10-29-2021, 12:52 PM | #326 |
Re: Project: Tow-Rat (Lil' Blue)
thank you sir!
10-30-2021, 09:48 AM | #327 |
Well that got messy i still never found a better way than to squirt it out n finger paint with it.
She's sealed n ready, just needs scuffed, taped, n shot with LizardSkin. |
10-30-2021, 10:26 AM | #328 |
You can also buy the brush on sealer dunno if that would work any better.
Looks good. |
10-31-2021, 09:59 AM | #329 |
Looks good. What sealer did you use and did you use a calking gun? Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
10-31-2021, 11:21 AM | #330 |
10-31-2021, 08:28 PM | #331 |
11-01-2021, 10:27 AM | #332 |
I think the finger paint method is the "proper" way to do it. That's how I did it on my floor as well and the stuff responds to that method pretty well.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
11-01-2021, 11:26 AM | #333 |
tried to lay a clean line with caulk gun, but it still needs smeared down into the voids and lay down a little flatter to the panel. i tried the whole "dip your finger in water" trick and it didn't seam to help much if at all.
i actually did 2 finger passes. one to press it into the panel gap and to lightly spread it out even, then another to flatten. if doing it again, i would run my finger in different directions each time to really press it into and behind all the welds better. right now i can see a few spots where there's a little void "behind" a weld. |
11-01-2021, 09:17 PM | #334 |
That must be the official method. The last truck I did I tried wearing a latex glove, ya didn't last long and my finger was poking out lol. It's coming along nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
11-01-2021, 09:57 PM | #335 |
I find it dries fast but when done I have dipped my finger, or some sort of formed tool, in wax/grease remover or lacquer thinner and used that to smooth it out for the final. Whatever the caulking tube says to use for clean up should work to soften the surface for a nice smooth finish. I have done a real mess at times and finished with a solvent soaked rag to smooth and clean up the mess, it looked good when done and filled all the voids.
11-02-2021, 08:17 AM | #336 |
i like the cleaning solution finger dip suggestion, i'll have to try that inside! i actually have a few cans of urethane reducer for paint too.
11-03-2021, 08:26 PM | #337 |
I also used the finger smear method. Start with a glove... end with... hopefully a glove still :P
11-05-2021, 06:41 AM | #338 |
6>8 Plugless........
Very nice work! I have always used the finger method too. Licking your finger works better than water but it is a bad taste after the first swipe. I tried wax paper one time over my finger but it was sort of a pain so I just went back to a bare finger. What do you plan to cover the frame with paint wise?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-05-2021, 10:05 AM | #339 |
I prefer to use those cheap disposable acid brushes to smooth the sealer.
Looking good. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
11-05-2021, 10:57 AM | #340 |
11-08-2021, 11:23 AM | #341 |
It's Monday......
11-08-2021, 12:37 PM | #342 |
everything did not go as well as it could have ...
so Sunday morning i hauled it outside with a few buddies, my painting tent has not yet shown up. was a GORGEOUS day, but the light breeze was too much to paint in. i cleaned it up n got the primer on, but no way i could shoot color. the shadows were also crazy and i missed places that i looked at 3x. also now that it's all one color, i found a few places i want to go back and touch up, just clean up the weld spatter or edges a little more. |
11-08-2021, 12:42 PM | #343 |
ANY progress is good progress...Is that DP40 primer? The green color looks like it.
Marc
11-08-2021, 12:59 PM | #344 |
11-08-2021, 01:59 PM | #345 |
Ok, I used a lot of that myself....I like it for a rattle can product.
Marc
11-08-2021, 02:16 PM | #346 |
yeah, i've always had reasonable luck with it. but this is the first time I'm doing a 2-part acrylic urethane over it. we shall see. I'm ok with just a rattle can finish, but i really wanted a little better chemical resistance for this. plus i couldn't find anything near the color i'm spraying in a can.
11-10-2021, 08:11 AM | #347 |
Life is too shot not to Hotrod :rock:
WOW, that took maximum effort. 12:30pm i started chipping spatter, 8:30pm i finished dragging tools back in. So my tent showed up Monday night after i had a horrible day trying to paint the primer, just in time to mock me. then sitting in the team meeting Tuesday morning i was having an aneurism over the nice weather, told my boss i would try the work thing again today and left. cleaned up a lot more welding spatter i had missed until i could see it in primer, and scuffed the whole thing. neighbor came up n helped me set up the tent and move the chassis out, if it wasn't for him coming up when he did i'd have never gotten done. thank god for neighbors! i've painted before, but not enough to feel proficient with it. that first gun of paint is feeling awkward, but i wanted to hit the "gotcha spots" that wouldn't get much paint unless specifically hit ... i had a lot of those. just a little into that i'm under the chassis spraying the suspension tube work and splash most of my paint out on me and the ground when the lid pops off. well i gota finish the paint that's left in it ... while my hand glues to the gun. i had to do a full clean up of myself and the gun to start again. back at it, spraying along, 3rd gun of paint and i'm back under the chassis, spraying the same spot, and i laid in the puddle of paint. now my shirt is gluing itself to me while i finish this gun, my armpit sticking together. i still have orange armpit hair :facepalm: after that i got a system going and couldn't be happier with the results! Last edited by 6DoF; 11-10-2021 at 11:37 AM. |
11-10-2021, 08:38 AM | #348 |
That frame came out gorgeous, and your story about the painting mishaps made my day (I have done something quite similar!).
11-10-2021, 09:08 AM | #349 |
Awesome pics (especially the light up canopy at night). That orange chassis should pop nicely next to the blue body. I like your color choice.....Be bold my friend. Well done.
Marc
11-10-2021, 09:39 AM | #350 |
Thanks!
and the story is way more entertaining this morning than it was last night |
