Gauge cluster
I was wondering what the two empty circles on a 60-66 gauge cluster were used for, having not come across a factory guage cluster with a tachometer. Thank you in advance
Moderator
![]() ![]() Join Date: Aug 2011
Re: Gauge cluster
Vacuum, Tachometer I believe. On larger trucks mostly I would think. Since then however we are using them.
Re: Gauge cluster
Yes, the opening on the left was used for either a vacuum or air pressure gauge. The vacuum gauge was available in the medium duty trucks with vacuum assisted hydraulic brakes and the air pressure gauge was used in trucks equipped with air brakes.
The opening on the right was used for the tachometer which was an available option in everything from 1/2 tons up into the medium/heavy trucks. |
Re: Gauge cluster
I seen someone put a clock in one before.
Moderator
Re: Gauge cluster
Love that cluster....
Re: Gauge cluster
Hey Rocknrod, I am about to try a potentially expensive mistake and just go for it because I have dreams at night about a full gauge cluster in my 64 SFB and buy the aftermarket Classic Ind. produced Nova tach and clock and hope that with little alteration, I can make them fit into my stock gauge housing. I have a I6 230 and to my knowledge, Chevy didnt offer tachs for our trucks for the 6 but CI has the 6 cyl version. The Nova gauges look like they are almost indistinguishable from the trucks. Any experience or have you ever heard of this before?
http://www.classicindustries.com/pro...s/3863796.html |
Moderator
Re: Gauge cluster
New to me but very interesting. Many people here would like to find out if they are. Also I had to have mine custom made to be a volt gauge and an sender type oil gauge. I also bought the electric limited sender for the temp gauge, so with my new fuel tank sender I should be "in the mix". Since I am wiring the truck as though it's a fiberglass unit using ground wire everywhere it should read well and the lights should be as good as they can possibly be.
Re: Gauge cluster
Well, I am just going for it. I will definitely post an article on the trial of it. Looking at your minty gauge set up there, I see you had to run the the clock adjuster arm through the lense which you did precisely. I see you have a chrome grommet to protect the plastic lense which the adjuster rides through. What did you use? It looks very factory. Good job!
#10 | |
Moderator
Re: Gauge cluster
Another member of this board TBONE1964 did the gauge change over work.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 05-18-2017 at 11:07 AM. |
#11 | |
Re: Gauge cluster
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Moderator
Re: Gauge cluster
w-Sup LDO you've been keeping a low profile as of late.
Re: Gauge cluster
Picked up an 85 for my son so we've been wrenchin on that for a bit. My 66 is in pieces waiting on time/money!
Re: Gauge cluster
The rocknrod, that's an amazing cluster!! It's blown me away!! Does the guy who did the work take orders?
#15 |
![]() Join Date: Oct 2009
Re: Gauge cluster
the 60's GM vac gauges (seem to be most common in Pontiacs, but other GMs had them also, just in different casings and with different works cover plates) are a good fit. Here's the cluster I put in a 66 I sold a while back. I made use of some of the other unused (i.e. med duty) openings in the dash as well
#16 |
Moderator
Re: Gauge cluster
I put his contact info above so someone could ask him that question.
#17 |
Re: Gauge cluster
Thanks The Rocknrod, and thanks everyone fir you're answers! Very helpful and great to see examples
#18 |
Re: Gauge cluster
What is the correct color for the 66 cluster bezel ?
#19 |
Re: Gauge cluster
64-65: satin black
66: silver |
#20 |
![]() Join Date: Jun 2011
Re: Gauge cluster
left side is for vacuum or air on the big c 50,60,80 right side for tach.
i bought a vacuum gauge and installed it in my 65 c10 ![]()
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
#21 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Gauge cluster
RPO U16 Tachometer in 10-20-30 light duty trucks.
RPO Z53 Gauges AMMETER ,OIL & THERMO
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Tags |
dash, guage, guage cluster, tachometer |
