Old 03-28-2022, 10:21 AM   #676
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: New 64 Stepper Project
Congrats on the awards, you have built an outstanding truck!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-28-2022, 10:28 AM   #677
The Rocknrod
Moderator
The Rocknrod's Avatar
Thanks buddy. ��
Old 04-15-2022, 02:55 PM   #678
pdxhall
pdxhall's Avatar
Hey man, I remembered back awhile you bought the Honda door seals, didn't like them, and replaced them. I'm in the same spot right now. I didn't notice any follow-up on the new seals you used. How are you liking them?
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-15-2022, 03:12 PM   #679
The Rocknrod
Moderator
There are a couple spots where they too are tight. It's been over a year so it is getting better. The doors close and line up. No edges sticking out. So I guess I'm good now.
Old 05-22-2022, 01:36 PM   #680
The Rocknrod
Moderator
So I'm replacing the rear end cover with this. Also purchased the CPP deluxe panhard bar.
Old 05-22-2022, 01:59 PM   #681
Joe Pass
Joe Pass's Avatar
Nice bling......did that on mine also
Joe Pass is offline   Reply With Quote
Old 05-22-2022, 02:05 PM   #682
The Rocknrod
Moderator
Great minds...
Old 05-22-2022, 02:07 PM   #683
Braunschweiger
Nice piece, well made.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 05-29-2022, 07:55 PM   #684
The Rocknrod
Moderator
So the B&M Differential Cover came with the wrong load bolts and no fill plug. Summit tried to get Holley to respond for the last week to no avail. So I bought a set and a fill plug from Summit, received them and attempted to install it. Didn't want to wait till June or...?
That didn't work because the 14 bolts (instead of 12) B&M sent with the kit I found were metric. Yep. So I called Summit and complained again. Only this time the guy I spoke to sent me new correct fastener for the cover on they're dime.
This is the most expensive 12 bolt cover I have seen in my life in both time and parts to buy in order to install it. Still no word from Holley or B&M.
Looks great and sealed tight as a drum but come on.
I also installed the CPP deluxe (bent) panhard bar, no issues there.
Old 06-13-2022, 11:07 AM   #685
The Rocknrod
Moderator
I forgot to post pics of it installed.
Old 07-03-2022, 01:55 PM   #686
The Rocknrod
Moderator
I changed my tail lights up a bit, used the same housing though.
Old 07-03-2022, 08:10 PM   #687
SkinnyG
SkinnyG's Avatar
I might have missed this - did you intentionally put the rear bumper on upside down? If so, do you have a picture of the whole back end like this so I can see if I want to as well?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-03-2022, 08:23 PM   #688
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'd like to see it too.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-03-2022, 08:28 PM   #689
SkinnyG
SkinnyG's Avatar
I went back. Found pics I wanted here: http://67-72chevytrucks.com/vboard/s...666226&page=20
Thanks.
Old 07-03-2022, 09:59 PM   #690
forestb
forestb's Avatar
It is from a different year. Late 60’s early 70’s body style. I only know because I asked the same question a while back.
forestb is offline   Reply With Quote
Old 07-03-2022, 10:07 PM   #691
The Rocknrod
Moderator
Exactly. You did ask.
Old 07-03-2022, 11:26 PM   #692
LostMy65
LostMy65's Avatar
Looks great
Old 07-03-2022, 11:29 PM   #693
The Rocknrod
Moderator
Looks great
Thank you.
Old 07-19-2022, 03:56 PM   #694
forestb
forestb's Avatar
Do you have a photo of how your vintage air accessory brackets attach to the header bolts? I want to get that style of bracket but I don't think that they will work for me sense the first tubes on my headers go straight back instead of down.
Old 07-19-2022, 04:05 PM   #695
The Rocknrod
Moderator
Well I'm using Alan Grove Brackets that only attach to the head. Same with or without headers. I have since changed to corvette manifolds.
Old 07-19-2022, 04:19 PM   #696
forestb
forestb's Avatar
Do you have the part number? Vintage air sells the Alan Grove Brackets. That's why I called them that. Sorry if that was confusing.
Old 07-19-2022, 04:28 PM   #697
forestb
forestb's Avatar
Do you have a Saginaw Power Steering Pump and where did you get that bracket?
Old 07-19-2022, 04:46 PM   #698
The Rocknrod
Moderator
Yes Saginaw Pump.
Part#
132R - A.C.
232L - Alt.
400L - P.S.
http://www.alangrovecomponents.com/S...Short_Pump.htm
You can shop around, eBay, Amazon etc for the best price I always do.
Someone on here said they were afraid of their belt coming off. I've had my engine up to 5K RPM without issue. NASCAR up until last year used engine belts that were not serpentine and they take they're engines to extreme for hours and hours year in and tear out.
As a set these Alan grove units line up perfectly.
Old 07-19-2022, 04:48 PM   #699
forestb
forestb's Avatar
Thanks. Your awesome.
Old 07-19-2022, 05:03 PM   #700
The Rocknrod
Moderator
All the instructions for the brackets are at the bottom of this page, just find the bracket number and a PDF file will open with the instructions.
http://www.alangrovecomponents.com/Important_Info.htm
They come with them in the box but just in case you want to be ready...
