Old 06-14-2017, 01:41 AM   #926
lower50's
lower50's's Avatar
Re: 53 Surburban "Family Truckster"
Looking Good Marc!! I will be at the Columbus GG show. Are you going? We should meet up!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 06-14-2017, 08:48 AM   #927
youngrodder
youngrodder's Avatar
Originally Posted by mongocanfly View Post
Sweet looking buick..would be fun cruisin round in that..please give the carrier p/n...I'm not sure if I'm going 1 piece or 2 but would be good to put in the info bank..
.was starting to get worried about you and Doug...yall have been quite for way to long
Oh there's reason to be worried about Doug and I. We lose focus easily. The part number is IE210527XS. You can pick it up from Summit for $141.97. The brand name is Inland Empire Driveline
Originally Posted by oldman3 View Post
Hey Marc, I knew Doug's story, glad your posting up some stuff and it looking good...Jim
thanks, like Doug it's just a busy time of year for me.
Originally Posted by Rods57 View Post
Thats a beefy looking carrier. tank mod is cool too....
thanks man!!!
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-14-2017, 08:50 AM   #928
youngrodder
Thanks. Yes we stay at the host hotel. Columbus is a blast. It really wrecks any other show you go to once you've been to Columbus.
Marc
Old 06-14-2017, 09:24 AM   #929
99 to Life
99 to Life's Avatar
luv that car. nice carrier. who makes it? is the company called "fancy"
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 06-14-2017, 10:12 AM   #930
youngrodder
Thanks.. yes it is made by Inland Empire driveline and it also came with a fancy price tag but it sounds like this is the best carrier bearing when using a 2 piece drive shaft..
Marc
Old 06-17-2017, 06:06 PM   #931
Advanced Design
Advanced Design's Avatar
Nice work on the lead joint Marc! Good idea with he carrier bearing and two piece prop shaft too. Now I am feeling the pressure...lol.
The Buick is impressive. Is that a stock grill rechromed?
Advanced Design is offline   Reply With Quote
Old 06-20-2017, 07:10 PM   #932
youngrodder
Thanks Doug...yes the back story on the Buick is that is was build once by a local builder that is high on his abilities and needless to say it was a hacked up POS when he was done with it. The grill was one of the only things that Dutchboys was able to reuse from the first build.
Marc
Old 06-24-2017, 01:54 PM   #933
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
curious on how you removed the lead filler? I will have to do my panels sometime. I assume grinding is going to get it airborne, which is not good to breathe. And I have seen people melt it out. What did you do on yours?
GreasyLikeaBurger is offline   Reply With Quote
Old 06-26-2017, 11:11 AM   #934
youngrodder
Yes, I melted mine out with a small (yellow bottle) hand held touch. It was very easy and straightforward. A nice stiff metal brush helps as well once the lead is liquefied.
Marc
Old 10-09-2017, 03:23 PM   #935
youngrodder
Well it has been a hell of a summer (not really). I had/have a health issues that caused me to spend a total of 20 days in the hospital at three different times throughout the summer. Needless to say when I was unable to do the most minor house related chores like mowing my own lawn, the Suburban was far from something that I could work on. As my health has (slowly) improved so has my drive to get back in the garage. My friend Paul that owns the Hotrod shop came over on Sunday to lend a hand. I still don't have the strength to do everything myself like I used to..
Updates
: I had a 2 piece driveshaft made. I have never messed with a 2 piece. The C-10 guys use them and since my Porterbuilt suspension uses a lot of the same components I followed suit. It turned out nice plus fully aired out I confirmed that I don't need to cut into my floor anymore. I was pretty happy about that. Check that off of the list.
We also installed Paul's LS mock up block to test fit the LS Hooker headers in relation to my steering linkage (fail). One text to Nate at Porterbuilt and it sounds like a 1" taller set of motor mounts will remedy the issue. That would be a better solution that what we were coming up with. I would like to avoid anymore cutting/grinding/welding.
Later this week Paul will be back out and we will tackle mounting my gas pedal and figuring out my hidden hitch that I have been working on. I picked up a new class 3 Reese hitch cheap that I think I can modify to fit.
Here are a few pics.
Marc
Old 10-09-2017, 03:31 PM   #936
Scott2
Good to see you back at it although it's too bad you weren't doing well. Hopefully you're past it and just need to get back into shape!
I had minor back surgery and also got a full knee replacement over the summer and my time working is definitely much more limited until I also get fully recovered. The recovery and strength rebuilding will come in time, but getting old I can't do much about!
Great work on the burb - can't wait to see what's next! I also ordered a new driveshaft and a Derale trans cooler and will be installing those shortly.
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 10-09-2017, 03:47 PM   #937
Coach529
Coach529's Avatar
Awesome work as always.
Glad your health is coming back around and you are getting some shop time!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 10-09-2017, 04:03 PM   #938
youngrodder
Thanks Scott, The crazy thing is I turned 45 this August and prior to this was never sick nor took any medication. I feel like this year took 5 - 7 years off my life...ha ha. I plan to sell my 48 truck this spring and that will free up some funds to really kick the Suburban into gear.
Thanks Coach
Marc
Old 10-09-2017, 07:00 PM   #939
mongocanfly
mongocanfly's Avatar
dang I hate to hear bout that...glad your gettin better...I've been missing updates from you and Doug and the battle of the burbs
Old 10-09-2017, 07:12 PM   #940
oldman3
oldman3's Avatar
Marc, sorry to hear about the health issues, glad you're doing better. Have missed your updates on the burb...Jim
oldman3 is offline   Reply With Quote
Old 10-09-2017, 07:51 PM   #941
Advanced Design
Good to see you on the Burb Marc! Two piece shaft is a good idea for this application. And taller motor mounts sounds like a simple fix...good deal. Hope your healing / strengthening continues!
Old 10-09-2017, 08:02 PM   #942
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Glad to see you back at it!!
ChuckDriver is offline   Reply With Quote
Old 10-09-2017, 10:12 PM   #943
youngrodder
Thanks, I think Doug felt bad since I couldn't work on mine so he decided to not work on his as a show of good sportsmanship....ha ha
Thanks Jim...
Thanks Doug. Once I get these fitment issues resolved I can look at pulling the body to paint the frame.
Thanks Chuck
Old 10-10-2017, 12:04 AM   #944
99 to Life
99 to Life's Avatar
scary stuff. glad you are on the up and up. I'm sure you won't have any problems selling the 48'. be a nice boost for you indeed. looking forward to seeing this one complete. bless you on the road to recovery.
Old 10-10-2017, 09:27 AM   #945
youngrodder
Thanks...I have wanted to push this Suburban forward for a while and the 48 truck sits more than I like considering it's a 2 seater and I have 2 kids and a wife. He math doesn't work. I would have no guilt throwing money at it then.
Marc
Old 10-10-2017, 11:44 AM   #946
Dan in Pasadena
Dan in Pasadena's Avatar
Marc,
I hadn't checked inoin this thread in a long time and missed the part where you said you'd been sick/hospitalized. SO sorry to hear about that. Your health is everything so take care of that first and always.
I can relate. I am 62 (but think I'm mentally stuck around 37-38) and had never been sick other than the flu. I had what turned out to be a gall bladder attack about a year ago. I thought I was dying of a heart attack. Ambulance, emergency surgery, yada, yada...It really opened my eyes.
Sorry to hear about selling the '48 - she is SO beautiful. But having the funds to do the new project will be exciting. Looking forward to what you do. Best, Dan
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 10-10-2017, 12:20 PM   #947
youngrodder
Originally Posted by Dan in Pasadena View Post
Marc,
Thanks, Dan. I like the 48 it just doesn't get used enough and I really like building them and driving them. Plus the idea is to take some of the 48 money and throw it into the boys college funds. That makes more sense to me then having money tied up in a truck I seldom use...
Yes, a persons heath is everything and this ordeal has opened my eyes to that.
Marc
Old 10-10-2017, 10:02 PM   #948
Root2812
Root2812's Avatar
Marc, I understand the whole selling the truck thing. I was just in the same boat. I just sold my 59 corvette because it sat 2 and we are a family of 3. The only time I used it was when I was by myself and there wasn't as much fun in that. I sold it for a pretty penny and paid off debts, put alot in savings, and even have some to help push my truck project along. I'm going bench seat so the truck will seat 3. As long as we don't have more kids I should be good to go. Best of luck to you on the sale and most importantly the health.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 10-11-2017, 08:31 AM   #949
lower50's
lower50's's Avatar
Marc It's to bad you got sick. Glad to hear your on the mend, and getting back out in the shop. I'm only 5 years under you and scares me to think of what could happen over night. We all need to enjoy life while we can. Keep your spirit up Your sweet burb is on it's way. Bob
1951 MG TD
Old 10-24-2017, 07:19 PM   #950
youngrodder
I have been spending more time in the garage as of late. Here is what I have to show for it. I picked up a class 4 hitch for stupid cheap. It was too narrow so I was going to pass on it but then the guy said how about $20.00. For that price I figured that I could cut it up and make it work. I cut off the large mounting brackets and I bought some smaller square tube to slide into the hitch to make it the width I needed. More work needed to figure out my brackets. The end product would be close to how BEEP did his. The receiver will stick through the bumper and the received would hold the plate.
I also removed my radio delete plate (which I already sold on EBay) and welded shut the holes...
I removed the mock up block and in anticipation of receiving my 1" higher motor mounts from Porterbuilt.
That's all folks.....
Marc
