08-20-2020, 09:07 AM | #26 |
I'm just glad to be here!
Re: Wizit's bagged 60 GMC build V2.0
I want your shop cabinets!
How long have you been using Solid Works?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
08-20-2020, 09:50 AM | #27 |
Goodness, your shop is like a dream i have..... lol Awesome work!!!
08-20-2020, 05:40 PM | #28 | |
I have been using Solidworks since I was 17. Im now 31. Solidworks is about 75 percent of my day to day job. Thanks! I have pretty much invested in tools for the last ten years in the hopes to one day have a shop to put them all in. I have just about any piece of fabrication equipment you could want along with a mill, Lathe, and some sheet metal tools.
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901 |
08-20-2020, 05:43 PM | #29 |
The machine shop started on the axle side lower link mounts today!
I need to order my rear axle and the rear suspension should come together pretty quickly!
08-24-2020, 01:43 PM | #30 |
The axle lower link mounts are finished and back from the machine shop!
Late friday the frame rails were delivered to my work. I hauled them home and got to work getting everything on the frame jig. I still have some work to do on squaring everything up but thanks to my jigs it is all very close already. Ignore my messy shop!
08-24-2020, 01:49 PM | #31 |
Those are some beefy tabs! How heavy are they?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
08-24-2020, 01:57 PM | #32 |
I have been planning and researching the brake setup for this build for a long time now. Maintaining 6 lug has made it interesting to source parts.
For instance, there are a couple people making 5 lug hubs that fit the 73-87 spindles but nobody makes them in 6 lug because there is really no demand for it. My solution was to get cpp 6 lug conversion rotors and cut the rotor off the hub portion. I did some measuring and found the thickness of the casting for the hub section to be 0.75" so I scribed a line all the way around and the cutoff wheel made fairly quick work of the cast. I still need to spin them on the lathe to true up the cut but I essentially now have 6 lug hubs that will allow me to use slip on rotors. In hindsight the better solution here would have been to design around a more common spindle that had 6 lug options available. I think something that uses a standard gm 6 lug unit bearing would have been ideal. For now Im going to continue with my current approach but I may revisit this in the future. The rotors Im planning to run are pretty interesting and should be in this week.
08-24-2020, 01:59 PM | #33 |
They are about 2 pounds each. Certainly a form over function part.
08-24-2020, 04:20 PM | #34 |
Some high tech design stuff mixed w/old school can-do. I'm in for the ride.
08-24-2020, 04:34 PM | #35 |
That's some great stuff right there. Your shop is giving me ideas for when I get to the point in life where I can have my own shop
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-24-2020, 10:25 PM | #36 |
60-66 Nut
You could have used the '88-'98 light duty C2500 rotors to make your hubs. They use the same bearings as the '73-'87 spindles. The only drawback is they have Metric studs.
I see you made yourself a Fireball vise.
08-24-2020, 11:53 PM | #37 |
Read the above wrong, and posted irrelevantly. Edited.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 08-26-2020 at 09:54 PM. |
08-26-2020, 07:28 PM | #38 | |
Yep that is basically a fireball vise. I modeled it up and changed it a bit for some improvements I thought could be made. I bought his plans even though I didnt use them at all but I wanted to support him since it was his idea in the first place. Im itching to get my hands on some of his squares!
08-26-2020, 07:35 PM | #39 |
The rear rotors came in. These are first gen Cadillac CTS-V front rotors. They are 355mm(14")
The first gen CTS-V was 6 lug for some reason. Even though it is a smaller 6 lug I can redrill them to the proper 6x5.5 easily. The best part is they are very affordable at around $100 for the pair. Here they are next to a cpp rotor. I bolted together a rear link and link brackets for some inspiration to get the rear end done!
08-27-2020, 09:50 AM | #40 |
Wow, those trailing arms are AWESOME!
08-31-2020, 01:59 PM | #41 |
I got one of the front rotors in so I could make sure they are going to work for me.
There was a factory upgrade available on some gm half ton vehicles that used these 16.1" brembo rotors and 6 piston brembo calipers. I was able to source these replacement rotors from rock auto for $60 each. Since they are plain rotors I set them up on the mill and added some slots for style. The clearance in the wheel is really tight even though they are 22s. The low offset and shape of the transit wheels really only leaves 18.5" of room for caliper clearance. I need to get a caliper and verify clearance before I go any further with these brakes.
08-31-2020, 04:33 PM | #42 |
Geez. Us. That's a big rotor.
09-01-2020, 08:55 AM | #43 |
Those are huge! So, what exactly is the GM 1/2 ton vehicle that these fit for searching on RockAuto?
09-19-2020, 05:01 PM | #44 |
Found a little time to work on the truck today. Ive had these upper link mounts cut out for a while waiting to be built.
Its super satisfying how well they key onto the frame!
09-20-2020, 01:20 PM | #45 |
Just here to tinker
Wow just read through this. What an awesome build! Definitely excited to see this one finished! Jealous of your high tech skills!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
09-24-2020, 07:32 PM | #46 |
My Moser M9 axle housing came in! Very impressed with the quality all around.
If the rest of my parts get back from the plasma cutter tomorrow I should have a completed rear 4 link by the end of the weekend.
09-28-2020, 11:36 AM | #47 |
My upper links didnt get back from the machine shop on Friday so I didnt get as much done this weekend as I hoped.
I got the axle squared and located and tacked in the link mounts and finally got to bolt in those gorgeous lower links. I spent some of the weekend working on the swaybar design. It is comprised of off the shelf circle track components. I will make a custom adapter nut that utilized the lower link bolt as a mounting point for the swaybar linkage.
09-28-2020, 12:23 PM | #48 |
I feel I need >1.25" solid front bar but seem to be struggling on locating something.
09-29-2020, 06:51 AM | #49 |
Just read the thread again, love the work being done on this build. Very nice!!
Rick |
09-29-2020, 10:24 AM | #50 | |
Im using some quirky circle track stuff on the back that is pretty soft. On the front I will probably use Speedway Engineering stuff. Speedway engineering sway bars have always been great to me in the offroad world and we sure tortured them. Kartek is a great company to buy them through and their custom service is top notch. Lots of length and stiffness options on the bars and quite a few arm options as well. :cheers:
