024, 12:44 AM   #293
SkinnyG
SkinnyG's Avatar
I don't think people usually move the steering box or idler arm forward, but check other builds. I would only move those if the steering linkage is hitting the crossmember after the move.
The control arm caster mod is pretty easy, and WELL worth it (did it to my '77 and my '61).
Old 01-13-2024, 09:59 AM   #294
62 Barnfind
Can you send me the template?
John Z
62 Barnfind
Old 01-13-2024, 12:20 PM   #295
SkinnyG
SkinnyG's Avatar
Click on the link I gave you to the pdf of it. You quoted it just now.
It's from this page of my build:
https://www.gwellwood.com/project-ca...apache-part-2/
Old 01-14-2024, 09:40 AM   #296
62 Barnfind
Thanks for the help!
John Z
62 Barnfind
Old 01-15-2024, 08:21 PM   #297
62 Barnfind
Made a little more progress on the engine build during the cold weather. I ordered a set of finned rocker covers from Amazon and added some engine paint. Really makes the engine pop! Just have to decide on a drive system and what I知 going to use for fuel delivery.
John Z
62 Barnfind
Old 05-01-2024, 10:06 PM   #298
LVPhotos
LVPhotos's Avatar
Your mail was full. I run Hookers HK- 2466 but they don't clear clutch fork. This is why I run a hydraulic bearing on the clutch
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-22-2024, 08:25 PM   #299
62 Barnfind
Been a little busy on my 62. I removed the 235 and suspension and got it all sold. Next I installed the 78 x member power steering adapter, tube suspension and moved the shock mounts. I had a setback on what engine mounts to use. Thankfully the forum told me to use the 67-72 mounts. With some modifications they fit great. Set the 12 bolt axle and did the 62 modifications to it. I freshened up the frame and now it痴 time for reassembly. I知 still trying to find out what accessory drive system to run.
John Z
62 Barnfind
Old 09-23-2024, 08:54 AM   #300
rbruno68
How did you modify the mounts?
rbruno68 is online now   Reply With Quote
