#676 |
I'm just glad to be here!
Re: New 64 Stepper Project
Congrats on the awards, you have built an outstanding truck!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#677 |
Moderator
![]() ![]() Join Date: Aug 2011
Thanks buddy.
#678 |
![]() Join Date: Mar 2011
Hey man, I remembered back awhile you bought the Honda door seals, didn't like them, and replaced them. I'm in the same spot right now. I didn't notice any follow-up on the new seals you used. How are you liking them?
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
#679 |
Moderator
There are a couple spots where they too are tight. It's been over a year so it is getting better. The doors close and line up. No edges sticking out. So I guess I'm good now.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 04-15-2022 at 06:13 PM. |
#680 |
Moderator
So I'm replacing the rear end cover with this. Also purchased the CPP deluxe panhard bar.
#681 |
![]() ![]() Join Date: Aug 2013
Nice bling......did that on mine also
#682 |
Moderator
#683 |
Nice piece, well made.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
#684 |
Moderator
So the B&M Differential Cover came with the wrong load bolts and no fill plug. Summit tried to get Holley to respond for the last week to no avail. So I bought a set and a fill plug from Summit, received them and attempted to install it. Didn't want to wait till June or...?
That didn't work because the 14 bolts (instead of 12) B&M sent with the kit I found were metric. Yep. So I called Summit and complained again. Only this time the guy I spoke to sent me new correct fastener for the cover on they're dime. This is the most expensive 12 bolt cover I have seen in my life in both time and parts to buy in order to install it. Still no word from Holley or B&M. Looks great and sealed tight as a drum but come on. I also installed the CPP deluxe (bent) panhard bar, no issues there.
#685 |
Moderator
I forgot to post pics of it installed.
#686 |
Moderator
I changed my tail lights up a bit, used the same housing though.
#687 |
I might have missed this - did you intentionally put the rear bumper on upside down? If so, do you have a picture of the whole back end like this so I can see if I want to as well?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#688 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I'd like to see it too.
#689 |
I went back. Found pics I wanted here: http://67-72chevytrucks.com/vboard/s...666226&page=20
Thanks.
#690 |
#691 | |
Moderator
#692 |
Looks great
#693 |
Moderator
#694 |
Do you have a photo of how your vintage air accessory brackets attach to the header bolts? I want to get that style of bracket but I don't think that they will work for me sense the first tubes on my headers go straight back instead of down.
#695 |
Moderator
Well I'm using Alan Grove Brackets that only attach to the head. Same with or without headers. I have since changed to corvette manifolds.
#696 |
Do you have the part number? Vintage air sells the Alan Grove Brackets. That's why I called them that. Sorry if that was confusing.
#697 |
#698 |
Moderator
Yes Saginaw Pump.
Part# 132R - A.C. 232L - Alt. 400L - P.S. http://www.alangrovecomponents.com/S...Short_Pump.htm You can shop around, eBay, Amazon etc for the best price I always do. Someone on here said they were afraid of their belt coming off. I've had my engine up to 5K RPM without issue. NASCAR up until last year used engine belts that were not serpentine and they take they're engines to extreme for hours and hours year in and tear out. As a set these Alan grove units line up perfectly.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 07-19-2022 at 04:57 PM. |
#699 |
Thanks. Your awesome.
#700 |
Moderator
All the instructions for the brackets are at the bottom of this page, just find the bracket number and a PDF file will open with the instructions.
http://www.alangrovecomponents.com/Important_Info.htm They come with them in the box but just in case you want to be ready...
