Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 09-23-2018, 11:04 PM   #1
KFF 1
KFF 1's Avatar
New project : 72 Suburban
New winter project arrived today. 72 C-20 Suburban 402/400 factory ac front and rear. Has the usual rocker rot and bottoms of quarters but nothing major that cant be fixed fairly easy. Floors and frame are in pretty good shape overall. Will post pics of my progress when I can
KFF 1 is offline   Reply With Quote
Old 09-26-2018, 06:56 PM   #2
KFF 1
KFF 1's Avatar
Re: New project : 72 Suburban
Making some progress on the Suburban. 402/400 is almost ready to be pulled to make way for the LS swap 402/4L80E
Old 09-27-2018, 10:01 AM   #3
Lokin4AReason
Lokin4AReason's Avatar
i dont think that they have many of those ( or still have survived ) ...
and that looks like a cool project
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is online now   Reply With Quote
Old 09-27-2018, 01:03 PM   #4
Bigdav160
Bigdav160's Avatar
As much as I like LS motors, in my mind, they don't hold a candle to a good running Big Block.
Anyway, in for the details
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-29-2018, 12:43 PM   #5
GIZZ
GIZZ's Avatar
That Burb looks fairly well loaded.
I'll follow along for the bodywork and LS swap.
GIZZmotorsports on YouTube & my panel truck build
'69 c10 panel, '75 c35 flatdeck car hauler
GIZZ is offline   Reply With Quote
Old 09-30-2018, 07:10 AM   #6
KFF 1
KFF 1's Avatar
402/400 pulled out and power washed frame. This week will work on disassembling suspension for the 1/2 ton conversion and static drop, plus get some paint on the frame
Old 09-30-2018, 12:17 PM   #7
Advanced Design
Advanced Design's Avatar
Welcome. Enjoy the build!
Advanced Design is offline   Reply With Quote
Old 10-02-2018, 10:18 PM   #8
KFF 1
KFF 1's Avatar
Frame is painted and working on suspension components to get ready for front portion of static drop
Old 10-02-2018, 10:43 PM   #9
GIZZ
GIZZ's Avatar
Frame looks great.
I see all the undercoat and dirt on your shop floor, how much time did you spend cleaning it? What was your tool of choice?I'm doing the same, I've been spending an hour a day when I can stripping mine and I figure I'll need many more days stripping it.
Old 10-04-2018, 07:51 PM   #10
pwdcougar
pwdcougar's Avatar
Originally Posted by GIZZ View Post
Frame looks great.
I used a 1" wide putty knife when I did mine and it worked great on the flat surfaces!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 10-04-2018, 08:17 PM   #11
KFF 1
KFF 1's Avatar
I power washed frame first ,then used razor scraper for the heavy stuff followed by 4 inch grinder and wire wheel or wire cup
Old 10-06-2018, 09:42 AM   #12
04ls1gto
I got some bildge cleaner from a friend that is a tug boat captian. Putty knife, scrapper, scotch bright pad wire wheel and whatever else I could find. One piece of advice is put plastic or a tarp on the floor first. I will be cleaning the floor for a while
04ls1gto is offline   Reply With Quote
Old 10-09-2018, 08:36 PM   #13
KFF 1
KFF 1's Avatar
Got the front cab support, A-pillar, floor, and inner rocker panel welded in today. Now just waiting for B-pillar, and front lower quarter to arrive so I can finish the job and get the outer rocker installed
Old 10-09-2018, 10:39 PM   #14
Advanced Design
Nice fit! Moving right along.
Old 10-17-2018, 08:59 PM   #15
KFF 1
KFF 1's Avatar
The 2 front wheels and tires came for the Suburban the other day ( Ridler 650 Gray center polished lip 20x8.5 Nitto NT555G2 245/45/20) Brake booster, master cylinder, front brake lines, and A-arms installed. Drop conversion spindles should be here tomorrow so I can get the front end buttoned up and move on to the rear
Old 10-17-2018, 09:45 PM   #16
flashed
Im in to see the rest .
flashed is offline   Reply With Quote
Old 10-18-2018, 09:38 AM   #17
LockDoc
The Older Generation
LockDoc's Avatar
Ahhh, progress. All of the little accomplishments add up to a finished truck....
Looking good.
LockDoc
Leon
Old 10-19-2018, 08:41 PM   #18
KFF 1
KFF 1's Avatar
Got the front suspension and front brakes finished today. Now its on to the rear. I hung a fender on it just to get a visual of what it will look like when its finished
Old 10-19-2018, 10:15 PM   #19
Advanced Design
Great progress! Looks very good.
Old 10-20-2018, 11:01 AM   #20
3drburb
Looking very good.
3drburb is offline   Reply With Quote
Old 10-28-2018, 06:53 PM   #21
KFF 1
KFF 1's Avatar
Just an update for everyone following my build, I started on the C-notch in the rear and have the passenger side completed. Since this is my first one I did not document that side but I will on the driver side. I'm returning to work tomorrow after a 3 month layoff bc of surgery I had in August so my posts wont be as frequent as they have been the past month. Thank you all for following along and for all of your help and support with this build. I will update my progress when I can
Old 11-03-2018, 07:37 PM   #22
KFF 1
KFF 1's Avatar
Finished the C-Notch today. Drop springs and blocks installed, rear end housing is in, shock relocation kit and shocks are on, and brake line back to rubber hose is finished.
Old 11-04-2018, 07:02 PM   #23
KFF 1
KFF 1's Avatar
Finished up the rear end today, set it on stands and threw a wheel on it to get a visual of ride height
Old 11-04-2018, 07:39 PM   #24
Advanced Design
Making good progress.
Old 11-17-2018, 08:07 AM   #25
KFF 1
KFF 1's Avatar
Got the Suburban back down on all 4's. Next step is to install motor and trans mounts. The machine shop is going to have the 6.0 block finished next week so I hope if all goes well when I go on vacation in 2 weeks the motor and trans will be in the frame
