07-09-2016, 08:44 PM | #26 |
Re: 1968 Suburban K20 Past & Present build
Will I see you at the Brothers Truck show tomorrow?
07-09-2016, 08:46 PM | #27 |
What?
Sure will, I plan to be there!
Chris 1968 K20 Suburban 1972 K10 LWB PU |
07-09-2016, 09:03 PM | #28 |
Very good, I'll look forward to meeting you.
07-11-2016, 09:56 AM | #29 |
What?
Brothers show 2016 was probably my favorite, since the drive in was easier this time and the weather was nice. Plus, I met more members of this forum than in any other years past! It was great to meet, and talk with each one of you! Thanks for stopping by to say hello.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 07-11-2016 at 10:05 AM. |
07-11-2016, 10:07 PM | #30 |
Chris,
Very nice to meet you as well. Here is the HO52 info as promised. 3rd member and cover gaskets, Felpro from Napa Pinion Seals SKF 25970 National 411330N They also mention a felt behind the pinion seal if you have it, 5M89 Speedi sleeve for pinion seal surface if needed National 99259 There is a thread here called "HO52 pinion retainer" that White Whale posted a reply to on 7-22-2014 that has all the seal and bearing numbers. Pirate 4x4 has a 46 page thread on these axles. Stovebolt forum has a ton of info also. Good luck with the gear swap, I am retired and work cheap, if you need help, call me. |
07-12-2016, 01:10 AM | #31 |
This thread is long overdue lol! Thanks for taking the time to put this together. Your Burb is truly an inspiration to myself and most likely many others on this site.
Well done Chris!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
09-13-2016, 02:14 AM | #32 |
subd....very nice. I've got a gold 68 burb, 68 short, and 67 long 2wds. Burb is gonna get a 4x4 treatment with a cummins/5spd
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
09-14-2016, 11:50 AM | #33 |
What?
I haven't been doing anything with the burb lately, since I have been taking it to as many shows as possible. This last weekend, I took the burb up to Idyllwild. It's a good work out for the burb, since it is a steep mountain road up to 5000' elevation.
This Friday I am planning on tearing into my electrical, since my tail lights have a gremlin in them. Mid October I plan to do some axle work in the front Dana 44, and doing a 3rd member swap in the rear Eaton (just collecting parts right now).
09-14-2016, 05:48 PM | #34 |
6>8 Plugless........
Chris, very nice burb! I've always liked seeing pics of it when you shared them. Great job on a very nice restoration. That is awesome that it was handed down and it made it all those years in your family too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
09-16-2016, 10:34 AM | #35 |
To add to the info I posted above about the HO52, a 14 bolt Detroit Locker can be used in the HO52 carrier and you use 14 bolt axles.
Also 14 bolt drum brakes can be installed on the HO52 which is nice because I believe brake parts for these old axles, especially drums are hard to get. Jeremy, Jbclassix has a nice write up about the brake drum swap. Last edited by justcuz; 09-16-2016 at 10:40 AM. |
09-16-2016, 10:12 PM | #36 |
Great Thread Chris!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-19-2016, 11:01 AM | #37 |
What?
I was able to get the most annoying electrical gremlins resolved this last Friday but I will not lie, I threw in the towel and hired my neighbor who is an electrician to seek out the problems I have been trying to resolve myself for way too long. He loves to work on our trucks, and even has a K5 that is sitting on a 2002 truck chassis with a 6 liter engine.
As expected, most of the problems were ground related. I apparently just did not remove enough paint where the bolts would go through to get a proper ground for the tail light buckets, as for the front lights and the gauge panel lighting both turn indicators when clicking the turn signal switch. That was because I used single filament bulbs in the front running light buckets! Once the bulbs were swapped with dual filament bulbs, the turn signals and gauge panel began to work normally.. My windshield wiper motor is working again, this was because of a missing mounting bolt. This one the one bolt used by the motor to get ground from the firewall, and it must have worked itself loose and fell out (I later found it under the front seat). My gauges all work now. I never could seem to get the AMP and TEMP gauges to work right, and found out that both of the little 4 amp fuses in the front harness were defective and not working. The TEMP sending unit, this turned out to be a defective new part as well. The original OE AM radio is working now, this too was not working because of a missing ground to the radio. As a bonus, a secret kill switch was added. The total cost was minimal, and I was ecstatic getting that last remaining thorn in my side of nagging troubles with my truck fixed. I even went back and gave my neighbor a large cash tip, since he was so good at getting these problems resolved and explaining everything he did. So, if you need an automotive electrician for your truck. This guy will get it resolved quick. www.ejwireworks.com He is a mobile technician, or you can drive to his house to do the work. Money well spent for me.
01-29-2018, 03:39 PM | #38 |
subscribing
1972 K10, 350/SM465/NP205, 4 inch lift, 35x12.50s on 15x10 wheels 1976 K20 crew cab, 350/Ranger/SM465/NP205 |
